** C7 Reported issues and resolutions thread **
Old Oct 14, 2014 | 02:40 PM
  #2061
dckotwicki's Avatar
dckotwicki
Originally Posted by dalinone
VIN #1127.
My NPP does the same thing but at around 25 MPH. Didn't notice it until around 300 miles. The NPP is also in "open"; i.e. Active Sound Management is "off".
I have a 2014 and have noticed the same thing. It is now my belief that it is not the exhaust that is closing, but the AFM is going to 4 cylinder mode. Watch your V8 - V4 on your instrument cluster. My guess is that will be the issue. Sounds like a door is closing and then the exhaust is quite.
AFM is the culprit.
Old Oct 14, 2014 | 07:11 PM
  #2062
lastcowboy's Avatar
lastcowboy
AFM is the culprit.
it is the 8 going to 4 and it drives me nuts. somewhere around 1500-1700 rpm the flaps for the 4 close to about the size of a nickel opening for back presure and the d.mode at the back has no presure and goes quiet.
something else i've noticed when driving with the window down the a6 will go through what seems to be down shiftting and then i hear what i first thought was metal twisting or a small cherp sound from under the car .now i don't know if its the 4c. values closing or what it is but it dosen't sound normal( well gm would prob. say it was ) . it's not real loud but loud enough for me to hear with the window down.
some will prob. not notice this , but if anyone has let me know please.
Old Oct 15, 2014 | 01:44 PM
  #2063
Jedi-Jurist's Avatar
Jedi-Jurist
St. Jude Donor '15
So I followed all the recommended track procedures on the car (dealer did all the fluids, installed the cooling rings) and after two track days, my rotors are exhibiting surface cracks. I think they should last longer than two track days and less than 2000 miles on the car. Dealer doesn't believe GM will cover any part of the rotor cost; hoping you have a different opinion.
While we're at it, I'm seeing multiple part numbers for the 2015 Z51 Rotors (front and rear) - could you also please give me the correct part numbers?
Old Oct 15, 2014 | 09:38 PM
  #2064
Sallye M's Avatar
Sallye M
22 Hypersonic Grey HTC
When the Drive Belt Tensioner was leaking hydraulic fluid on my A6 I could hear a chirpy noise when in V4 and rpm's around 1300-1500 rpm's, at any speed. Dealer replaced the faulty tensioner under warranty. It is a known issue and there are PIP bulletins on this.
Old Oct 16, 2014 | 06:46 AM
  #2065
lastcowboy's Avatar
lastcowboy
thank you for your reply . the more i woud hear this the more it did sound like a chirp and thats about the same rpm. but its like one chirp when your slowing to a stop;
i had ck'ed the tensioner about 2wk's ago when someone had pm'd me about having thiers replaced i could find no leak everything looked fine . but who knows thank you for your input ....
Old Oct 16, 2014 | 10:30 AM
  #2066
kdavis69's Avatar
kdavis69
I have the same chirp (VIN 408, 2014 Z51 A6), no fluid leak that I can see, will have the dealer check it out at next oil change.
Old Oct 17, 2014 | 03:55 PM
  #2067
AWOL's Avatar
AWOL
Default Problem with A8 going into Park
When my car was removed from the car carrier after delivery, it would not go into Park.
The shift cable was bad. Has anyone else had this problem?
Old Oct 17, 2014 | 04:39 PM
  #2068
tmh68528's Avatar
tmh68528
Cruising
I have the exact same issue.
I will be curious to find out what the dealership tell you.
Please let me know and thank you!!
And...best of luck![/QUOTE]
I have the same issue. All brake pads were changed. Still did it. Then changed rear pads and rotors. No repeat yet. Let me know how you came out.
Tom
Old Oct 17, 2014 | 06:31 PM
  #2069
Paws's Avatar
Paws
Originally Posted by KNDVETT
No I am saying if I do not get run flats to replace OEMs
Get ANYTHING EXCEPT run flats.When I lived in Ct., I hit a 4 in pothole and got a bubble on both right side tires(car was one week old) Goodyear's reply,"Too bad !"
The owner of the local Chevy dealer was a father of a student and basketball player of mine. He comped BOTH tires. Had I not been in that position, I would have been out 1K.
Goodyear doesn't back them and they're $$$$$$ .
I switched to Goodrich on one car and Bridgestones on the other.
BOTH were significantly better for me.
Old Oct 17, 2014 | 07:08 PM
  #2070
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Uh, I thought C7s came with Michelin's. Why would you take your Michelin's to a Goodyear dealer??
Old Oct 17, 2014 | 07:09 PM
  #2071
lastcowboy's Avatar
lastcowboy
thier are alot of people that don't know that g.y. has a wart. that covers
road h. for 12k for anything . 50 mils on one vette 09 ,screw in sidewall ,dealer was going to sell me one but didnt have it in stock .
went to d. tire prepared to drop some $$$ guy there told me they were under g.y. wart. ....o $$$$...called the dealer and told him , he said he knew nothing about it.used this same wart. on 2011and 2013 gs hope i don't haave to go through that on the c7
Old Oct 17, 2014 | 09:51 PM
  #2072
Paws's Avatar
Paws
That's unusual because I also contacted Goodyear corporate customer service and was given the same song and dance.
I'm glad you had a more cooperative dealer.
For me, I'm done with Goodyear FOREVER.
Old Oct 17, 2014 | 10:36 PM
  #2073
sabatage69's Avatar
sabatage69
Default Issues with Driving Modes
2015 Stingray, just picked it up 2 days ago. I noticed today, when I would switch to example form Sport Mode, then to Track Mode ( I know not recommended for Street) just to see the difference in steering and exhaust the car when I went to go back to Sport Mode or any Mode, automatically skips all and goes to Weather Mode. Once in Weather Mode, I try to switch and skips all and goes back to Track Mode. I am hoping it is something I do not know, or is this a glitch? Any help would be appreciated. I am also turning the **** slow and waiting for it to engage before I switch out of it. Help please, while I will not be driving in track mode, I do not want something that is not working properly. Thank you!
Also it does it does sometimes work normal, there does not seem to be a rhyme or reason. Closest thing I could do is when I take off traction control and go to Track , then switch back, always seems to go back to Weather mode.
Last edited by sabatage69; Oct 17, 2014 at 10:38 PM. Reason: added something I tried
Old Oct 18, 2014 | 08:48 AM
  #2074
barryh's Avatar
barryh
Originally Posted by sabatage69
2015 Stingray... when I would switch [modes] ... [it] automatically skips all and goes to Weather Mode. ... is this a glitch? ...there does not seem to be a rhyme or reason.
Seems to be a common problem. My 2014 does the same thing. For me it has only been an annoyance; I've always been able to wrestle the dang **** into the proper mode eventually. I would bet that GM won't do anything until somebody threatens a lemon lawsuit for this stupid little problem.
Old Oct 18, 2014 | 09:42 PM
  #2075
dbisc's Avatar
dbisc
Originally Posted by bluedevil 1
2014 vin#53 Premium Edition When in reverse and the camera is on, I can read a good portion of my license number. Both I and the dealer have looked for a adjustment, no joy. Am wondering if we are incorrect?
Same here - curius that ther's no adj.
Old Oct 18, 2014 | 09:44 PM
  #2076
dbisc's Avatar
dbisc
try turning the opposite way (CCW)
Old Oct 18, 2014 | 09:56 PM
  #2077
dbisc's Avatar
dbisc
Default Odd feeling when making tight turns - slowly
I get a "funny" feeling in the wheel when I make a tight turn going very slowly (less than 5 mph) - it "feels" like it is coming from the rear. Seems smooth when going over 10MPH -
Any thoughts?
To ** C7 Reported issues and resolutions thread **
Old Oct 18, 2014 | 11:14 PM
  #2078
HalfMoon's Avatar
HalfMoon
This is by design so you can see the rear bumper and can even get REALLY close when doing parking maneuvers.
Old Oct 18, 2014 | 11:16 PM
  #2079
HalfMoon's Avatar
HalfMoon
Any thoughts?
It's addressed in the manual and is nothing new to Corvettes with large tires.
http://en.wikipedia.org/wiki/Ackermann_steering_geometry
You can also google "ackerman effect" for more details.
Old Oct 18, 2014 | 11:21 PM
  #2080
Iceman09's Avatar
Iceman09
St. Jude Donor '17
Any thoughts?
From the owner's manual pg 1-20:
"Tire Chatter/Hop
When driving at slow speeds and in
very tight turns, the vehicle may
have tire chatter/hop. This condition
is normal and the vehicle does not
require service."
