Cheap front camera
Old May 7, 2017 | 02:17 PM
  #241
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
Default I Like This Setup Better...
OK update for anyone interested - I sent back that Trio "mini tablet" as it was just too laggy to use for parking. For $25 it was worth the gamble but didn't work out, so it got returned.
However.....I DID find a much better solution that I DO like for a bit more money. I bought a new Blu Studio X8 HD smartphone, with no SIM card, for $50 on Amazon. It has a 5" display and a 1.4 ghz processor w 4GB of internal memory - and it works quite well as a monitor for this cheap camera setup. Because it is about the maximum size that can fit in the cubby, I paired it with a 1ft long 90 degree micro USB cable.
I think I am finally done with this mod and I am happy with the results!
Old May 7, 2017 | 02:53 PM
  #242
Bob Beroza's Avatar
Bob Beroza
I used a $19 Android burner phone and never activated it.
My only disappointment is that it takes to long to boot up.
As as I get a new iPhone, I'll switch to my 6S
Old May 7, 2017 | 05:00 PM
  #243
C6 MoneyPit
Same here, they are worth next to nothing as a buy back.
Old May 8, 2017 | 09:45 PM
  #244
smajicek's Avatar
smajicek
I have been following this thread since day 1 and was weighing all the options. My decision was to just dig a little deeper into my pocket and splurge on Navtool, $36 for 3 Pyle cameras and installed myself. Not hard at all, side cameras are mounted in the front portion of my 2 side windows. Now when I use my blinkers I have that extra eagle eye looking out towards the rear sides. Just my thoughts and opinion and decision.
Old May 14, 2017 | 09:45 AM
  #245
cberistain's Avatar
cberistain
Am I correct in that the 12V dc connection from the wifi unit is Red for hot and Black for ground?
Old May 14, 2017 | 10:09 AM
  #246
cberistain's Avatar
cberistain
I should have re-read the previous posts ... found all the answers to my questions ... now just waiting for the micro tap fuse holder to arrive.
I have a Z51 so I will have to play around with where to put the wifi unit. I see one poster routed it inside the car ... I may try that if I can't find a good place to tuck it in the engine compartment.
Old May 15, 2017 | 02:07 PM
  #247
cberistain's Avatar
cberistain
Originally Posted by fredl11
Put it to the test morning.
Worked great
I also ran mine differently. I put the transmitter inside under the glove compartment
I ran the wires from camera along passanger side underneath fender
Then under rubber and taped over
Removed moulding and ran wires underneath and and behind portion of moulding under the glove compartment
The heat of engine compartment had me concerned
I have a Z51 as well and would like to run the wifi unit inside the cockpit like you did ... but I can't quite figure out how you did it from the photos .. I don't see any holes/openings to fish the wires through from the engine compartment to the cockpit ... any help would be appreciated.
Old May 15, 2017 | 03:44 PM
  #248
agapsdiver's Avatar
agapsdiver
Just go under hood to rear of front fender.. then under vertical door seal trim.
Old May 15, 2017 | 03:50 PM
  #249
cberistain's Avatar
cberistain
got the wifi installed in side under the glove box ... working now on mounting the camera ... I'm using the rectangular eskay unit and it doesn't fit inside the grill ... I saw someone found a way to mount it and I'll be trying that shortly.
Old May 15, 2017 | 05:27 PM
  #250
Bob Beroza's Avatar
Bob Beroza
I mount mine using High Perforce Double Stick Tape (the gray stuff.
Old May 15, 2017 | 09:03 PM
  #251
cberistain's Avatar
cberistain
is the mounting plate taped to the top of the grill or the surface above the grill ..
Old May 15, 2017 | 09:19 PM
  #252
Bob Beroza's Avatar
Bob Beroza
Mounted to the flat spot on the top of grill
Old May 15, 2017 | 09:37 PM
  #253
CP's Avatar
CP
I mounted my camera in the license plate frame. The camera was from NavTool and has no bracket.
Old May 16, 2017 | 08:46 AM
  #254
agapsdiver's Avatar
agapsdiver
Now that's convenient ......
Old May 16, 2017 | 08:23 PM
  #255
cberistain's Avatar
cberistain
finally got ours installed.. worked first time we turned it on . .. which is good news for us .. but the image is upside down,.. hope there is an adjustment for this .. as removing the camera and flipping it upside down will not be easy.
Old May 17, 2017 | 04:46 PM
  #256
cberistain's Avatar
cberistain
should there be a cover on the button?
I'm having a problem with the "button" can only turn the grid lines off and on .. can't do the rotation, spacing of grids, etc .. any suggestions?
Old May 17, 2017 | 05:52 PM
  #257
Bob Beroza's Avatar
Bob Beroza
You should have gotten the a set of instructions with the camera. By pressing the button multiple times you can change the camera functions. Here's a copy of the instructions that came with my camera. I hope this helps you.
Esky Car Camera Instructions - One Button Control for Front/Rear Camera Switch
To Cheap front camera
Old May 17, 2017 | 06:33 PM
  #258
cberistain's Avatar
cberistain
[QUOTE=Bob Beroza;1594759808]You should have gotten the a set of instructions with the camera. By pressing the button multiple times you can change the camera functions. Here's a copy of the instructions that came with my camera. I hope this helps you.
I have the manual ... pressing the button twice should bring up the picture rotation feature ... doesn't work .. none of the others . press 3 times, press 4 times, etc work ... I tried pressing slowly, quickly and in between .... nothing seems to work except adding/removing the grid lines.
Old May 21, 2017 | 07:31 PM
  #259
cberistain's Avatar
cberistain
Hope someone can help me with the eskay camera .. picture works perfectly ... but I can't seem to access the software that allows reversing the picture or adjusting the grid lines ... I have the little booklet that tells how to do it .. I thought it must be a defective camera so I got a new one and it does the same thing .. hard to believe that I could get two bad camera in a row, expecially when I didn't see anyone else talk about issues with the camera,
so .. is there anything special about the way the button is pushed to get to the adjustment screens? ... when you set yours up,.. did you have any problems getting the adjustment screens to appear on the iphone?
thanks
charlie
Old May 21, 2017 | 08:55 PM
  #260
Bob Beroza's Avatar
Bob Beroza
thanks
charlie
I had no problem at all. Without sounding stupid are you sure your pressing the button hard enough? I know it was kind of strange to get the right rhythm in press the button multiple times.
