On the LMR unit, if the PCV system is eliminated, where does the suction come from to pull all of the contaminated particles, gases, etc out of the crankcase?
I pulled my hose off of my catch can today to check my system and there is quite a bit of suction going on there.
I talked to Doug about it before buying it, and he had some interesting insight back from his aviation days. Air and fluid dynamics is far from my field, though. I'm more comfortable with circuits and mechanical engineering.
Just got off the phone with Reid @ LMR - It's what I thought. On a FI car, you're using the enhanced positive pressure as opposed to vacuum. I can't imagine anyone using these on N/A cars, but that's just me.
On a side note, he said they're going to start offering these in a black finish as well! Sounds like a lot more people liked it than I even thought would!
No worries - I just don't have a lot of answers. I think LMR would be much better suited to answer the question(s) as otherwise I'm just guessing and relaying info.
I Just ordered the lmr catch can.
How can i install it without the welding part you did?
Is there a new version of it now?if not
Whats the easiest to bolt it without welding?
Thanks,i just emailed them to ask about the valve covers welded.
I just ordered the lmr catch can today.
Maybe tomorrow i will go see the vette,he started working on it today morning.a&a supercharger
The front bolt is easy to install there is a lip you can tighten the nut,but how can you install the rear bolt?a mechanic said there are screws that dont need a nut.is there a easy way to install it with a bolt & nut
The flange closest to the driver is easy - there's a lip right there to drill into and put a bolt/nut onto.
The front is a little more difficult. It requires you to either remove the front wheel well and really squeeze your hand in a tight space, or drill (I used a diamond-tipped 1/2" hole cutter) a small hole adjacent to where the bolt will go. That way, you can slide a nut onto the bolt and tighten it.
The issue with using screws on poly-carbonate is the cracking factor. Drilled holed can be covered or grommet'ed - cracks will always show or at least weaken the area you're working with.
