NPP fuse pull trick/result
Old May 20, 2014 | 09:40 PM
  #141
Theta's Avatar
Theta
St. Jude Donor '14-'15
I read that a few times, and I think you have it correct.With the fuse in, you have the 1700rpm tip-in in race and the 3000rpm tip-in in sport.
You can see it pretty easily if you watch the valves while someone else fools with it. Just make sure you trust them to not run you over or rev it in your face...
Old May 22, 2014 | 10:10 PM
  #142
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by Theta
Serious time crunch, so I borrowed a pic to edit from - sorry to that person, running out the door.
It's the 20A micro fuse (yellow).
That fuse is there in my non-npp car. Doesn't seem like i could use it for a bunch of reason's. I'm thinking of just grabbing 12v from the
socket in the right rear hatch.
My 4 cly mode is disabled from the tuner. Which i'm glad!
Just looked at the battery. I can add and wire everything under there!
Old May 22, 2014 | 10:39 PM
  #143
Theta's Avatar
Theta
Good route to take - there's a ton of room back there compared to the front junction area.
Old May 23, 2014 | 12:24 AM
  #144
3 Z06ZR1's Avatar
3 Z06ZR1
I put 12v to pin 4. Pin 1 to ground and then when pin 2 gets ground it closes?
Trying to test before I install it!
Test worked! Now to wire with the Mild to wild!
Old May 23, 2014 | 10:15 PM
  #145
Elite275's Avatar
Elite275
This would he awesome. Keep us posted!
Old May 23, 2014 | 10:19 PM
  #146
Theta's Avatar
Theta
It will work just fine, no mystery about it. M2W will supply the voltage as needed (or rather, act as the relay).
Other than having to wire it, this method is less of a PITA than messing with relaying a factory-NPP car like we've been working on.
Old May 25, 2014 | 01:37 PM
  #147
EVL-C8's Avatar
EVL-C8
If I just put on an axle back exhaust on a non-NPP car is it going to throw codes?
Old May 25, 2014 | 10:50 PM
  #148
Theta's Avatar
Theta
No, installing an axle-back exhaust system will not cause any codes to be thrown.
Old May 25, 2014 | 11:39 PM
  #149
bigdaddyj25's Avatar
bigdaddyj25
I installed b&b bullets on mine a couple days ago and I through a code yesterday. My car came with the NPP option. Any ideas on fix?
Old May 25, 2014 | 11:42 PM
  #150
Theta's Avatar
Theta
Which code (number please)? There is only one that will be thrown for AFM (fuse 34), not 41...
Old May 25, 2014 | 11:46 PM
  #151
bigdaddyj25
I currently don't have a method to detect the number my engine light just came on. Is there any way to determine without going to dealer?
Old May 25, 2014 | 11:47 PM
  #152
Theta's Avatar
Theta
OBD2 Code Scanner of any type, OnStar, or AutoZone.
Old May 25, 2014 | 11:51 PM
  #153
bigdaddyj25
Thanks I'll find out which and let you know. I was told that it wouldn't throw a code before I installed and sure enough my luck. Anyway I'm just trying to figure out how to correct it.
Old May 25, 2014 | 11:54 PM
  #154
Theta's Avatar
Theta
If you have a chance tonight to hit the OnStar button, I'll get you the answer right now.
There is only one code that could be thrown in a normal situation. Out of curiosity, do you have the B&B with their version of the NPP valves, or did you go with the non-valved B&B on an NPP car?
That opens up one other set of codes if you removed the valves from the CCM.
Old May 26, 2014 | 12:16 AM
  #155
Gr8ful's Avatar
Gr8ful
Vin #3385, NPP, Z51, 7sp, fuse 41 pulled. Thanks to all who made this info available. This place is great.
Old May 26, 2014 | 12:32 AM
  #156
Theta's Avatar
Theta
Old May 26, 2014 | 08:14 PM
  #157
3 Z06ZR1's Avatar
3 Z06ZR1
Need help something's is not right!
To NPP fuse pull trick/result
Old May 26, 2014 | 08:15 PM
  #158
Theta's Avatar
Theta
Not a lot to go on from that... Not to be an ***, but... more info?
Old May 26, 2014 | 08:25 PM
  #159
3 Z06ZR1's Avatar
3 Z06ZR1
I installed everything and ended up taking it back off. To find
12v to pin 4 then ground to pin 1 and 2 doesn't work !
HELP!
Trying to wire the mild to wild but I'm testing with 12v and ground.
Old May 26, 2014 | 09:18 PM
  #160
Theta's Avatar
Theta
Well, we have to start at the ground and work up, of course.
You had this wired and working correctly before the M2W, right? Just have to confirm.
