Code name Zerv
So then we have two power enablers on the C8 vs. C7 using LT1 engine, the headers and the intake manifold. GM is using the extra height and the extra width in ME chassis to allow the LT1 to breathe.
It is useful to look at a mid engine Ferrari 458 to see what's going on, notice how transmission, exhaust, intake are all at the back of the car, on one side of the engine. Same with this CAD, except the heads look smaller which means pushrod.
If this is the DOHC turbo then the turbos are not in the vee and that's a damn shame.
What I see in the CAD is a NA OHV engine with a "beauty" cover over the intake manifold with the air breather/MAF at the rear of the car located above the DCT.
I also take that to mean there is possibly no cargo area in the rear of the car(unlike the NSX and the Cayman/Boxster). That would leave a small cargo area in the front, which solidifies my believe that the front engine Corvette will still be built(too many of us like the huge cargo area of the front engine Corvette) concurrently with a mid engine model.
I also suspect that there will be trunk space at the back of the ME car to accommodate the "golf club" owners. That's why the rear overhang on the camo cars make it look like a pickup. I'd be happy to be proved wrong, but I see no other reason why the back end should be so high and long. That in itself may give some clues as to the intended target market and subsequently the likely pricing.
In wheel knuckle design. The C5 was the first vehicle to be designed where the knuckle slipped around the wheel and the hub attachment was much closer to the wheel face. That drove the one sided brake calipers.
The more you move that the great the articulation you get on turning the wheel.
Trucks always have difficulty in turning radius so the '98 Durango had that same design even though the C5 had only been on the market a very short time. It was a huge competitive advantage due to small turning radius compared to other vehicles of its size.
1 generation or 3 generations, it is still the same. It is not intentional and due to the amount of detail they pulled in I doubt it will take them long, if not already, to find out who did it.
We had safe guards in place that if someone pulled in a lot of models at one time they got a phone call to explain what they were doing because there very rarely is a need to do so.
I asked the owner what they were doing for Ford, and he told me they were doing some research work for Ford on induction hardening of the valve seats, because of upcoming government regulations to do away with lead in our gasoline. That was he first time I had heard about getting rid of the lead in our gasoline.
I also saw something similar when I had another company in Michigan building some automated welding equipment for me and they had a bunch of equipment they were building for Oldsmobile to weld their torque convertors.
Surprising how others can see what is going on since many companies do business with companies that also supply the auto industry. At that time, the company I worked for was a supplier to Chrysler(but the equipment I was buying had nothing to do with the components we supplied to Chrysler.)
CAD Drawings - Real "Leak" or GM Controlled?
Keep this thread for the discussion of what the CAD drawings reveal (or do not reveal). What can we learn about the ME from these?
Which is different than what the LT1 has, which is this:
Basically the runners are much longer. It's not just a beauty cover since you can see a gap between the runners in the CAD.
It's unclear from the CADs whether there is room for storage above/in front of the engine. It does not show interior trim. The intake manifold in the CAD is not giant, like the Ferrari 458 one I posted, so technically there may be some room left above the engine.
The leaks so far indicated that there is an NA OHV, Turbo 4.2 DOHC, and Turbo 5.5 DOHC. Are you saying there will also be a forth option, NA DOHC? I hope so, but this is the first I hear of it.
I think I can explain better with pictures. The CAD shoes an intake manifold like this:
What it covers(an old design LT1 intake manifold or a new design intake manifold) is irrelevant.
It's no different from the carbon fiber "beauty" cover on the LT5 engine on the new ZR1 that covers the top of the supercharger/intercooler.
As for a cargo area, the air breather does extend over the top of the transaxle housing in the rear of the car along with the CATS on each side of it, taking up a lot of space. I don't think there is enough room of much of a cargo box, if there is one. No way can there be a cargo area above the engine, and I doubt if there is in front of the engine between the engine and the rear passenger bulkhead. Not only do you have a long engine there is a lot of accessary drives in front of the engine, and the gas tanks have to be squeezed in there also. I suspect the battery has to be in the rear of the car also along with the dry sump reservoir.
I believe it is a "beauty" cover that covers the intake manifold as you can clearly see the attachment tabs and the hex heads of the attaching fasteners, on each side of the cover.
The 570 McLaren has giant runners, a la Ferrari, and still has storage space on top.
I'm not sure that what I saw scrolling thru the above link is what most people are thinking of when it comes to "storage space." And the 5 cubic feet up front won't carry anything, really...
“12x43 (trunk gasket to trunk gasket)x22 in deep at the top. The trunk was designed to hold two sets of golf clubs. These were the measurments for my 87 GT. The lower portion of the trunk is 34.5 inches wide with the front sloping down to 8 in at the bottom of the trunk.”
Can't wait to see what they actually come up with. For now, just fun debating on a cold day...
https://www.google.com/url?sa=i&rct=...13888511341700
https://ziploc.com/en/products/close...bag-large-flat
