C7 fast list!
Old Sep 10, 2018 | 08:34 PM
  #801
65fastback's Avatar
65fastback
Well I took out my M7 base stingray for its first time to the track ( test n tune ).... definitely not "fast" but i didn't embarrass myself.
100% stock other than z06 repop wheels no npp
Woodburn drag strip in oregon.... mid to upper 70's dont know the DA but definitely NOT minus - conditions prolly 1000 +
Next to impossible to 60 ft one of these cars on OEM run flat tires. but i had to give it a shot. I either left to soft with a slight bog or spun wile feathering the clutch. Id never think to bracket race a stock M7.
Old Oct 19, 2018 | 05:47 PM
  #802
Tswillie's Avatar
Tswillie
Cruising
Default is List Maintained?
Originally Posted by C2367
26psi rear, 45 psi front, Sport mode, slam it from dead idle, open hood between runs to reduce heat soak and let cool off for close to a hour. Best 1/4 run 11.731 at Fontana California speedway @ 1100' elevation and is up hill for the first 1/8 mile.
Hello All, I was under the impression the Top 50 times would be consolidated in a list or a spreadsheet. Does such an animal exist in the wild?
Thanks,
Tswillie
Old Oct 20, 2018 | 09:39 PM
  #803
only9balls's Avatar
only9balls
Thanks,
Tswillie
Check out the first post on this thread for the lists.
Old Oct 21, 2018 | 12:22 PM
  #804
zohhhsix's Avatar
zohhhsix
Default 2015 C7 Z06 track time
Year of the C7: 2015 Z06
Tires used on the pass: MT DRs
Performance Mods (if any): F1-R procharger, ported heads, Can, headers and exhaust
Category submitted for: Power adders supercharged
60'............. 1.338
330'........... 4.059
660'........... 6.192
660’ mph..... 116.41
1000'.......... 8.013
1/4 mile 9.585
MPH. 141.67
Name of the track: MIR
Date of pass: 10/18/18
Weather condition
was 52 degrees by this run.
Image of complete Time Slip:
Old Oct 21, 2018 | 05:04 PM
  #805
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Unfortunately, the last update to the first post was over two years ago.
If you really care, you can slog through all the individual posts made since that last update and see what's new.
Old Oct 21, 2018 | 05:14 PM
  #806
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
1/4 mile 9.585
MPH. 141.67
Weather condition
What transmission?
Old Oct 21, 2018 | 06:33 PM
  #807
zohhhsix's Avatar
zohhhsix
Originally Posted by FYREANT
What transmission?
Auto
Old Oct 28, 2018 | 07:51 PM
  #808
jsdweck's Avatar
jsdweck
3rd Gear
Originally Posted by TuneTimePerformance
Haven't seen one yet and with the C7's going faster and faster I figured it was time to start up a Fast list.
I copied and pasted from Rangers thread in the C6 Z06 section. Wasnt much I had to modify to apply to the C7. I'll do my best to update as often as possible as the posts come in.
Here are the copied rules....
The Fast List, found at the end of Post #1 of this thread, is open for additions as submissions are received and validated.
The Fast List has five sub-lists.
Bone-Stock on Stock Tires. This means completely stock with no performance changes whatsoever; stock exhaust, stock airpath, stock “untuned” and ""never-tuned" computer (ECU/PCM), etc.
Bone-Stock, except Non-Stock Tires including drag radials. Otherwise, the same requirement as above.
Bolt-Ons without Internal Engine Modification (e.g. modified air-path, headers, PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires)
Internal Engine Mods plus Bolt-Ons (e.g. stock displacement with bolt-ons plus heads and/or cam)
Power Adders (Nitrous, Turbo, Supercharger) and Non-Stock Displacement
Rules:
In proposing submissions for inclusion on the list, please follow these simple rules
Rule #1. Post the details of your quarter-mile pass using this template:
Note: your submission won't be acted upon unless it is in the format below. This requirement applies to each new Personal Best.
Year of the C7:
60'.............
330'...........
660'...........
660’ mph...
1000'..........
1320'..........
1320’ mph…
Name of the track:
Date of pass:
Weather conditions: (include Density Altitude, if known):
Link to Video:
Rule #2. Times that may qualify for the top-20 in each category require posting of an image of the complete time slip. If you lack the ability to post an image, contact me via PM, and I will help you. Edit for Clarification (Sep 3 2007): "time slip" means full time slip. Must include date/time of the pass and customarily includes identification of the track issuing the slip. Image should be in the vertical orientation and the numbers must be legible. Edit for Clarification (Jan 10 2011) A time slip is encouraged for all submissions as a means of improving documentation of accomplishments and increasing credibility of the Fast List.
Rule #3. Track times will not be corrected for weather or track altitude. Those elements can be noted in the comment portion of the submission to clarify the conditions under which the run was made. If interest merits, we can include a single category for fast times at tracks with altitudes, say, above 3000’ for the official track elevation. Please let us know if there is interest in such a category.
Rule #4. All members are invited to submit his/her times on this thread. The top 50 or so for each category will be included in the Fast List. Only one pass per member per car-model per category will be included on the Fast List.
Rule #5. In the event two members submit a 1320’ ET identical to the thousandth of a second, the tiebreaker is the higher 1320’ mph.
Rule #6. (Oct 20 2010): Stating explicitly a rule applied to all submissions since the Fast List's inception, in order for your track results to be included on it, they must be plausible, probable and credible. The time slip must match the capabilities of the car.
Clarification (Oct 20 2010): A car with a tuned (modified file) PCM or a non-OEM PCM is not eligible for either of the two stock classes thereafter. This means once tuned, always tuned.
The C7 Fast List
Last Updated: July 20, 2016
Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details
1~~~~11.372~~119.94~~1.623~wfarmer.z~~~~'14 A6 Z51 (Post#275)
2~~~~11.377~~122.91~~1.71~brent eb02~~~~'15 A8 2Lt (Post#212)
3~~~~11.496~~118.96~~1.683~SNORMAN~~~~'14 A6 (Post#4)
4~~~~11.524~~119.52~~1.685~10mm~~~~~~~'15 A8 Z51 (Post#439)
5~~~~11.585~~120.08~~1.716~VNAMVET~~~~'14 A6 Z51 NPP (Post#21)
6~~~~11.630~~118.76~~1.718~Old Goat~~~~~'14 A8 Z51 NPP (Post#578)
7~~~~11.743~~119.05~~1.745~jrwood~~~~~~'14 A6 non-z51, with NPP, Used launch control (Post# 84)
8~~~~11.813~~118.09~~1.760~only9balls~~~~'16 A8 Z51, 91 Octane (Post#588)
9~~~~11.823~~119.22~~1.845~pettevette~~~~'15 A8 ZF1, NPP, 2.41 Gears (Post#531)
10~~~~11.889~~118.31~~1.795~Fore58~~~~~~'14 A6 Non Z51 Convertible (Post#254)
11~~~~11.924~~119.59~~1.836~jacksnorm~~~~'15 A8 1LT (Post#504)
12~~~~11.947~~117.17~~1.806~The Rock1~~~~'14 A6 Z51, 2LT, no NPP (Post#364)
13~~~~11.955~~119.62~~1.919~Kyle Lemish~~~~'14 M7 non Z51 and no NPP (Post#13)
14~~~~12.074~~116.79~~1.928~jb306y~~~~~~'14 M7 Non-Z51, M7, NPP, launch control (Post# 85)
15~~~~12.077~~116.46~~1.869~bigsapper~~~~'16 A8 non Z51, NPP, Launch Control (Post#636)
15~~~~12.164~~116.31~~1.938~Greg Quillen~~~'14 M7 Z51, Has NPP (Post#15)
16~~~~12.217~~116.88~~1.978~nfcooper~~~~~'14 A6 Z51 MR NPP Track sport2, launch off idle
17~~~~12.573~~112.73~~1.996~Baron7700~~~~'14 M7 Z51 NPP stock tire psi. Track mode, full traction on.
Bone-Stock except Non-Stock Tires
1~~~~11.311~~121.21~~1.647~wfarmer.z~~~~'14 A6 Z51 with MT drag radials (Post#218)
2~~~~11.719~~119.38~~1.731~robe38~~~~~~'14 M7 Z51 with NPP 315/30/18 Hoosier Drag Radials (Post#52)
3~~~~11.724~~119.52~~1.775~Kyle Lemish~~~'14 M7 MT ET Streets, non Z51 and no NPP (Post#13)
4~~~~11.745~~116.39~~1.675~TonyC@RLMS~~'14 M7 Z51, 345/35/18 MT on ccw 18" wheels (Post#37)
1~~~~10.89~~124.79~~1.57~Ls2000~~~~~~~~~~~~14 A6 TSP headers, AFE intake, tune, E85, CCW's front 17-4, rear 275-40-17 MT (Post#572)
2~~~~11.04~~125.24~~1.59~jacksnorm~~~~~~~~~~15 A8 ARH LT, 3" catted x, HPA Tune, AFE CAI, E85, Nitto NT555R 305/18's & Weld 17" Skinnies(Post#547)
3~~~~11.16~~124.38~~1.70~Cajun@BER~~~~~~~~~15 A8 TSP headers, AFE CAI, BER ported intake/TB, BER tune, NT05R (Post#597)
4~~~~11.17~~126.92~~1.30~Zmoy2~~~~~~~~~~~~14 M7 ARH headers, e85 tune, BF Goodrich drag radials (Post#593)
5~~~~11.19~~123.56~~1.76~yonks8365~~~~~~~~~15 A8 NT05 drag radials, Cai, E85 (Post#553)
6~~~~11.21~~123.75~~1.72~10mm~~~~~~~~~~~~15 A8 Z51 ARH Midlength, AFE CAI, Tune (Post#542)
7~~~~11.32~~120.78~~1.63~wfarmer.z~~~~~~~~~~14 A6 Z51 K&N filter, 4 1/2 inch Weld wheels, NO TUNE (Post#292)
8~~~~11.33~~122.28~~1.62~Complete Street~~~~~~14 M7 NPP, Kooks 7/8, Tune, Catless, MT Radials (Post#482)
9~~~~11.47~~119.32~~1.68~TuneTimePerformance~~~14 M7 ARH/Tune/Z51/NPP
10~~~~11.57~~121.78~~1.82~JJFormato~~~~~~~~~~14 M7 Z51 Modified airbox, ported manifold & TB, Formato tuned. Hoosiers W/C5Z wheels(Post#94)
11~~~~11.67~~120.01~~1.74~~~JB~~~~~~~~~~~~14 M7 ARH, Modified airbox, ported intake manifold & TB, Formato tuned MT drags on C5Z (Post#74)
1~~~~10.573~~129.34~1.520~Ben@WeaponX~`'14 A6 427, 3400 converter, M&H 325's (Post#541)
2~~~~10.667~~127.39~1.527~LMR~~~~~~~'14 A6) Heads/Cam
3~~~~11.392~~123.29~1.911~ChucksTuning~'14 M7 VVT cam/AFM delete, Kooks 2" headers, 3" B&B PRT, Halltech stinger. (Post#120)
4~~~~11.672~~126.19~1.975~Mike@NewEra~ '14 M7 stock tires, NEP VVT Cam, ARH mid length headers, NEP exhaust D/A +2000 (Post#114)
Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr Details
1~~~9.48~~156.57~~1.611~LMR~~~~~~~~~ '14 M7) Twin Turbo (Post#250)
2~~~9.72~~137.55~~1.358~LS2000~~~~~~~~'14 A6 200 Shot, TSP Headers, AFE intake, E85, CCW skinnys and 275-40-17 MT
3~~~9.74~~145.94~~1.563~JTMMotorsports~~'15 A8 ARH 1 7/8" no cats, NPP, ECS 1500, 3.75 pulley 13.5#'s, Alky kit, JTM Cam, E85, 315/35/18 M/T DR's (Post#457)
4~~~9.95~~138.20~~~1.544~Dave01GT~~~~~~'15 A8 305/35/19 Mickey's A&A Blower, Small Cam/DoD delete, Long Tubes, Meth (Post#530)
5~~~9.96~~141.22~~~1.644~Pete@ChampionMotors '15 A8 Z51 A&A YSi, Champion Cam, ARH Headers, MT 18'DR (Post#526)
6~~~9.99~~132.7x~~~1.403~LMR~~~~~~~~~~'14 A6) Heads/Cam/150shot
7~~~10.00~139.85~~~1.541~brent eb02~~~~~~'15 A8 Ecs 1500 meth and Texas speed headers mt 315's (Post#591)
8~~~10.03~146.67~~~1.763~stangkilrproductions '14 M7 Stock LT4, Procharger F1a 14lbs, Cam, DYAD clutch, ignite e90 and meth, Cordes Tune (Post#582)
9~~~10.13~138.97~1.441~Ben@WeaponX~~~~'14 A6 427, NOS, 3400 converter, M&H 325's (Post#181)
10~~~10.18~131.23~1.434~Jimsgn~~~~~~~~~'14 A6 Z51, 417CI, LME Heads, ECS 1500,10psi, LS7 Lifters, BTR Springs, C5R Chain, Alky Meth, 3500 Stall, ARH 7/8, Catless M&H 275/45/18(Post#149)
11~~~10.17~140.56~1.610~Complete Street~~~'14 M7 A&A YSI Kit 10psi slipping belt, Meth, Kooks Headers, MT 285/35/18 (Post#537)
12~~~10.19~140.33~1.611~RyneZ06~~~~~~~'14 A6 Cam, Procharger P1 10lbs, ARH LT, Alky meth, Cms tuning, Hoosier drag radial (Post#304)
13~~~10.20~144.03~1.669~Vengeance Racing '14 M7 ECS blower, 14psi, Alky meth,VR Cam, ARH 1 7/8 W/CATTED X pipe Toyo 888R 315/35/20 (Post71)
14~~~10.25~140.33~1.640~JJFormato~~~~~~'14 M7 A&A Supercharger 6.5 psi, Fasterproms Heads/Cam, 93 Octane (Post#269)
15~~~10.33~136.93~1.671~c6switchblade~~~~'14 M7 ECS 2200sl, 2" ARH, Alky single nozzle 265/18 MT ET Streets (Post#486)
16~~~10.39~131.48~1.419~C7LT1~~~~~~~~~'14 A6 Tune, Converter, 150 shot m/t 19's. (Post#64)
17~~~10.56~131.35~1.633~kakashi~~~~~~~~'14 A6 A&A Supercharger, TSP LT headers, Alky Meth 9psi Hoosier 315/30/18, (Post#456)
18~~~10.57~129.96~1.554~Dameian~~~~~~~'14 A6 Z51, Pfadt Kit 8psi, ARH, 18" Forgeline Drag pack with 325/40/18 M&H Radials (Post#104)
19~~~10.61~132.13~1.713~Melgotboost~~~~~'14 A6 Non NPP, Tires stock, stock tire pressure, ECS Novi1500 ARH, Alky meth (Post#348)
20~~~10.64~135.13~1.849~FRANS96SS~~~~~'14 M7 Headers/Tune/150shot
21~~~10.73~132.90~1.813~"BoneStock"~~~~~'14 M7 20's with 315 r888s. ECS kit with restrictor removed, TSP Headers, meth (Post#459)
22~~~10.83~131.02~1.666~2highpsi~~~~~~~'15 A8 Z51 Magnuson Heartbeat, LT4 pump/injectors ET Street S/S 285-40-18 (Post#640)
23~~~10.84~130.55~1.716~10mm~~~~~~~~~'15 A8 Z51 Midlength Headers, AFE CAI, 100 shot (Post#514)
24~~~10.93~127.55~1.675~MIGHTYM0USE~~~'14 M7 A/A base kit, AFE headers, Meth, Tune, 305 19" NT05R (Post#498)
25~~~11.06~134.78~1.974~jsb08Z~~~~~~~~'14 M7 Z51 ECS supercharger 12psi, ARH headers, Meth, LMR breather kit (Post#159)
26~~~11.19~129.98~1.862~Greg Quillen~~~~~'14 M7 Z51, NPP, ECS Supercharger, ARH Headers, Pilot Super Sports (Post#157)
27~~~11.69~122.85~1.794~blue_bomber697~~'14 M7 Z51 ECS Supercharger, American Racing headers and X-Pipe (Post#629)
28~~~
Post em up!
Hi, I need help with a question. I have a 2014 Z51. I want to "hang a bottle" of combustion cleaner, connect the hose from a can of Berryman cleaner to an intake hose to clean the combustion chamber. Where should I connect it? Will this engine benefit from this or is this engine different so that it doesn't need this type of attention?
I have done this before with other cars by attaching the hose to the brake vacuum hose.
Thanks for the time.
Jon
Old Nov 1, 2018 | 06:38 PM
  #809
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I know the list isn't updated but why not. I hope to run in better air this weekend with some improvements my shift points to run a little better time but this is where I'm at for now.
Year of the C7: 2015 z51 a8
Tires used on the pass: 305/35/18 mt SS, 26x4.5x17 m&h racemaster fronts
Performance Mods (if any): 2" tsp lts, unported msd, e65, vararam, home depot air inlet mod, tuned by myself
Category submitted for: Bolt-Ons without Internal Engine Modification
60'.............1.612
330'...........4.579
660'...........7.008
660’ mph...101.54
1000'..........
1320'..........10.881
1320’ mph…126.19
Name of the track: State Capitol Raceway
Date of pass: 10/19/18
Weather conditions: (include Density Altitude, if known): 1572 according to airdensityonline.net
Link to Video:
Old Dec 26, 2018 | 09:26 AM
  #810
pedalpusher's Avatar
pedalpusher
I've been told the base C7 is faster because it is about 100 lbs lighter (no rear sway bar, full width rear spoiler, etc.) than any other model. The aero items add weight and actually slow the car down. They do improve corner speed for road racing. It also has the most narrow and lightest weight wheel and tire package. It all adds up to lightest most arrow dynamic stock C7.
Old Jan 8, 2019 | 04:56 PM
  #811
Marine1965's Avatar
Marine1965
Default My 2014 Z51
I run my Vette at out local drag strip once a month or so....my best et is 6.57 1/8 th.....1.51. 60'. 108 mph with Hoosiers on rear when racing....It runs 10.17 1/4 ..........
My car was built by Redline Motorsports in south Florida ....it has. Paxton supercharger, American Racing Long Tube Headers, Methanol, Intercooler......it is my daily driver....get 30 mph hwy, 20 mph in town.....767 hp to flywheel....
How do do I get it on the list ?
Old Jan 8, 2019 | 05:23 PM
  #812
Poppacapp's Avatar
Poppacapp
The list hasn't been updated for a good while. Unsure who will pick it back up
Old Jan 8, 2019 | 06:28 PM
  #813
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Unfortunately, nobody is able to “pick it up”. The theead belongs to the OP and nobody can take it over. Someone just needs to create a new fast list and then stay on top of it. I’ve been thinking about doing it myself..
Old Jan 14, 2019 | 12:07 PM
  #814
oklahoma's Avatar
oklahoma
I agree that a new "fast list" needs to start. This would be time intensive for whoever steps up to the plate. Perhaps one or more vendor organizations could adopt this as a service to the forum. If so how could we reciprocate the favor and make it a win win for us all. Please comment.
Old Jan 21, 2019 | 03:29 PM
  #815
sevinn's Avatar
sevinn
Another update here...why not
Performance Mods (if any): 2" tsp lts, unported msd,zr1 tb, e65, vararam, home depot air inlet mod, tuned by myself
60'.............1.558
330'...........4.450
660'...........6.828
660’ mph...104.66
1000'..........
1320'..........10.654
1320’ mph…127.37
Date of pass: 01/13/19
Weather conditions: (include Density Altitude, if known): -1100 according to airdensityonline.net
Here are my 3 best slips from the day...pretty consistent!
I didn't get any video myself, but I did end up on a youtuber's video on a 10.66 pass I made at 3:20 (second grey c7 just after the timestamped video is not me):
Old Jan 22, 2019 | 03:40 PM
  #816
JL2155's Avatar
JL2155
4th Gear
Default Settings
Hey, just curious, what settings are you using, tour, sport, track, traction on/off? I have z51 m7 as well, having trouble lanching... Thanks!
Old Jan 22, 2019 | 04:06 PM
  #817
65fastback's Avatar
65fastback
ha yeah it’s so damn tricky on run flats... I was in tour mode because that at least gave a slight bit of weight transfer to the rear on launch...also my car is a base model .
i also drove around the water and did a quick burn out to knock off any debris and put a little heat in the tire.
To C7 fast list!
Old Jan 22, 2019 | 04:44 PM
  #818
JL2155's Avatar
JL2155
4th Gear
I was trying all different settings and the best was 13 flat. I will stick with tour mode for now and hopefully I can do better this yr!. Thank again and really appreciate your feedback!
Old Jan 22, 2019 | 04:56 PM
  #819
65fastback's Avatar
65fastback
also... don’t worry about cutting a good light, you’re just out there for fun and it won’t affect your ET anyways ... just focus on feathering the clutch And balanced throttle input.
A good set of drag radials would make launches wayyyy easier and much more consistent.
Good luck !👍🏼
Old Jan 23, 2019 | 10:48 AM
  #820
JL2155's Avatar
JL2155
4th Gear
Good luck !👍🏼
Thanks, I have only been on the track 4 times last year. As a newbie, I was dropping the clutch at 3k cause wheels spin. I definitely need practice on feathering the clutch which I think is key. Oh, did you have your traction on or off. Yeah, having drag radial is like nite and day! Will keep you posted!
Good luck to you too!
