C7 fast list!
http://www.famosoraceway.com/schedule.htm
Owner: Scott Brown
Year of the C7: 2014
Tires used on the pass: Hoosiers
Performance Mods (if any): Z51, 6L80E, Twin Turbo, Direct Port Nitrous, Mild Stroker.
Category submitted for: Power Adders
60'.............
330'...........
660'...........
660’ mph...
1000'..........
1320'..........
1320’ mph…159.4mph
2640' mph..193.4mph
5280' mph..238.4mph
Name of the track: Front Range Airport, Colorado
Date of pass: 9/9/17 & 9/10/17
Weather conditions: (include Density Altitude, if known): 8555' on 9/9 and 8392' on 9/10. Cross to head winds.
Power Adder- 416, YSI, Full Exhaust, LT4 Fuel System, CPR Low Side, Dual Methanol, 325/50/15 Street R, etc
Year of the C7:
60'............. 1.328
330'........... 3.878
660'........... 5.966
660’ mph... 119.02
1000'..........
1320'.......... 9.162
1320’ mph… 150.1
Name of the track: Ozark Raceway Park
Date of pass: 10-29-2017
Weather conditions: (include Density Altitude, if known): 1800ft DA
Year of the C7:
660’ mph... 119.02
1000'..........
1320’ mph… 150.1
Tires used on the pass: ET Street S/S 325/30-19, OEM fronts
Performance Mods (if any): Pray Performance Ported OEM IM, Pray Performance Ported OEM TB, Halltech CAI, Pray Performance Flex Fuel tune on E85, ARH 2" Longtubes w/ 3" catted X-pipe
Category submitted for:Boltons with no Internal Modifications
60'............. 1.587
330'........... 4,572
660'........... 7.017
660’ mph... 101.12
1000'.......... 9.128
1320'.......... 10.924
1320’ mph… 125.58
Name of the track: Rockingham, NC Dragway
Date of pass: 11/11/17
Weather conditions: (include Density Altitude, if known): -800ft DA
Image of complete Time Slip:
Tires used on the pass: Stock 34psi front, 26psi rear
Performance Mods (if any): None
Category submitted for: Bone stock on stock tires
60'.............1.709
330'...........4.914
660'...........7.512
660’ mph...95.11
1000'..........9.736
1320'..........11.626
1320’ mph…119.08
Name of the track: No Problem Raceway
Date of pass: 11/10/17
Weather conditions: (include Density Altitude, if known): -500
I copied and pasted from Rangers thread in the C6 Z06 section. Wasnt much I had to modify to apply to the C7. I'll do my best to update as often as possible as the posts come in.
Here are the copied rules....
The Fast List, found at the end of Post #1 of this thread, is open for additions as submissions are received and validated.
The Fast List has five sub-lists.
Bone-Stock on Stock Tires. This means completely stock with no performance changes whatsoever; stock exhaust, stock airpath, stock “untuned” and ""never-tuned" computer (ECU/PCM), etc.
Bone-Stock, except Non-Stock Tires including drag radials. Otherwise, the same requirement as above.
Bolt-Ons without Internal Engine Modification (e.g. modified air-path, headers, PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires)
Internal Engine Mods plus Bolt-Ons (e.g. stock displacement with bolt-ons plus heads and/or cam)
Power Adders (Nitrous, Turbo, Supercharger) and Non-Stock Displacement
Rules:
In proposing submissions for inclusion on the list, please follow these simple rules
Rule #1. Post the details of your quarter-mile pass using this template:
Note: your submission won't be acted upon unless it is in the format below. This requirement applies to each new Personal Best.
Year of the C7:
60'.............
330'...........
660'...........
660’ mph...
1000'..........
1320'..........
1320’ mph…
Name of the track:
Date of pass:
Link to Video:
Rule #2. Times that may qualify for the top-20 in each category require posting of an image of the complete time slip. If you lack the ability to post an image, contact me via PM, and I will help you. Edit for Clarification (Sep 3 2007): "time slip" means full time slip. Must include date/time of the pass and customarily includes identification of the track issuing the slip. Image should be in the vertical orientation and the numbers must be legible. Edit for Clarification (Jan 10 2011) A time slip is encouraged for all submissions as a means of improving documentation of accomplishments and increasing credibility of the Fast List.
Rule #3. Track times will not be corrected for weather or track altitude. Those elements can be noted in the comment portion of the submission to clarify the conditions under which the run was made. If interest merits, we can include a single category for fast times at tracks with altitudes, say, above 3000’ for the official track elevation. Please let us know if there is interest in such a category.
Rule #4. All members are invited to submit his/her times on this thread. The top 50 or so for each category will be included in the Fast List. Only one pass per member per car-model per category will be included on the Fast List.
Rule #5. In the event two members submit a 1320’ ET identical to the thousandth of a second, the tiebreaker is the higher 1320’ mph.
Rule #6. (Oct 20 2010): Stating explicitly a rule applied to all submissions since the Fast List's inception, in order for your track results to be included on it, they must be plausible, probable and credible. The time slip must match the capabilities of the car.
Clarification (Oct 20 2010): A car with a tuned (modified file) PCM or a non-OEM PCM is not eligible for either of the two stock classes thereafter. This means once tuned, always tuned.
The C7 Fast List
Last Updated: July 20, 2016
Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details
1~~~~11.372~~119.94~~1.623~wfarmer.z~~~~'14 A6 Z51 (Post#275)
2~~~~11.377~~122.91~~1.71~brent eb02~~~~'15 A8 2Lt (Post#212)
3~~~~11.496~~118.96~~1.683~SNORMAN~~~~'14 A6 (Post#4)
4~~~~11.524~~119.52~~1.685~10mm~~~~~~~'15 A8 Z51 (Post#439)
5~~~~11.585~~120.08~~1.716~VNAMVET~~~~'14 A6 Z51 NPP (Post#21)
6~~~~11.630~~118.76~~1.718~Old Goat~~~~~'14 A8 Z51 NPP (Post#578)
7~~~~11.743~~119.05~~1.745~jrwood~~~~~~'14 A6 non-z51, with NPP, Used launch control (Post# 84)
8~~~~11.813~~118.09~~1.760~only9balls~~~~'16 A8 Z51, 91 Octane (Post#588)
9~~~~11.823~~119.22~~1.845~pettevette~~~~'15 A8 ZF1, NPP, 2.41 Gears (Post#531)
10~~~~11.889~~118.31~~1.795~Fore58~~~~~~'14 A6 Non Z51 Convertible (Post#254)
11~~~~11.924~~119.59~~1.836~jacksnorm~~~~'15 A8 1LT (Post#504)
12~~~~11.947~~117.17~~1.806~The Rock1~~~~'14 A6 Z51, 2LT, no NPP (Post#364)
13~~~~11.955~~119.62~~1.919~Kyle Lemish~~~~'14 M7 non Z51 and no NPP (Post#13)
14~~~~12.074~~116.79~~1.928~jb306y~~~~~~'14 M7 Non-Z51, M7, NPP, launch control (Post# 85)
15~~~~12.077~~116.46~~1.869~bigsapper~~~~'16 A8 non Z51, NPP, Launch Control (Post#636)
15~~~~12.164~~116.31~~1.938~Greg Quillen~~~'14 M7 Z51, Has NPP (Post#15)
16~~~~12.217~~116.88~~1.978~nfcooper~~~~~'14 A6 Z51 MR NPP Track sport2, launch off idle
17~~~~12.573~~112.73~~1.996~Baron7700~~~~'14 M7 Z51 NPP stock tire psi. Track mode, full traction on.
Bone-Stock except Non-Stock Tires
1~~~~11.311~~121.21~~1.647~wfarmer.z~~~~'14 A6 Z51 with MT drag radials (Post#218)
2~~~~11.719~~119.38~~1.731~robe38~~~~~~'14 M7 Z51 with NPP 315/30/18 Hoosier Drag Radials (Post#52)
3~~~~11.724~~119.52~~1.775~Kyle Lemish~~~'14 M7 MT ET Streets, non Z51 and no NPP (Post#13)
4~~~~11.745~~116.39~~1.675~TonyC@RLMS~~'14 M7 Z51, 345/35/18 MT on ccw 18" wheels (Post#37)
1~~~~10.89~~124.79~~1.57~Ls2000~~~~~~~~~~~~14 A6 TSP headers, AFE intake, tune, E85, CCW's front 17-4, rear 275-40-17 MT (Post#572)
2~~~~11.04~~125.24~~1.59~jacksnorm~~~~~~~~~~15 A8 ARH LT, 3" catted x, HPA Tune, AFE CAI, E85, Nitto NT555R 305/18's & Weld 17" Skinnies(Post#547)
3~~~~11.16~~124.38~~1.70~Cajun@BER~~~~~~~~~15 A8 TSP headers, AFE CAI, BER ported intake/TB, BER tune, NT05R (Post#597)
4~~~~11.17~~126.92~~1.30~Zmoy2~~~~~~~~~~~~14 M7 ARH headers, e85 tune, BF Goodrich drag radials (Post#593)
5~~~~11.19~~123.56~~1.76~yonks8365~~~~~~~~~15 A8 NT05 drag radials, Cai, E85 (Post#553)
6~~~~11.21~~123.75~~1.72~10mm~~~~~~~~~~~~15 A8 Z51 ARH Midlength, AFE CAI, Tune (Post#542)
7~~~~11.32~~120.78~~1.63~wfarmer.z~~~~~~~~~~14 A6 Z51 K&N filter, 4 1/2 inch Weld wheels, NO TUNE (Post#292)
8~~~~11.33~~122.28~~1.62~Complete Street~~~~~~14 M7 NPP, Kooks 7/8, Tune, Catless, MT Radials (Post#482)
9~~~~11.47~~119.32~~1.68~TuneTimePerformance~~~14 M7 ARH/Tune/Z51/NPP
10~~~~11.57~~121.78~~1.82~JJFormato~~~~~~~~~~14 M7 Z51 Modified airbox, ported manifold & TB, Formato tuned. Hoosiers W/C5Z wheels(Post#94)
11~~~~11.67~~120.01~~1.74~~~JB~~~~~~~~~~~~14 M7 ARH, Modified airbox, ported intake manifold & TB, Formato tuned MT drags on C5Z (Post#74)
1~~~~10.573~~129.34~1.520~Ben@WeaponX~`'14 A6 427, 3400 converter, M&H 325's (Post#541)
2~~~~10.667~~127.39~1.527~LMR~~~~~~~'14 A6) Heads/Cam
3~~~~11.392~~123.29~1.911~ChucksTuning~'14 M7 VVT cam/AFM delete, Kooks 2" headers, 3" B&B PRT, Halltech stinger. (Post#120)
4~~~~11.672~~126.19~1.975~Mike@NewEra~ '14 M7 stock tires, NEP VVT Cam, ARH mid length headers, NEP exhaust D/A +2000 (Post#114)
Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr Details
1~~~9.48~~156.57~~1.611~LMR~~~~~~~~~ '14 M7) Twin Turbo (Post#250)
2~~~9.72~~137.55~~1.358~LS2000~~~~~~~~'14 A6 200 Shot, TSP Headers, AFE intake, E85, CCW skinnys and 275-40-17 MT
3~~~9.74~~145.94~~1.563~JTMMotorsports~~'15 A8 ARH 1 7/8" no cats, NPP, ECS 1500, 3.75 pulley 13.5#'s, Alky kit, JTM Cam, E85, 315/35/18 M/T DR's (Post#457)
4~~~9.95~~138.20~~~1.544~Dave01GT~~~~~~'15 A8 305/35/19 Mickey's A&A Blower, Small Cam/DoD delete, Long Tubes, Meth (Post#530)
5~~~9.96~~141.22~~~1.644~Pete@ChampionMotors '15 A8 Z51 A&A YSi, Champion Cam, ARH Headers, MT 18'DR (Post#526)
6~~~9.99~~132.7x~~~1.403~LMR~~~~~~~~~~'14 A6) Heads/Cam/150shot
7~~~10.00~139.85~~~1.541~brent eb02~~~~~~'15 A8 Ecs 1500 meth and Texas speed headers mt 315's (Post#591)
8~~~10.03~146.67~~~1.763~stangkilrproductions '14 M7 Stock LT4, Procharger F1a 14lbs, Cam, DYAD clutch, ignite e90 and meth, Cordes Tune (Post#582)
9~~~10.13~138.97~1.441~Ben@WeaponX~~~~'14 A6 427, NOS, 3400 converter, M&H 325's (Post#181)
10~~~10.18~131.23~1.434~Jimsgn~~~~~~~~~'14 A6 Z51, 417CI, LME Heads, ECS 1500,10psi, LS7 Lifters, BTR Springs, C5R Chain, Alky Meth, 3500 Stall, ARH 7/8, Catless M&H 275/45/18(Post#149)
11~~~10.17~140.56~1.610~Complete Street~~~'14 M7 A&A YSI Kit 10psi slipping belt, Meth, Kooks Headers, MT 285/35/18 (Post#537)
12~~~10.19~140.33~1.611~RyneZ06~~~~~~~'14 A6 Cam, Procharger P1 10lbs, ARH LT, Alky meth, Cms tuning, Hoosier drag radial (Post#304)
13~~~10.20~144.03~1.669~Vengeance Racing '14 M7 ECS blower, 14psi, Alky meth,VR Cam, ARH 1 7/8 W/CATTED X pipe Toyo 888R 315/35/20 (Post71)
14~~~10.25~140.33~1.640~JJFormato~~~~~~'14 M7 A&A Supercharger 6.5 psi, Fasterproms Heads/Cam, 93 Octane (Post#269)
15~~~10.33~136.93~1.671~c6switchblade~~~~'14 M7 ECS 2200sl, 2" ARH, Alky single nozzle 265/18 MT ET Streets (Post#486)
16~~~10.39~131.48~1.419~C7LT1~~~~~~~~~'14 A6 Tune, Converter, 150 shot m/t 19's. (Post#64)
17~~~10.56~131.35~1.633~kakashi~~~~~~~~'14 A6 A&A Supercharger, TSP LT headers, Alky Meth 9psi Hoosier 315/30/18, (Post#456)
18~~~10.57~129.96~1.554~Dameian~~~~~~~'14 A6 Z51, Pfadt Kit 8psi, ARH, 18" Forgeline Drag pack with 325/40/18 M&H Radials (Post#104)
19~~~10.61~132.13~1.713~Melgotboost~~~~~'14 A6 Non NPP, Tires stock, stock tire pressure, ECS Novi1500 ARH, Alky meth (Post#348)
20~~~10.64~135.13~1.849~FRANS96SS~~~~~'14 M7 Headers/Tune/150shot
21~~~10.73~132.90~1.813~"BoneStock"~~~~~'14 M7 20's with 315 r888s. ECS kit with restrictor removed, TSP Headers, meth (Post#459)
22~~~10.83~131.02~1.666~2highpsi~~~~~~~'15 A8 Z51 Magnuson Heartbeat, LT4 pump/injectors ET Street S/S 285-40-18 (Post#640)
23~~~10.84~130.55~1.716~10mm~~~~~~~~~'15 A8 Z51 Midlength Headers, AFE CAI, 100 shot (Post#514)
24~~~10.93~127.55~1.675~MIGHTYM0USE~~~'14 M7 A/A base kit, AFE headers, Meth, Tune, 305 19" NT05R (Post#498)
25~~~11.06~134.78~1.974~jsb08Z~~~~~~~~'14 M7 Z51 ECS supercharger 12psi, ARH headers, Meth, LMR breather kit (Post#159)
26~~~11.19~129.98~1.862~Greg Quillen~~~~~'14 M7 Z51, NPP, ECS Supercharger, ARH Headers, Pilot Super Sports (Post#157)
27~~~11.69~122.85~1.794~blue_bomber697~~'14 M7 Z51 ECS Supercharger, American Racing headers and X-Pipe (Post#629)
28~~~
Post em up!
Tires used on the pass: M/T 285/35/19
Performance Mods (if any): NONE
Category submitted for: Stock No Tune with Tires
60'............. 1.739
330'........... 4.972
660'........... 7.608
660’ mph... 94.08
1000'.......... 9.862
1320'.......... 11758
1320’ mph… 118.84
Name of the track: California speedway Fontana
Date of pass: 11/19/2017
Weather conditions: (include Density Altitude, if known): 1100'
Link to Video:
Post one doesn't have a single stock GS, I know the extra weight hurts but the extra rear grip helps compensate.
As maybe a point of reference, my GS A8 went 12.20@115mph in +3500ft DA 97 degrees bone stock.
Has been 10.92 so far @ 125.6 with boltons
Tires used on the pass: Forgestar F14 Drag Pack 18x5f w/ MT Sportsman SR 26x6, 18x12r w/ MT ET Street S/S 305/35-18
Performance Mods (if any): Pray Performance Ported OEM IM/TB, Halltech CAI, Pray Performance Flex Fuel tune on E85, ARH 2" Longtubes w/ 3" catted X-pipe
60'............. 1.558
330'........... 4,514
660'........... 6.946
660’ mph... 100.04
1000'..........
1320'.......... 10.851
1320’ mph… 123.22
Name of the track: Fayetteville Motorsports Park
Date of pass: 12/10/17
660’ mph... 100.04
1000'..........
1320’ mph… 123.22
