E85 Questions
Old Nov 13, 2021 | 12:05 PM
  #41
MCK_Z06's Avatar
MCK_Z06
Originally Posted by Travlee
the shop will be 21st Century Muscle Cars, they did the work on my C6Z, and all the work on this C7
You will be in good shape, they did my secondary port injection and full flex fuel setup going on 5 years ago and its been issue free since then.
I just put 93 or E85 in the tank or any mixture in-between 0-100% and drive. (no calculating or specific ratio mixing at the pump)
I have a lot of other mods, but running on E gets me about 50-60whp over what I make on 93pump alone.
The car is also much more snappy and responsive as well as runs cooler on E85 vs gas.
Old Nov 13, 2021 | 12:39 PM
  #42
aklim's Avatar
aklim
Originally Posted by Internets_Ninja
Being that he is only adding E85 it is a very simple tune. The first file will be 90% of the way there. Then you tweak WOT on the dyno and go on with your day. I wouldn't consider that a canned tune at all.
That is pretty cheap. I can't get on a dyno for $400 and that is pretty much strap it down and take it off unless it is self tuning
Old Nov 13, 2021 | 12:51 PM
  #43
99vetteran's Avatar
99vetteran
You still have to add the flex fuel tables to add timing above the stock tables depending on the E content. Turn on the sensor but not a big deal.
Old Nov 13, 2021 | 04:29 PM
  #44
Travlee's Avatar
Travlee
They are a good group of guys, i have full confidence in them.. hell I am there every 4 ish months for an oil change
Old Nov 15, 2021 | 10:05 AM
  #45
TJay74's Avatar
TJay74
The C7 gas tank is 18.5 gallons, at a 1/4 tank that will be about 4.75 gallons, If the tuner gets it down to 2 gallons and then add 5 gallons of E85 (Will be closer to E70-E75) it will put you are about E50-E55 for when they start tuning.
Old Nov 15, 2021 | 11:24 AM
  #46
Travlee's Avatar
Travlee
thanks for that, this weekend i downloaded an E85 calculator to mess around with it. my plan is to schedule it for 12/10
Old Nov 16, 2021 | 08:59 AM
  #47
TJay74's Avatar
TJay74
I found a custom PID for the Torque App so I can use it to see what my Ethanol rating is, that and along with a fuel remaining function in torque as well. Once I know that info I can convert everything over to "points" and know how much E85 and gas to add to the tank to keep my rating in the range I need it in. I made a excel spreadsheet that does all of the calculations for me for E85 all the way down to E60 in 5 point increments.
So as an example if I know my ethanol is sitting at E52 and I have a half tank of fuel I take 9.25 (tank is 18.5 gallons) and multiply 9.25 by E52 and it gives me 481 points. Then I figure up how much E85 I am going to add, say 6 gallons in the example and multiply E75 (normal Ethanol content for this time of year for my area) by 6 which is 450 points. I then add the 450+481 and get 931 points. I divide 931 by 18.5 and it gives me a new E85 rating of E50. The 6 gallons of E85 added to the 9.25 gallons remaining means I will need to add 3.25 gallons of 91 or 93 octane. It isnt exact, but it is close enough that I can get within a couple points of where I need to be on my E85 concentration.
Old Nov 16, 2021 | 10:11 AM
  #48
Internets_Ninja's Avatar
Internets_Ninja
You can just download an E85 calculator from the App store to do all of the work for you. You put in your fuel tank size, your current ethanol %, your desired ethanol %, what the pump ethanol content is. And then you just tell it how much fuel you need to add to fill up and it will tell you the ratio in gallons. You can use the fuel volume consumed screen in your dash to see how much fuel you have used so that you know what to plug in as well.
Old Nov 18, 2021 | 09:43 AM
  #49
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
I can deal with that, given it a dollar a gallon cheaper than 93 in my area
You will burn up to 30% more E85 than you will 93 octane so the price difference isn't a bonus. In fact I end up burning more money using E85 and have to fill up more often. Wish more people understood that at the pump I see lots of people filling up with E b/c they think it's cheaper and they are saving money, when in reality they are filling up more often and not saving much of anything. If tuned properly with a wideband you will make more power if you have all the correct dependencies and mods in place, most important being an upgraded fuel system to supply more fuel to compensate for the extra 30% more flow.
Old Nov 18, 2021 | 09:56 AM
  #50
Travlee's Avatar
Travlee
i know the downfalls, i am going to talk to them about fuel when i swing by saturday
  #51
aklim's Avatar
aklim
So, sensor, tune and fuel pump. Are the injectors good to go or are we going to be running on the ragged edge?
Old Nov 18, 2021 | 10:45 AM
  #52
Travlee's Avatar
Travlee
the shop didnt mention fuel pump until i SC it, but i have read that some use z06 injectors... going to ask all these question to them this weekend
Old Nov 18, 2021 | 11:27 AM
  #53
99vetteran's Avatar
99vetteran
I agree that you do burn more fuel but right now and in the past I've paid over a 1.00 less a gallon for E85 which is usually E65 to E70. I just filled mine up couple days ago and E85 was 2.69 and 91 was 3.79, they don't have 93 where I buy my flex fuel. Mine will get 29 mpg when on full 93 octane and about 23-24 mpg on E85 so there is a difference but the power is there with the E85 that's not there with the 93 octane. The thing about running either is the genius of having the sensor and tuned properly. The sensor sees the content in the line and adjusts the according to the flex fuel timing table set up by the tuner. Now living in the midwest I have to run E30 or lower because of the cold winter climate. However I don't drive my Vette unless its above 40 degrees and of course sunny and generally run all 93 during that time period of about 4 months.
Old Nov 18, 2021 | 11:34 AM
  #54
7LitreC5's Avatar
7LitreC5
While technically true that you can burn up to 30% more E85, in my experience it is less. Part of that depends what the actual ethanol content is when it comes out of the pump. I run my 18 6.2 Tahoe, 17 ZL1, and 19 Z06 on E85. The actual ethanol content is very consistently 66% at the stations that I buy at. My actual mileage loss on all 3 vehicles is 16%. If the E85 were actually 85% ethanol, I would expect to use about 21% or 22% vs. premium.
Old Nov 18, 2021 | 12:05 PM
  #55
TJay74's Avatar
TJay74
This isnt always true. E85 is $2.25 at the pump here in OKC, 91 is $3.75. My fuel mileage is no where near 30% worse either, I get about 17mpg combined on E55 and 20mpg on 91. 10 gallons of 91 @ $3.75 is $37.50 per week for my gas, on E85 I run 7 gallons of E85 @ $2.25 and 3 gallons of 91 @ $3.75 for a cost of $27 or a weekly fuel savings of $10.
You also wont make more power on 91/93 over E85, not even close. 91/93 is octane limited to around 600hp on its own, E85 can go well above that. On E55 I can make 700rwhp, pretty dang close to 100hp more than I can on 91/93. A WB02 has nothing to do with that as a WB02 only confirms your A/F targets and that they are on point.
Old Nov 18, 2021 | 12:13 PM
  #56
aklim's Avatar
aklim
What is the gain for the NA LT1?
Old Nov 18, 2021 | 12:26 PM
  #57
Gary barnes 1098's Avatar
Gary barnes 1098
Maybe 30rwhp
To E85 Questions
Old Nov 18, 2021 | 12:58 PM
  #58
Travlee's Avatar
Travlee
equal or higher torque as well from my understanding
Old Nov 18, 2021 | 04:15 PM
  #59
TJay74's Avatar
TJay74
Yes, on a N/A LT1 you will see around 20-30 RWHP gains.
Old Nov 18, 2021 | 04:39 PM
  #60
aklim's Avatar
aklim
Sensor and a dyno tune is one thing. Fuel pump and injectors will be a $3000 deal by the time all is said and done.
