C7 sway bars choices?
That being said you will see updates on the website with more pictures and data as time goes.
These were the first bars on the market and have been on the market for well over a year now after months of testing prior to their release.
As with all of our products they are tested by the man himself on track to make sure you not only get the best performance, but performance that is going to last.
The Corvette has a built-in understeer, as do most north american cars.
To address this, we can do several things
Raise front tire pressure.
Lower rear tire pressure.
Soften front shocks.
Stiffen rear shocks.
Lower front end.
Raise rear end.
Widen front track.
Install shorter front tires.
Install taller rear tires.
Install wider front tires.
Install narrower rear tires.
Soften front sway bar.
Stiffen rear sway bar.
More front toe out.
Reduce rear toe in slightly.
Increase front negative camber.
Increase positive caster.
Soften front springs.
Stiffen rear springs.
This is all taken from..... http://www.thesmokingtire.com/2012/m...teeroversteer/
I have installed the LG G7 Sway bars, front and rear.
I tried the front bar on "soft" a couple of weekends ago,
and the car handled very well.
Last weekend, I set the front to "firm", and we encountered
quite more understeer.
So today I put the front bar back to "soft".
Results at the PCA-CWR autocross today.... 44 drivers
(my wife and I in our 2014, another 2 guys in a 1984, and about 6 others in various other vehicles).
We had 10 runs each.
I had FTD with 53.0.
Closest was a Porsche Carrera 4 with 54.4.
My wife was next with a 54.7.
Everybody else was 55 and up.
I LOVE These bars !!!!!!
I now have my new wheels (they took over 4 months... but that's another story),
and my new R888 tires to go on them. They are being mounted and balanced for
next Monday or Tuesday.
We have another event next Saturday (July 18), with those pesky Miatas on A6 tires.
I do have a concern about rubbing in the front wheel inner liners when doing hard turns.
I guess we'll find out.
If that is the case, I'll have to research what I can do to alleviate the problem.
Stay tuned.
Here's my best run
(notice there are a few spots where I did skid out a bit..... probably could have gotten a high 52,
but it started to rain)
If you are talking about a C7 Z06, that much HP can turn any car into a "Drift Car".
I tested these bars, in various sizes, at the track, and this is the package that actually gets rid of the factory built in "Push".
The faster that track, and the corner the more easily you can see the benefit of a properly set up sway bar package.
The C7, all models are so much better with these bars on, it is hard to believe the transformation.
We just sent a set to Phoenix Performance and they raved about them. And Phoenix is a great race team to say the least.
We have them in stock, ready to go.
NOTE: If you have a base C7, you have NO rear sway bar on the car at all. The Z51 package is less aggressive than our bars so you will see the improvement even over the Z51.
thanks guys
Lou Gigliotti
This car has the bars installed along with our LG C7 Drop spindles. Awesome car!<br/>
I was getting sick of essentially going '***-end-over-teakettle' every time I goosed it around an iffy corner.
Stay tuned.
Here's my best run
Congrats on the runs and the win!
I would completely agree that there is a lot of push built into the cars, but almost any production car is going to have that as most would feel a push has a bit more "safety" to it than a car that will over steer at the drop of a hat (not talking throttle induced over steer).
Our sway bars will allow you to soften the rear, or stiffen up the front in order to induce the understeer feeling you desire to fit your driving style
I'm admittedly not a suspension whiz - this isn't really in my wheelhouse. What drove me to these was the adjustability. In my mind, I should be able to find a good combination using one of the six (someone correct me if that's incorrect) settings between the two bars.
For the moment, I'm testing them out on what I would refer to as normal (middle)/soft.
I'm not doubting you at all, just trying to make sure I have it all straight in my mind before making any changes to my car.
