Another blown engine! Fully documented
Old Jun 24, 2015 | 04:27 PM
  #61
thrilled's Avatar
thrilled
Ya might say the failure rate is .0001% but I'm not going to gamble I'm going to start adding
Stuff to the engine after the 36 months.18K is A nice chunk of coin.
Old Jun 24, 2015 | 04:29 PM
  #62
RUBYREDVET's Avatar
RUBYREDVET
Originally Posted by ospreycorvette
This is exactly how the Z06 engine failure started. Discussions like this saying there is no problem is identical to the Z06.
And metal in the new engine, wow, HOW does that happen????
OMG, not the dreaded Z06 engine failure problem.........
Wasn't that failure rate something like 2000%?
I now just go into my dealer every 3 months for an entire engine swap on my '08..... Just in case.....
Sure I could try to sell it but I don't want the next owner to have to do the same thing. It gets spendy.........................
Old Jun 24, 2015 | 04:32 PM
  #63
BIG Dave's Avatar
BIG Dave
Originally Posted by CSEVEN
Yes, my car is driven. My crew is a little tuff too follow:
WOW! What a great bunch of rides!
I live in the area and I also purchased my C7 from Paul Masse.
  #64
RUBYREDVET's Avatar
RUBYREDVET
If you are that concerned........
Might wanna wait until the power train warranty is up.
Assuming that is still 5 yr/100,000 miles......
Old Jun 24, 2015 | 04:47 PM
  #65
jimmyb's Avatar
jimmyb
Hello Gang,
I recently blew my engine 2014 Stingray, #7727 with 18K miles. I wanted to spare the drama and share the complete time line and major events:
1. June 7th , engine started making a lower end knock: http://youtu.be/FoUBjXrhtzQ
2. June 8 through June 11, warranty tear down, 4 blown bottom bearings
3. June 12th complete long block engine, torque tube and clutch assembly approved under warranty
4. June 16th new motor arrives at dealership containing metal dust in cylinder heads
5. June 17th GM sends 2nd replacement motor VIA FedEx P1.
6. June 18th Motor arrives at Dealership and installation process begins
7. June 19th Car is ready for pick-up $25K+ repair bill covered by GM
I only lost one weekend and now basics have a new car, thank you GM and my local dealer for the best service in the world.
RIP!
Why did the dealer pull the heads on the first replacement engine? Can you see the combustion chamber/valves when the intake manifold is off?
Jimmy
Old Jun 24, 2015 | 07:11 PM
  #66
CSEVEN's Avatar
CSEVEN
Banned Scam/Spammer
Jimmy
They did not pull the heads off the replacement engine, picture taken through the intake .
Old Jun 24, 2015 | 09:51 PM
  #67
dgtvette's Avatar
dgtvette
3rd Gear
Hey See 7, I've seen you around a bit. Glad to hear Masse took care of you. I ordered my 2016 from them and has a TPW of next Monday.
Old Jun 24, 2015 | 09:57 PM
  #68
Chevy Guy's Avatar
Chevy Guy
What are those first two pics? You mention bad lower end bearings but show two pics that aren't bearings. Did the dealer tell you if it was rod or main bearings?
Old Jun 25, 2015 | 01:42 AM
  #69
imxz28's Avatar
imxz28
Two major points to make here...
1) Honda has the industries best record at 1 in 340 with Toyota in second with a 2 to 1 margin or 1 in 170. If GM has sold 60,000 I would expect to see around 600 engine failures or about 1% which is still good odds. The big question is over what time frame is the rating?
2) Seems there are more M7 failing than A6 or A8. Could it be the manuals are jolting the powertrain much more than the autos?
I think there are more A6 and A8 than M7 NO?
Old Jun 25, 2015 | 07:20 AM
  #70
CSEVEN's Avatar
CSEVEN
Banned Scam/Spammer
Cool, you will love the place!
Old Jun 25, 2015 | 07:24 AM
  #71
CSEVEN's Avatar
CSEVEN
Banned Scam/Spammer
I lost 3-4 Lower bearings (play) and engine had signs of liberation loss through out.
I was very lucky that it failed during slow operation, if it happened at high speed it would of more destructive.
Old Jun 25, 2015 | 11:26 AM
  #72
imxz28's Avatar
imxz28
Very good question. My assumption would be main bearing. I think that's what the others were. Maybe CSEVEN can ask his dealer?
Old Jun 25, 2015 | 12:55 PM
  #73
Zing's Avatar
Zing
Originally Posted by 05XLRtoC7_San Diego
Yikes- I've heard about this for the Z51.
Is this the first case of a blown engine for a base?
Glad it was resolved quickly.
Guess you had to break it in again for the first 500 miles.
No it wasn't I believe I had the first 6/2/14 [nothing that I'm proud of]. Vin was 6631. Car was also purchased in RI. Odd coincidence. the OP luckily heard the failure, where I found the failure while driving. Def. won't get into that debacle. To the OP, glad you got everything squared away fairly quickly!
Old Jun 25, 2015 | 02:16 PM
  #74
IdleUp's Avatar
IdleUp
To each his own but if it were my car - I would have taken the hit and traded it rather than have those monkeys tear it apart - it will never be the same as a factory install.
Old Jun 25, 2015 | 05:31 PM
  #75
Higgs Boson's Avatar
Higgs Boson
Wouldn't that be a GOOD thing considering the circumstances?
Old Jun 26, 2015 | 10:41 AM
  #76
Chevy Guy's Avatar
Chevy Guy
The Z06 thread was spawned by one idiot supporting vendor and a bunch of nut swingers who piled on. That was a disgrace.
Old Jul 9, 2015 | 04:55 PM
  #77
DGXR's Avatar
DGXR
So the new LT1 and LT4 engines are both failing...
I'm curious about the engine failure rates for the C6 ZR-1, Z06 and base models, for comparison. Are the new engines really failing at a higher rate? Or are the failures just getting more publicity because of the still-sensational C7 Corvette redesign? LT4 is the most powerful production engine in GM history?
Regardless, this is just reinforcement in my belief to NOT buy a car in the first 2 years of a new design. Don't misunderstand, I love the C7 quite a lot! It's an awesome car all-around and the supercar performance bargain -- bang for the buck -- simply cannot be beat anywhere. I just think it's a good idea to wait a few years until they get the bugs and gremlins worked out of the new design, as much as possible. For example, the last 2 years of the C4 (1995-1996) were easily the best years for that generation, a typical example.
To Another blown engine! Fully documented
Old Jul 9, 2015 | 05:41 PM
  #78
imxz28's Avatar
imxz28
See post 69 about 8 post above here. I think too many people are eager to run around screaming the sky is falling if they know of 2 or 3 failures. Keep in mind, a fair portion of the failures are coming from LT1's that are pushed hard with superchargers and/or slicks at the track. I admit there's been discussion about main bearing design but as far as I know, GM has not redesigned or that. They are normally fairly quick to address significant issues such as the 2001 oil consumption. A new piston ring design fixed that. I'm confident major problems will be addressed as needed. Again, see post 69 and ponder the numbers.
Old Jul 9, 2015 | 05:45 PM
  #79
corvettecop's Avatar
corvettecop
Originally Posted by tsts
A pat on the back for the GM dealer that performed so well.
Question: What oil have you been using?
Dextos or Mobile 1 or something else.
Dexos is a specification, not a brand. Mobil 1 5w30 is Dexos approved. (Just saying' ;-)) I think you mean did they use the GM- branded synthetic blend 5w30 or Mobil 1 5w30- correct?
Old Jul 9, 2015 | 05:49 PM
  #80
Leicajh's Avatar
Leicajh
Default Great photo
Thank you!
Another ride through Boston on Saturday.
Looks like a Transformer movie shot. Nice!
