CD player
Old Feb 18, 2016 | 08:48 AM
  #41
Boiler_81's Avatar
Boiler_81
FAT32 is not required for music, NTFS works as well. FAT32 is only required for the PDR.
Originally Posted by wbrands
Check your USB thumb drive format type. Pretty sure you need it formatted to FAT32. Should then work in both the behind the screen and console locations.
Old Feb 18, 2016 | 10:00 AM
  #42
Hoonose's Avatar
Hoonose
Originally Posted by The Sea
I just bought a 2016 coupe and it does not have a cd player. Now, I do not have a mp3 player or an IPod but was thinking maybe a portable CD player may work..
Jerry in Minnesoeta
If not already mentioned in the thread:
A portable CD player should play from the headphone output through the Aux input using a stereo mini plug wire.
Old Feb 18, 2016 | 10:34 AM
  #43
DAFFYDRUNK's Avatar
DAFFYDRUNK
Originally Posted by rockit1
check 320 kbps
I agree with this. 320kbps is the point where it's hard to hear the loss unless it's a nice system. With my little home recording studio setup, I rendered a song I recorded at 24-bit/96kHz to a 320kbps mp3. I can hear the difference but that's probably because it's my own music and I've analyzed the original a zillion times.
With the run of the mill corporate pop music, I can't tell much of a difference, particularly with my 1LT C7 stereo. It sounds good enough for me, but lots of people are critical of the quality. Probably no real reason to get too crazy with ripping CDs.
Old Feb 19, 2016 | 12:21 PM
  #44
xwing's Avatar
xwing
Originally Posted by wgood
Yes it will just plug it in the aux jacks ( through the earphone jack ) the same as my mini nano ipod and I still have my 1990's portable CD player !!!! Wayne
Not only do I still have my Discman, I still have my Walkman from the mid '80s. I checked it recently and it still works. They made a lot better products back then. Of course I can't think of a real scenario where I'd use it.
Old Feb 21, 2016 | 01:49 AM
  #45
toolking's Avatar
toolking
From the '16 Infotainment Guide:
Applicable audio extensions
are mp3, wma, aac, m4a,
and aif. WMA and Apple lossless files
are not supported.
Get a flash drive and load high quality (high quality being a relative term) mp3's or wma's as suggested. There's all sorts of software available to convert. You can load thousands of songs because the files are much smaller than the originals.
There is a limit to the number of songs on the drives but I doubt you have that much music.
Old Feb 21, 2016 | 06:53 AM
  #46
rrsperry's Avatar
rrsperry
You are correct that WAV and FLAC are not supported. But it seems to read my apple lossless iPod just fine...
I actually bought a couple of 160G iPods that just leave in my cars. Unlike my only Valentine1 that I have to schlep from car to car...lol
Old Feb 22, 2016 | 12:01 PM
  #47
dr_gallup's Avatar
dr_gallup
Does anyone know the max allowable size for a USB flash drive for a 2013 GS with Bose & NAV? I know it has to be FAT32 format and MP3 files but not sure if I can use a 128 GB drive. My RAM pickup maxes out at 32 GB which is good for a lot but not all of my music collection.
Old Feb 22, 2016 | 12:59 PM
  #48
NostraD's Avatar
NostraD
Thought it might be helpful to provide a link to a post/thread I created a while back, dealing with many of the questions, comments, and speculation I've seen throughout this thread.
While I wrote this up a while ago and it's based on my own '15 3LT system, I believe the majority of the info remains accurate and relevant to all, including '16 owners, with one exception... The 2016 models removed the SD card slot for music in the center console. While the SD slot in the glove box remains, it is exclusively used for the PDR system (if you have one).
https://www.corvetteforum.com/forums...nfo-found.html
Hope this info helps. I'm also happy to answer any questions, as I've done quite a bit of experimenting with the C7 Infotainment system.
Good Luck!
Old Feb 22, 2016 | 01:14 PM
  #49
Boiler_81's Avatar
Boiler_81
I had tried to find his thread earlier to post here. Thanks for adding it. That thread should be a sticky.
Good Luck!
Old Feb 22, 2016 | 01:22 PM
  #50
CriticalmassGT's Avatar
CriticalmassGT
VBR is preferable. But whatever, as others have stated, just have someone copy the music over for you if you can't figure it out yourself. That's why people offer these services.
Old Feb 22, 2016 | 01:59 PM
  #51
1776DAVE's Avatar
1776DAVE
My step son gave us his I pod and it won't play in behind the screen or I'd the console!
I am getting tired of not hearing the stones or Cher when the mood hits me.
Old Feb 22, 2016 | 02:27 PM
  #52
NostraD's Avatar
NostraD
Before I went through a re-rip of my CD collection about 5 years ago (when I was 45), I did extensive online research along with my own rigorous audible testing, before I settled on a format and bit rate.
What my research and personal testing yielded was that I (personally - with excellent tested hearing for a 45 year-old) found it almost impossible to differentiate the quality level, once I got to 192 kbps. Anything higher/better did not actually sound any different to me, that included many genres and varied volume passages.
The simple fact is that as we age, our hearing capabilities simply deteriorate. Even those of us who maintain excellent hearing ratings for our age will experience some level of loss, probably more so on the hi-end. Therefore, while a 22 year-old can probably easily hear the difference between the same song ripped at 128 vs. 192 vs. 320... Most of us over 50 probably can't.
Now (5 years later) that memory storage has increased so much, while costs have reduced, I purchase most of my music at 320, mostly because it comes that way.
One additional note... Some/Many CDs created back in the 80's - 90's sounded like CRAP. When you rip CRAP audio in any format at any rate, it still sounds like CRAP. For those types of albums, I've sought out "Remastered" versions of my favorites, which sound amazingly better.
Mix all of this with the fact that our C7's are far from Audiophile Sound Chambers... and I see no reason, benefit or necessity to rip your music in "Lossless" or other hi-end formats. I'd recommend 192 at a minimum (if you have storage/memory constraints) and 320 as a max. However, I do agree with the above post that utilizing "Standard Quality" 48kHz VBR (Variable Bit Rate) is also beneficial and yields file sizes similar to what you'd see if converting somewhere between 192-256.
Just my opinion... with some factual research blended in.
Old Apr 22, 2017 | 04:36 PM
  #53
SargeInSocal's Avatar
SargeInSocal
Originally Posted by Kfmorgan
I have a 2016 Z51, 2LT coupe also. There are a couple of articles in the forum that tell you how to use a flash drive to transfer your CD's to it. When done, it will work in the USB ports in the console, or behind the screen.
The basics are as follows: I am using a 16GIG drive , and already have about 130 CD albums on it, with plenty of room left.
Insert a CD into your computer drive (I have windows)
Go to your Windows Media Player
Click Music
Below that you will see the CD album that you have inserted into your computer drive:
Double click that
Above you will see RIP CD
Click that and set to automatically rip CD's
Click Rip settings and check MP3 format and audio quality of 192Kbps
You hardly notice any decrease in the quality of the sound, in your car with these settings
This will get your CD copied into your windows Media Player
Remove your CD from the computer and insert a blank flash drive into your usb port on the computer
On the computer screen, click Start, then Computer. Double click the flash drive icon. Go to the media player and Right click Music. The CD's that you have in there will show. Right click the one you want to transfer to your flash drive, and click Copy. Go back and right click Music on the flash drive, and click Paste. Seconds later it's done, and on your flash drive, which you can then play in your car.
I'm sure that this seemed pretty long winded, but it worked for me with the help of others on this forum. I'm also sure that if I left something out, or wasn't clear, that someone more knowledgeable about these things will chime in.
Good Luck!
Irony: I tried to do a screen shot of this - But have no idea how to do it on this tablet thing...
Sarge
Old Apr 22, 2017 | 05:52 PM
  #54
defaria's Avatar
defaria
Originally Posted by mikez06
Thank you Kfmorgan. Some of us have no clue what the terms even meant!
Then Google them! The knowledge of the world is on the internet and available for all to take advantage of. All you need is a little ambition...
Old Apr 22, 2017 | 08:44 PM
  #55
CP's Avatar
CP
Originally Posted by thrilled
To much like work.Many of us would just stick A tape in something and head on down the road.
Why does this crap have to be so difficult? It is almost IMPOSSIBLE to listen to a book on CD that has been converted to MP3 files.
Old Apr 22, 2017 | 11:47 PM
  #56
witch hunt's Avatar
witch hunt
very true---the compartment behind the screen was clearly designed for a CD player but with the NAV/audio system they ended up using, a CD player is simply not compatible. I believe non-NAV vehicles could be fitted with functional CD players in the space there, but with no tech support from GM on this, apparently no aftermarket vendor has attempted anything.
Old Apr 23, 2017 | 08:55 AM
  #57
jaybar's Avatar
jaybar
Originally Posted by felkebg
We check out books on disc from our library for long road trips. I may try to load the discs on an SD drive and see if the publisher has put any anti-copy/security protection on the boxed set. Anyone done this?
I tried it once though I had limited experience doing any copying CD's, and it seemed that all the sections grouped together. Meaning of the 8 CD's all of the first track grouped together and then the second track etc.
I have found my local library offers audio books for down load for free. They us an app called "Overdrive" which is not one of the CarPlay apps but I can play it as music . Problem is the book disappears in two weeks so if you don't take a long enough trip you may not hear the end of the book.
To CD player
Old Apr 23, 2017 | 09:11 AM
  #58
Curahee's Avatar
Curahee
Default Skipping is a problem
Every time I hit a bump in the road, my turntable skips to the next song. Does anyone know of an effective damping system to prevent this skipping?
Old Apr 23, 2017 | 09:29 AM
  #59
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
A hammer.
Old Apr 23, 2017 | 10:18 AM
  #60
DogTag-C7R's Avatar
DogTag-C7R
Better hurry- cd drives on computers are about gone too as they should be. Always be able to get a plugin drive I imagine but so much easier to just download....to be honest I quit downloading 5 years ago as well , too much hassle. I simply have my playlist in the cloud.....I have given in to the fact that to play a song I don't have to physically hold a cd or thumb drive....I can't lose a cloud....you have to have a backup of your thumb drive stored....I just let them store it for me....it's always available ....nothing I have to have with me. Way things are headed anyways. It's just easier....I like a song and I add it to one of my playlists....all there is to do.
