Muffler Mod
Old Jan 8, 2016 | 06:32 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Default Muffler Mod
Answered my question today after we cut open some NPP mufflers.
Old Jan 8, 2016 | 06:33 PM
mariofromnewyork
Larger, Solid pipe is on the valve.
Old Jan 9, 2016 | 12:13 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Good work! We've wondered what it actually looks like inside the NPP mufflers for a while but nobody was brave enough to cut one open!
Old Jan 9, 2016 | 01:01 PM
Seannyc's Avatar
Seannyc
So what can u do to make it louder
Old Jan 9, 2016 | 01:22 PM
MikeLsx's Avatar
MikeLsx
cover up the baffles is my guess.
This is what we did on the BMW m3 forums.
Old Jan 9, 2016 | 02:19 PM
meyerweb's Avatar
meyerweb
What was the original question?
Was there any fiberglass or similar in there, or is it just empty space like in the photos?
Old Jan 9, 2016 | 03:30 PM
mariofromnewyork
The muffler is completely hollow. The perforated pipe is for quiet mode. The ends have some matting for drone.
Old Jan 9, 2016 | 04:21 PM
Seannyc's Avatar
Seannyc
So how can we make it louder and have the quit mode also
Old Jan 9, 2016 | 07:24 PM
mariofromnewyork
I think the only way would be to increase the size of the straight pipe?
Old Jan 12, 2016 | 07:02 PM
xrayvette's Avatar
xrayvette
Cruising
hi
are you going to make it louder? and if you do please let us know how it turns out...thanx
Old Jan 12, 2016 | 08:43 PM
C2367's Avatar
C2367
I would think you would have to have a larger diameter valves, I believe the pipe / valves before the muffler squeezes down to 2.25 at the valves from 2.75".
Old Jan 13, 2016 | 08:56 AM
6Speeder's Avatar
6Speeder
Originally Posted by xrayvette
hi
What about making the quiet side straight through like the valved side?
Old Jan 14, 2016 | 06:25 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I'm not sure I understand what is happening. When the valve is closed (quieter?) the gas goes through the holes in the large pipe, into the chamber, and out the small perforated pipe?
When the valve is open, the gas goes (mostly) straight out the large pipe?
Old Jan 14, 2016 | 05:42 PM
mariofromnewyork
Nailed it.
Old Jan 19, 2016 | 10:50 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
You'd get more sound by cutting out the small straight pipe completely, but the quiet mode will be gone. but isn't that the idea?
Old Nov 5, 2020 | 10:00 AM
Prop Job's Avatar
Prop Job
Bringing this one back from the dead.
I'm trying to figure out a way to get under the ridiculous 103 db limit at NCM. On my C7Z with ARH catless mid length headers, stock x-pipe with stock cats, and Borla S-Type catback I was 106. I tried their on site exhaust tip mufflers and they didn't work. I have since installed an additional set of 200 cell count Magnaflow cats but I don't think it lowered the volume at all.
My thoughts are to put the stock catback on but I think in off the shelf form they will be just as loud as the S-Type Borla during WOT due to the majority of the gasses going straight through the valved pipe. So I need more of the gasses during WOT to go through the muffled pipe.
The two options I'm considering are removing the curved pipe completely or drilling a bunch of 1/2" holes in it. What do you guys think would yield better sounding results, hopefully under 103 db?
Old Nov 5, 2020 | 12:17 PM
HOXXOH's Avatar
HOXXOH
Strangely enough, I'm in the prototyping stages of doing exactly whats needed to resolve the problem. So if you are willing to wait a couple weeks, I'll share my results with you.
To Muffler Mod
Old Nov 5, 2020 | 12:49 PM
Prop Job's Avatar
Prop Job
Awesome! Let me know what you come up with. I'm in no rush. NCM is a once a year track for me during LS Fest so not planning to go back until next Sep. None of the other tracks I go to play the stupid noise limit game.
Old Feb 24, 2021 | 11:06 PM
MorrisZ51's Avatar
MorrisZ51
many updates on this? I’m picking up a set of mufflers this weekend to experiment with. My thought was why not cut out both the S pipe and the perforated pipe. With all the exhaust going into a big chamber it might slow the flow and resonate idk. Could also open up the flow like a straight pipe, any thoughts?
Old Feb 25, 2021 | 05:48 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
There's another discussion going on about this right now. You guys might want to get together. I think hes at the same point you are.
https://www.corvetteforum.com/forums...er-delete.html
