C7 fast list!
Old Mar 22, 2018 | 03:27 PM
  #781
robz's Avatar
robz
Originally Posted by Artem
I'm thinking to switch tires to Hoosier DR2 315/30/18 and go for 11.5s or maybe even 11.4s. But I can't really complain with 11.61 on bone stock stick shift car.
I'd rather see you go with a smaller, lighter, shorter tire.
The Hoosier 245 dr should do the trick.
Old Mar 22, 2018 | 03:48 PM
  #782
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I wish Tune Time would update the original list and stick with it..
Old Mar 22, 2018 | 04:07 PM
  #783
Seannyc's Avatar
Seannyc
11.6 pretty much confirms the Manual ain’t slower just all about the launch 60ft
Old Mar 22, 2018 | 11:10 PM
  #784
Fore58's Avatar
Fore58
Very nice run with your manual. You really need the necessary skills in order to obtain a decent 60 feet with the manual. Now it appears that you have the quickest manual with drag radials. Just a reminder. .....the quickest auto on the list is 11.31 with drag radiails. I don't believe that anyone came close to your time at Bradenton. Again ...good job.
Old Mar 23, 2018 | 12:25 AM
  #785
Artem's Avatar
Artem
I don’t think Hoosier DR2 245/40/18 will be good fit for my 18x10.5 wheel. 315/30/18 will be much better fit. And they are both 26” tire. I run 27” Mickey Thompson tire right now so 26” should definitely help.
Thank you! We also need to remember that 11.31 run was done with -1450 DA, 39F weather and 42% humidity while my run was done in -50 DA, 59F and 67% humidity.
Old Mar 23, 2018 | 11:15 AM
  #786
Fore58's Avatar
Fore58
i am familiar with that type of DA up north. I have used the same tracks back in my days. We won't get that here.....😄👍
Old Mar 26, 2018 | 09:35 AM
  #787
robz's Avatar
robz
A 27" is too much tire like you said. The small light tire is all on you need and will run quicker and faster.
Maybe you can borrow rims. You can get the 245 to fit the 10.5 and it will be 25" tall then which would be great but I wouldn't recommend it to someone if I hadn't tested it for safety first, although I bet it would be fine. Even a bias ply would work well in 17. Just not a fan of big dr. with stock power and clutch.
The 315 can work but it's too much tire and will put more strain on clutch and parts.
Old Mar 26, 2018 | 12:16 PM
  #788
Artem's Avatar
Artem
No way I’m stretching tires... So 245 is out of the question. Why do you say 315/30/18 will put more strain? I’m gonna have to slip the clutch no matter what on drag radials. If I could fit bias ply I’d just let it eat and launch her at 6000rpm.
Old Mar 27, 2018 | 12:49 AM
  #789
prmacho's Avatar
prmacho
Default Time slip/ power adder list no internal modification
Year of the C7: 2014
Tires used on the pass: M&H Racemasters 28/10.5-15 and 17x4.5 skinnies
Performance Mods (if any): lt4 supercharger on 7psi(2.9 blower pulley) Afe CAI, Alky Meth Kit, LG longtube headers and XPipe, flex fuel sensor(e50) LT4 injectors, LT4 HPFP, 160degrees thermostat, and New Era tune
Category submitted for: Power adder no internal mods
60'............. 1.465
330'........... 4.267
660'........... 6.583
660’ mph... 107.21
1000'.......... 8.582
1320'.......... 10.249
1320’ mph… 134.83
Name of the track: Famoso Raceway California
Date of pass: 03/25/2018
Weather conditions: (include Density Altitude, if known): 57.9 degrees and 533 density altitude and 625 feet above sea level
Image of complete Time
Old Mar 27, 2018 | 02:40 AM
  #790
Seannyc's Avatar
Seannyc
660’ mph... 107.21
1320’ mph… 134.83
great run did u need the meth to run E85 or u coulda run it with out it what ru making to the wheels wit the set up
Old Mar 27, 2018 | 08:59 AM
  #791
robz's Avatar
robz
...because it's too much tire for your setup. Slipping the clutch is wearing out the clutch which can save you at times and work but too much will glaze and cause a penalty downtrack.
You could borrow my tires and rims anytime (245 dr on stock c6z fronts) to try out if you are ever in the area. I ran them @ 25 psi so if you get the 315 I'd suggest much higher psi than normal and short quick burnouts.
A 17 in bias ply would be the most fun and you have skinnies already?
Old Mar 27, 2018 | 11:26 AM
  #792
tjdowdell's Avatar
tjdowdell
Originally Posted by wfarmer.z
Thanks , we are very pleased with how the car running, the cool weather has really made a difference..
what specs for the M/t radials did you go with? I know our z51s have big brakes so i just want to look for the right ones that will fit. or at least part # from them? =)
Old Mar 27, 2018 | 12:04 PM
  #793
prmacho's Avatar
prmacho
thank you. We use the meth to help keep the blower cool since it’s hooked up to the CAI and travels through the blower. I could run it without but with no icebox or cooling mods this works great for me. The car made 578whp and 560ftlbs of torque on 7psi of boost. We are super conservative with the amount of boost because we all know the LT1 pistons and rings are like glass.
Old Mar 27, 2018 | 01:01 PM
  #794
Seannyc's Avatar
Seannyc
thats a sick run on 7 pounds psi I’m doin same set up Lt4 blower on stingray but I’m gonna have 10 psi no meth lookin to hit 9’s
Old Mar 30, 2018 | 01:06 PM
  #795
robz's Avatar
robz
Here's a Hoosier 8.5 x 26 x 15" on a 10.5" rim.
View My Video
Old Mar 30, 2018 | 02:27 PM
  #796
Poppacapp's Avatar
Poppacapp
View My Video
Rob! Take over updating this list mang!
Old Mar 30, 2018 | 03:39 PM
  #797
Artem's Avatar
Artem
View My Video
For some reason I cant see that video
To C7 fast list!
Old Jun 11, 2018 | 02:08 PM
  #798
TheJohnny's Avatar
TheJohnny
5th Gear
Year of the C7: 2017
Tires used on the pass: Stock
Performance Mods (if any): ALL STOCK
Category submitted for: C7 STINGRAY 3LT NPP ALL STOCK Automatic. (Left on the brake, NO Launch Control)
60'............. 1.921
330'........... 5.379
660'........... 8.175
660’ mph... 88.08
1320'..........12.578
1320’ mph… 111.38
Name of the track: Las Vegas Motor Speedway
Date of pass: 6/8/2018
Weather conditions: (include Density Altitude, if known): Hot as F*#$. Density Altitude was est: around 4900 (something close to that as I can't recall sorry).
Image of complete Time Slip:
Link to Video: HERE IS LINK TO YOUTUBE VIDEO: My Run at 3:39 into video
Old Jun 13, 2018 | 02:33 AM
  #799
renanmendes's Avatar
renanmendes
660’ mph... 88.08
1320’ mph… 111.38
Vegas weather is terrible. When my stingray was stock my best out here was 12.2 .
Old Aug 9, 2018 | 11:39 PM
  #800
Dave01GT's Avatar
Dave01GT
Originally Posted by ShaneFap
Year of the C7: 2015 C7 Z A8
Tires used on the pass: 18" ET street R
Performance Mods (if any): Stock Pulleys, AFE CAI, ARH headers, Tune, 18" DR, flex fuel (E40 used)
Category submitted for: C7Z 3LZ ZO7
60'............. 1.54
330'........... 4.4
660'........... 6.7
660’ mph... 105.0
1320'..........10.469
1320’ mph… 131.13
Name of the track: Gateway motorsports park
Date of pass: 8/8/2018
Weather conditions: (include Density Altitude, if known): 2360
https://www.youtube.com/watch?v=moA_jaBUWng
This list hasn't been updated in years. Welcome Shane
