Triple flush
Old Aug 21, 2019 | 09:59 AM
  #61
Harris's Avatar
Harris
Originally Posted by Gearhead Jim
The dealer I use will do the triple flush on any A8 Corvette simply if you ask them to do it. They way they talked, that's what the latest bulletin says.
Same with the dealer I use. They said it is a good preventative measure to change the fluid now. Going in next week for the service.
Old Aug 21, 2019 | 10:07 AM
  #62
slant6's Avatar
slant6
Are they doing it under warranty ?
Old Aug 21, 2019 | 10:34 AM
  #63
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Mine was done under warranty. Car is about 2 years old with 30k miles.
Old Aug 21, 2019 | 02:53 PM
  #64
johnny3's Avatar
johnny3
My Dealer says they will do the flush under "power train warranty (5yr/50k mile)" . No cost to me, mines a 2016 (out of 3/36 warranty. South Pointe Chev. He says transmission must be "relearned" but they would do that also.
Old Aug 21, 2019 | 03:44 PM
  #65
Harris's Avatar
Harris
Yes
Old Aug 21, 2019 | 04:25 PM
  #66
twoz28's Avatar
twoz28
Default Triple Flush
They did my 2015 Z51 for no charge 2 weeks ago 3 months from my 5 years and it is doing great so far. 43000 miles on it.
Old Aug 21, 2019 | 06:38 PM
  #67
yellow2007's Avatar
yellow2007
Well my service rep called me back today. According to GM, there is nothing wrong with my transmission and apparently copped an attitude with my service manager. I can't fault the service department. After all they did do two flushes under warranty and their hands are tied. They suggested maybe trying another dealer. The problem is GM. Not sure what my next step will be but dealer shopping is not on my list. GM is just stalling since I only have a little over a month on my warranty. The shudder isn't as bad as before the flushes so I may just bite the bullet and pay for a third myself and see.
Old Aug 23, 2019 | 07:44 AM
  #68
Ramler's Avatar
Ramler
Called my dealer in Fargo, ND and asked for his policy on SB 18-NA-355 and 19-NA-121, updated effective July 9, 2019. He called back and said bring it in tomorrow and we'll take care of it. Dropped it off at 0830 the next day. No questions asked, no diagnostics, no arguments. It took 8 hours to complete, partly because it was the first one he had done, and partly because of the extensive warming up/cooling down process required by the SB. I had not had any shuddering problems so I have nothing to compare it to but everything is fine now. Dealer told me the new fluid did not accumulate/retain moisture like the old fluid so it really needs to be changed. Power train warranty covered all costs. Makes me feel better, if nothing else.
Old Aug 23, 2019 | 10:29 AM
  #69
SLEEKVET's Avatar
SLEEKVET
I called my dealer today - made an appointment and they said they would do it under warranty. Going on the 3rd year of the B2B warranty and 11,000 miles. My appointment is 9/12 so I'll see if they give me any flack once I arrive and will update once complete.
Old Aug 23, 2019 | 12:58 PM
  #70
ZyberMunster's Avatar
ZyberMunster
Had my 2018 GS (1/4/2018 build) flushed under warranty, no arguments, no BS.
Service advisor was aware of the issue; hell, even the cashier lady knew of the new fluid! Must have had a ton of vehicles with this issue!!
Anyway, main changes I feel is in the transition from V4 to V8, it is ABSOLUTELY seamless, you cannot feel it no matter how much attention you pay to it, also, car seems to go into V4 more often than prior to flush. This was immediately after flush.
Car shifts perfectly regardless of driving setting or speeds.
Service paperwork states a triple flush was performed, they kept the car two days and test drove approximately ten miles total.
Heading up to the NCM anniversary next week so will definitively put over 200 miles on it, fingers crossed.
Old Sep 7, 2019 | 12:49 PM
  #71
fnbrowning's Avatar
fnbrowning
Originally Posted by fnbrowning
I took my beautiful girl to the dealership today looking for the triple flush. Without the July 2019 revision of the 18-NA-355 TSB, all I could do was parrot the magic words and hope for the best.
That didn't work out for me. They test drove the vehicle, claimed no shudder, and "programmed TCM with the latest calibrations, warranty claim code 18YN24490124."
I know I've been told to "find a dealer who knows how to do their job", but that's easier said then done. Now, I will have to schedule with a more distant dealer, and beg a ride from a fellow employee that will go out of their way to give me a ride back-n-forth. Without the TSB, you are at the whims of the dealer & his mechanic.
Please! Someone reading this, help us find the updated TSB!
I tried again with the same dealership, but using a different tactic. I low-rated the dealership's after service survey, and the Marketing Manager contacted me to resolve customer dissatisfaction. I carefully explained that the dealership did not work TSB 18-NA-355 according to GM documentation. She carried my concern to the Service Manager, and he said they would do the work as specified, and invited me back. When I came back, I had a screen shot of Document ID 5151948 copied off of https://gsi.ext.gm.com that was posted on another automotive site.
On Sept 6th they did the flush under "power train warranty (5yr/50k mile)" Invoice sez "TRANS FLUSH PERFORMED DOC 5181942."
In conclusion, having the GM doc to point to did help. I wish I could have said I got the doc from the Corvette Forum!
Old Sep 8, 2019 | 09:03 AM
  #72
slant6's Avatar
slant6
Which site did you find it?
Old Sep 8, 2019 | 09:07 AM
  #73
Borntorun04/17's Avatar
Borntorun04/17
Your link doesn’t work can you show document .
Old Sep 8, 2019 | 09:48 AM
  #74
Elk's Avatar
Elk
If you post the document the rest of us can say we got the doc from the Corvette Forum!
Old Sep 8, 2019 | 10:11 AM
  #75
slant6's Avatar
slant6
:lol!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 8, 2019 | 10:29 AM
  #76
MMD's Avatar
MMD
PDF of TSB 18-NA-355 (dtd May 5,-2019) - last update
https://www.corvetteforum.com/forums...5-may-2019.pdf
Old Sep 8, 2019 | 10:36 AM
  #77
slant6's Avatar
slant6
We are all looking for the updated bulletin dated 7/9/19 that states no tests are required, just customer request.
To Triple flush
Old Sep 8, 2019 | 11:06 AM
  #78
MMD's Avatar
MMD
From what I have read the TSB 19-NA-121 (dtd July 9, 2019) you refer does 2 things. 1) Eliminates the Pico vibration test requirement, and 2) Adjusts dealer labor warranty charge-back billing because less time is required to perform the triple flush as the Pico test is no longer performed. The later TSB is more of an administrative change than a service/engineering change. The PDF link I cited earlier is still the most current in regards to the equipment necessary to perform the flush and other service requirements. Corvette is not the only GM model that incorporates the A8 transmission in their GM lineup. So the TSB also discusses all these other vehicles as well as any special considerations for each vehicle model.
Old Sep 8, 2019 | 12:15 PM
  #79
Elk's Avatar
Elk
Your summary is helpful, and accurate, but we are all hoping to get a copy of the TSB 19-NA-121. It apparently is as hard to find as the Loch Ness monster.
Old Sep 8, 2019 | 12:39 PM
  #80
MMD's Avatar
MMD
Why? It's not relevant. If anyone is considering this service all you have to refer do is your dealer to both of these TSBs. The older tells the dealer what the service issues are and how to perform the required service. The new TSB just tells the dealer what the dealer can charge back to GM. This is what I had done to my vehicle 2 days ago. Most, if not all, Chevy dealers are well aware of the issues associated with the A8. When I first called my dealer to get this service I had mentioned these TSBs and my service advisor indicated they were well aware of these TSBs and the service required. They had performed this service a few hundred times.
