Thanks. I figured that might be the case, but figured I'd ask anyway.
Thanks for sharing the info, 470hp sounds about right. Not the pie in the sky 500hp number folks were praying for, but a healthy bump above the LS3 to satisfy all of the 'ONLY 15HP?!?!' complainers.
If the weight does not go to hell it may perform well.
You could pay the $24 and read it, You know, it's possible GM Was not telling the whole story with that graph.
Do you know that GM was not telling the whole story with that graph?
Maybe that Official GM graph was when the engine was running in 4 cylinder mode. Yep, I bet it was. Hey everyone, the LT1 has 900 horsepower and 900lb-ft of torque. GM wasn't telling the whole story with that graph. Don't have any proof, but I know it's true.
Maybe that Official GM graph was when the engine was running in 4 cylinder mode. Yep, I bet it was. Hey everyone, the LT1 has 900 horsepower and 900lb-ft of torque. Don't have any proof, but I know it's true.
Honestly, just hypothetically speaking, what would you say if GM releases final numbers to the public soon, and it turns out the C7 will indeed have ~470 bhp?
Weight does not have to go up, we shall see what the fuel economy is like after GM cranks up the motor. The fact that neither MPG, weight or hp are disclosed are a very good indicator of what actually takes place and where this is heading.
I know how the SAE certification is done. Known about since around 2005.
I didn't ask how the certification was done. I asked if the magical numbers the OP is saying appears in the SAE paper were SAE certified numbers(the numbers that will be advertised by GM).
I still haven't seen an answer to my question about the 7200 RPM horsepower readings that are supposed to be mentioned in the SAE paper. I know from the dyno graph that GM has released for the C7's LT1, that the redline is 6500 and the horsepower starts dropping at 5900 RPM and that the LT1's torque drops off faster than the LS3's(which indicates that the engine is not going to put out magical horsepower numbers at high RPMs, above the LS3's).
IF you know how it's done, why did you say: "If GM can release all those magical numbers to the SAE"?
Huh? Is that to imply that you think all of those will be bad news? You're not really a glass-half-full kinda guy, are you? Not to mention that I just don't see the logic behind that conclusion at all.
As for MPG, they have not given us final numbers yet, but it has been made pretty clear that mileage will be VERY good for a 450-500 hp machine. Certainly a notable improvement over the C6.
Because the OP said the SAE paper had numbers. If the SAE has "certified" numbers, then GM also has them so why can't GM release them. Isn't that what we've been waiting for? Or is the SAE paper about another genV engine that is not going to be used in the base C7(thus the 7200 RPM crap that we know is not the redline of the LT1 that GM has said will be in the case C7).
Could the 7200 RPM be the redline for an optional engine that will indeed have more horsepower than the base LT1 engine and that is what the SAE paper is about? I Don't know and neither do you, so I'll stick with the known information that GM has released so far regarding the C7's LT1 to be used in the base C7..
Because the OP said the SAE had numbers. If the SAE has "certified" numbers, then why can't GM release them. Or is the SAE paper about another genV engine that is not going to be used in the base C7(thus the 7200 RPM crap that we know is not the redline of the LT1 that GM has said will be in the case C7).
So which trim would have it then? You think they are going to introduce a new Corvette trim between the Z06 and the base C7?
EDIT: Nevermind, I suppose you may be talking about a non-Corvette powertrain using the engine. Fair enough, I suppose.
I'm also still genuinely curious about the answer to the question I asked you a minute ago.
Thats because the sae was watching, if you knew the test as you claim, then you would know they both have the numbers at the same time.
Don't you read anything? The SAE doesn't watch a certification; a third party, independent from GM or the SAE, witnesses the GM dyno pull. The SAE(in conjunction with the auto manufacturers input) wrote the certification protocol, and GM does the dyno pull according to the SAE protocol, and a independent third party certifies that GM did the dyno pull according to the SAE protocol.
And you can bet your bottom dollar that the third party witness has to sign a confidentiality agreement not to release any info without GM's consent. And that means to the SAE.org.
I dont think anyone wants GM's numbers as much as some independent testing and dyno pulls....IMO!!!!
DO you understand anything? I'm the one who posted the link to the test standard, It says an SAE qualified witness is watching, who do think is certifying the test?
I do not think these are satisfactory numbers without knowing the specifics, do you?
Yes, exactly, they will be very good for 450 hp car, this does not mean they have to be better than for 436 hp car, does it? You obviously do not get this part.
And don't you understand that the witness in neither employed by GM or the SAE. The SAE is not present when the horsepower/torque is certified. Do you know for a fact that a SAE witness was on hand to certify the numbers the OP is talking about being in that SAE paper he linked. It could very well be some engine development program that is going on that GM thought would make a nice SAE paper, and nothing to do with the LT1 going into the base C7.
But it sure makes nice fodder for those that refuse to believe what GM has made available to the general public and want to believe their own pie in the sky fantasy numbers, that they can't substantiate with any factual evidence from GM.
Honestly, then that will be the horsepower of the C7. As of today, GM has only officially mentioned the 450(est) number. They have not mentioned any other number, so why should I believe in another number.
GM has said nothing about offering a Pepto Bismo Pink color for the C7 either. But if Vickie Kerbeck kept making posts every day about how she believes the C7 will be(or should be) available in Pepto Bismo Pink, does that make it factual information that Pepto Bismo Pink will be offered, today? Now a month from now, and GM says they will offer a Pepto Bismo Pink color for the C7, then I will believe it. But I won't today as there is nothing from GM that says that Pepto Bismo Pink will be offered but only Vickie wishing there was, so she wouldn't have to have her daddy paint one in their body shop just for her.
Nice obfuscation,
[QUOTE=JoesC5;1583593327]Do you know for a fact that a SAE witness was on hand to certify the numbers the OP is talking about being in that SAE paper he linked.
I really should put you on the ignore list, but this statement is just ridiculous. GM has said the c7 will have a significant MPG improvement over the C6 while increasing in peak HP and TQ as well as under the curve. Significant is more than an average increase of 2mpg but less than an average increase of 8 mpg. It's irritating that someone has to be so specific with you because as soon as your point has been proven incorrect you back track or move to a loosely similar but unrelated point.
