NPP fuse pull trick/result
Old May 26, 2014 | 09:59 PM
  #161
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by Theta
Well, we have to start at the ground and work up, of course.
You had this wired and working correctly before the M2W, right? Just have to confirm.
Thought so I got to turn now it doesn't. I pulled it all back out for another "bench test" and it doesn't pass
with power to pin 4! Ground to 1 and 2
Old May 27, 2014 | 10:11 AM
  #162
c5eddiem's Avatar
c5eddiem
Originally Posted by Rock'n Blue 08
I put 12v to pin 4. Pin 1 to ground and then when pin 2 gets ground it closes?
Trying to test before I install it!
Test worked!
Back at this post, you said this worked.
When you ground pin 2 does it stay closed? Seems to me like "12V to 4 and ground to 1 and 2" isn't the same as "12V to pin 4, ground to 1, tap 2 to ground."
In the original test, did it stay closed when 2 was grounded?
Ed
I have NPP on an A6. My issue is the V4/V8 thing, but that's another thread... interested in this on a purely "hmmmmm" level!
Old Jun 16, 2014 | 02:56 PM
  #163
c5eddiem's Avatar
c5eddiem
Yep. Unless you're hoping for always having the cold-start sound that was discussed in another thread. That first loud bark comes from changes in the metal, etc.
The #41 fuse pull will keep the valves open constantly.
Theta,
I don't know if you made any additional progress on the relay setup, or just decided on a switch.
I was wondering if the fuse box cover is orderable as a separate part, and its cost. I was thinking about some relay experiments, or just mounting a SPST switch right on the cover. Figured if I bought a second cover, I could make (grometted, watertight) holes, etc. and still have the original for service dept visits.
Thanks,
Ed
Old Jun 16, 2014 | 04:17 PM
  #164
Theta's Avatar
Theta
St. Jude Donor '14-'15
Ed, I'm using a grommet (or two) to do this, as I already have a wire running for illumination back from one of the HID fuses. Using that until such time as I can find a low-level 12v signal inside the cabin that signals illumination/lights on.
I will get that information for you shortly.
Old Jun 16, 2014 | 04:39 PM
  #165
DRLC5's Avatar
DRLC5
Thanks for the info. Can the C7 be done like the C6 by adding a toggle switch to turn on off when ever you want? I did my last 3 C6s this way. Only cost around 15 bucks depending on what switch you use. Like this?
http://forums.corvetteforum.com/c6-c...with-pics.html
Old Jun 16, 2014 | 06:11 PM
  #166
Theta's Avatar
Theta
No, it's a little different here. The switch we are working with on fuse 41 will allow the valves to stay open throughout the entire RPM range.
The valves, themselves, cannot be controlled by a switch directly. That's a project going on for the non-NPP folks at the moment.
Old Jun 17, 2014 | 10:22 PM
  #167
B Stead's Avatar
B Stead
How about this:
A C7 without NPP puts on the BB Fusion and works the NPP muffler valves with a switch. But I would disable the AFM and have a simple system
Old Jun 17, 2014 | 10:24 PM
  #168
Theta's Avatar
Theta
Originally Posted by B Stead
How about this:
You just need to get the power to the NPP valves, which you would need to buy, and that's a topic of much discussion in a different thread here.
It revolves around a PWM signal instead of just hot/ground (SPST).
Old Jun 18, 2014 | 12:11 PM
  #169
B Stead's Avatar
B Stead
The BB Fusion includes both the NPP muffler valves and the AFM muffler valves. Put it on a C7 that doesn't have NPP and connect the NPP muffler valves to a driver's switch. Also, disable the AFM. Then that's a simpler system than OEM
Old Jun 18, 2014 | 02:16 PM
  #170
Theta's Avatar
Theta
First, the B&B system doesn't come with their own valve actuators - you have to swap the factory NPP to make the car happy and work correctly.
See this:
Second, I've already explained that it's not a switched hot/ground, but rather a PWM signal controlled by the CCM (Chassis Control Module) that actually opens and closes the NPP valves, and constantly monitors their position.
Again, we had quite a bit of thought going into the other thread on how to accomplish a non-NPP to NPP swap.
I can't argue with you if you don't know what I'm talking about though, so I hope that explains it. If this were the C6, I'd be with you on it, but this works quite differently than those valves did.
Old Jun 18, 2014 | 02:26 PM
  #171
B Stead's Avatar
B Stead
The Chassis Control Module doesn't control the NPP when the C7 doesn't come with NPP.
The suggestion and question of a driver controlled switch is within that context
Old Jun 18, 2014 | 02:28 PM
  #172
Theta's Avatar
Theta
You're in the wrong thread, then - we have that discussion going in the other thread: http://forums.corvetteforum.com/c7-t...-npp-help.html
The NPP valves expect a PWM signal, not just hot/ground (SPST). If it was really that simple, we would have had this done months ago.
Old Jun 18, 2014 | 02:34 PM
  #173
B Stead's Avatar
B Stead
Okay, the C7 that I am working with didn't come with NPP. I put the BB Fusion on it with AFM valves and with NPP valves. What kind of driver's switch is needed to work the NPP valves ?
See, I don't think there is another subject because I am not trying to use the ECM or the CCM either one
Old Jun 18, 2014 | 02:38 PM
  #174
Theta's Avatar
Theta
Just gave you the correct thread - he's doing the same thing you're trying to do. Non-NPP car, trying to use NPP valves.
I don't know how else to explain it, as there isn't any other way. PWM. Not SPST.
When we tried SPST 12v the valve worked for a few moments and then nothing. There is a motor control PWM - the are little PWM controllers that may end up working (and they're around $10 each plus the box you'd need to build them in).
Right now, it's still very DIY to do what you want to do. Cutouts would have been a far simpler solution, but I respect wanting to use the factory system. The only thing holding you back is the new control 'mechanism' (really just added monitoring).
Old Jun 18, 2014 | 02:42 PM
  #175
B Stead's Avatar
B Stead
[QUOTE=Theta;1587163639]Just gave you the correct thread - he's doing the same thing you're trying to do. Non-NPP car, trying to use NPP valves.
QUOTE]
No, if the C7 didn't come with NPP then it can be set up like a C6 NPP
Old Jun 18, 2014 | 02:43 PM
  #176
Theta's Avatar
Theta
You know, I've tried to be helpful, but it's not getting through... Best of luck with the C7 NPP valves without a PWM signal. Please do read the other thread.
Old Jun 18, 2014 | 02:45 PM
  #177
B Stead's Avatar
B Stead
There aren't C6 NPP systems that use a simple vacuum switch and that could be used on a C7 that didn't come with NPP ?
To NPP fuse pull trick/result
Old Jun 18, 2014 | 02:48 PM
  #178
Theta's Avatar
Theta
This isn't remotely similar to the C6 design, and this actuator doesn't operate like the C6 valves did. Perhaps that's what's making this difficult to explain to you.
Old Jun 18, 2014 | 03:00 PM
  #179
B Stead's Avatar
B Stead
Yeah, the C7 that I am working with didn't come with NPP.
Now I just want to put a C6 NPP system on it.
I would want to use the C7 BB Fusion muffler system with the correct type of C6 NPP valves installed on it
Old Jun 18, 2014 | 04:49 PM
  #180
Theta's Avatar
Theta
The other thread is exactly what you're looking for in that case: http://forums.corvetteforum.com/c7-t...-npp-help.html
