I was eyeing that too but read somewhere the bezzel does not fit like the stock one causing vibrations, anyone using this **** can confirm that?
I will soon found out. I just ordered today. I am also getting the TMOD lower box. I've already taken off the center console, boot and shifter like 3 months ago to do the recommended alignment with the stock shifter. It's not hard. We will see after I receive and install everything how it works out.
Southern said they are 4 to 5 weeks out. They are out of stock. So I went with RPI. Hopefully they aren't out of stock.
Thanks. I just sent them an email to find out why I didn't have it. Keep us posted if RPI ships it this week. I may cancel and reorder from them. The custom stuff is unpredictable.
I am a fan of the MGW , I've used it in the last 4 Corvettes. In the most recent which has the T56 transmission I also did the Anti Venom mod. Another item I added this time was the MGW race ****. I really like this combination. I may try the fluid change next.
can you buy the weighted **** only ? Who makes that ****?
EPCO, they make all forms of custom *****. I went through 4 before settling in my current. I can’t recommend the flat stick with weighted **** enough! Each gear is like a well lubed rifle bolt!!! https://epcomfg.com/shift-*****/
Can you please recommend the ball type **** you use , i love the stock shifter and just looking for a custom **** that would lower the stock height which may make the shifter more direct.
I'm using the RPI **** as mentioned by others here as well.
Hi, new to the corvette, very awesome car. I have a 2019 Stingray M7. Would like some info on what short throw shifter you all suggest. I am looking for just the shifter shaft (stick) not the whole assembly. I know little about the products or quality brands out there for the corvette. I'll do the installation, so the easier the better. Appreciate your help. I have searched but want firsthand feedback.
Hmm, can't "just replace the stick!" Reminds me of my 3 on the Tree '50 Ford where you grabbed the shift lever at the column!
I, like others, love my MGW shifter. I have the flat stick version. It has much better bushings where the rod that goes back to the trans is controlled. Not as simple as changing the **** that helps shorten a little, but I had some issues with it so installed the MGW..
Here is a PDF of my install on the M7 in my GS. It also quotes and gives links to their video's. But you'll find my picture PDF points out some not so obvious install issues:http://netwelding.com/MGW_Shifter.pdf
My Combo as well. Absolutely the best mod for this car. Love it!
