Cheap front camera
Old Jun 8, 2016 | 09:49 AM
  #61
red 1's Avatar
red 1
Originally Posted by Bob Beroza
The question is...will it work with the other camera's WiFi box? If it does it would be great. Although for me I don't know that a reverse image is so bad. After all a curb is the same on the left as it is on the right.
I'm going to hold up on my install until l here back from you. Between all of us We Will do what Chevrolet should have from the beginning.
All of the cameras are universal
Old Jun 8, 2016 | 10:32 AM
  #62
Harry2's Avatar
Harry2
Originally Posted by zbrett
Due to the potential issues with this sealed camera (I don't mind the guidelines but I do not want the view reversed), I ordered a different one from Amazon. You can make all the adjustments outside the camera with by clicking one button.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I should have it tomorrow. Even with the cost for the additional camera, it is still a great deal compared to the other bundles out there.
Looking forward to seeing your review of the install of the new camera!
Old Jun 8, 2016 | 06:36 PM
  #63
zbrett's Avatar
zbrett
Here are a couple quick pics. The connectors for video and power are exactly the same. <br > <br > <br >
Old Jun 8, 2016 | 06:45 PM
  #64
zbrett's Avatar
zbrett
It also has some additional "programming" capabilities that I don't believe are in the Amazon product description:
Old Jun 8, 2016 | 07:20 PM
  #65
red 1's Avatar
red 1
Have you tried pressing the back side of the cable junction on the original camera, the side with an H on it and see if it changes anything, I would try the one I just got in but the wires broke when I disassembled it.
Old Jun 8, 2016 | 09:25 PM
  #66
Bob Beroza's Avatar
Bob Beroza
Okay ZBrett, i'm in.
This looks like a much better camera and it certainly has more function and REAL instructions on how to make adjustment. Since Red1 says that all cameras are universal there should be no problem with using the WiFi Box from the first camera.
ZBrett...I found the wires from the "Round" Camera to to be pretty short (23"). This limits where we can put WiFi Box. Are the wire longer on the "Square" Camera?
I ordered it. It supposed to be here on Friday...thanks to Amazon Prime.
Let us know if you get your hooked up over the weekend.
Remember the fate of all Corvette Noses rides on what we're do here...No Pressure!
Old Jun 8, 2016 | 10:04 PM
  #67
zbrett's Avatar
zbrett
The cables on both cameras are about the same length, but the E-Sky camera comes with a super long video extension cable and longer power leads. There should be enough there to get the job done.
No pressure. Ha.
Old Jun 8, 2016 | 10:15 PM
  #68
Bob Beroza's Avatar
Bob Beroza
No pressure. Ha.
Don't we have to use the Red Connector Wire to the wifi box?
Old Jun 8, 2016 | 11:39 PM
  #69
zbrett's Avatar
zbrett
Yes, and no. I'm pretty sure you could hook up the camera and wi-fi box to separate 12v sources. Might be handy if you want to put the wi-if unit in the cabin. The video extension cable that comes withe the E-Sky camera is certainly long enough.
If you need more wire for the power leads, get some shrink wrap tubing (electrical tape is so ghetto ), a solder gun, solder, the appropriate gauge of extra wire and poke around on YouTube to see how to do some proper soldering and how to use shrink wrap tubing. Pretty easy but it does take some practice.
Old Jun 8, 2016 | 11:47 PM
  #70
zbrett's Avatar
zbrett
I will try that when I have time and report back. Thanks
Old Jun 9, 2016 | 01:10 AM
  #71
Wilkmanracing's Avatar
Wilkmanracing
Is there a factory plug-in solution that would not require routing all the wiring that comes with the aftermarket solutions? If the LT-2 has this feature built in, I'm wondering if there is an existing harness with a plug for a factory camera.
Old Jun 9, 2016 | 01:57 PM
  #72
fredl11's Avatar
fredl11
Default I wonder
If the above mated with
Amazon.com: BW 3.5 Inch TFT LCD Monitor for Car / Automobile: Car Electronics Amazon.com: BW 3.5 Inch TFT LCD Monitor for Car / Automobile: Car Electronics
would mount is the cubby hole behind the screen?
Old Jun 9, 2016 | 02:54 PM
  #73
Bob Beroza's Avatar
Bob Beroza
Originally Posted by fredl11
If the above mated with Amazon.com: BW 3.5 Inch TFT LCD Monitor for Car / Automobile: Car Electronics would mount is the cubby hole behind the screen?
That would be a nice setup. I looked at it on Amazon and I don't see and leads for power to the monitor?
Old Jun 9, 2016 | 06:15 PM
  #74
zbrett's Avatar
zbrett
Power should be the red lead. Same type of connector that powers the camera. The power lead from the camera would not plug into this unit. You would need two 12V sources (one for camera, one for monitor)
Not sure what the white lead is for. Maybe for a reverse function?
Old Jun 9, 2016 | 06:23 PM
  #75
fredl11's Avatar
fredl11
Default ok maybe this?
Found on another site. Now how do we turn it off until needed? I just want it to save the nose chin on the Stingray from curb damage.
  #76
zbrett's Avatar
zbrett
So I got out my gazillion year old Radio Shack Micronta 12V power supply and powered up the wifi unit and cameras. First the camera that came with the wifi unit. The camera I got has gridlines. I pressed on the junction on the camera and it does nothing. I'm not so sure the image can be reversed on this camera.
Next the E-Sky. Does everything it says in the One Button Control instructions I posted earlier. Two sets of gridlines that are totally adjustable. Or you can turn them off. Picture reverses, etc. Everything works.
One last observation. The picture quality on both cameras is pretty much the same. No advantage to either one. I wouldn't be surprised if they both used the same image sensor.
Old Jun 9, 2016 | 06:25 PM
  #77
zbrett's Avatar
zbrett
Yeah, that would work if you don't mind running the wires into the cabin and messing around behind the dashboard. I already took my dash out once. I don't want to do it again.
To Cheap front camera
Old Jun 11, 2016 | 02:36 PM
  #78
YellowC7's Avatar
YellowC7
I ordered one of these. Hooked it up to power and it works fine, but I can't figure out where to route the wires from the grill back into the engine bay. Someone said there was a square hole they ran them through, but I can't find that. Anyone have a pic of where the wires go?
Forget it. I found it by shining a light through the grill.
The comments above about the wires being short are for sure. I honestly don't have an extra 1/2 inch of power cable between the WiFi box and the camera. Trying to get it all connected I ended up yanking the power plugs apart twice. To get them connected, I had to drop the camera behind the grill and pull the wires into the engine bay, then pull the camera back through the grill. I have a Z06 grill with big openings. With the regular grill I don't think I could have done it.
In the process of yanking on the wires multiple times, I think I shifted the camera inside the housing, because the image is now skewed when the camera is pointed straight ahead. It sill serves the purpose, but looks bad on the phone's screen.
Another issues: If the app is running when WiFi is disonnected, it freezes and has to be killed and restarted. Just reconnecting WiFi doesn't work. So you can't just leave it running. After you park your car you have to go in and kill the app, then restart it before you want to park. Sort of a pain.
And it's on whenever the car is. It won't use much power, so maybe it doesn't matter, but I don't know if it's good for the camera to be on all the time.
If I decide the software is OK, I may order the square camera above with the longer cables so I can mount the box better and reverse the image, and wire in a remote relay so I can shut if off when I'm not parking. Suddenly it's not so cheap.
Old Jun 11, 2016 | 06:39 PM
  #79
zbrett's Avatar
zbrett
You need this, or something like this...
It is the shortest one I've been able to find. It is long enough that I may move the wi-fi unit into the cabin. I was going to do it today, but it is godawful hot outside. So tomorrow....
Old Jun 12, 2016 | 01:40 PM
  #80
fredl11's Avatar
fredl11
Default Ok I placed an order
got the Esky obey butting and an WIFI Transmitter, Thinkels-Tech, 2.4Ghz wireless WIFI Camera Transmitter video receiver for Car Reverse Bakup rear view reversing CCTV Camera , Support iPhone IOS/ Android system phones
