C8 problems
Can anyone tell me if they are just blowing smoke up my _ _ _ or what?
Also, if anyone who has a c8 can they please check this for me.
Thank you for your help,
Joe
Sounds more like an issue with the Generator, ECM, BCM, Current Sensor, etc. I sent you a PM with lots of details.
I would ask the Service Rep / Tech to DETAIL all the steps they did to check it!
Did they check the duty cycle commanded to the generator by the ECM/BCM?
Did they check the battery current sensor?
Did they check for parasitic loss?
Did they check the BCM battery state of charge / indicated charge mode?
Some tools you could use to test it yourself:
Personally I have some slight concerns over the battery / voltage regulation circuit in my C8. Perhaps its a total coincidence, not sure, but I was doing work on my C8 brakes and I first disconnected my battery NEG terminal as you should if you want to keep your fingers intact!
Worked on my track prep / pad swap / DOT4 Castrol SRF fluid swap, and then I reconnected the battery ground.
I had a device connected to the USB-C port in the arm rest area and that little device FRIED nicely. Really??? Wow...thanks! Also had a USB-C thumbdrive working there for a while and it also fried.
I have a USB power tester / datalogger and connected that. It has a nice graph, very well regulated voltage with a slight ripple. I haven't tried graphing the output with a battery disconnect/reconnect sequence though.
Not sure, but from now on I disconnect EVERYTHING that is not part of the C8 from power before touching / removing the battery terminals.
Also, I get a message to start the car when I get the low battery warning. Does your warning state that? If not, perhaps it is a different message and thinks the car is running when it displays that message (again potentially a software error).
https://www.corvetteblogger.com/2022...attery-charge/
Joe
Edit - Ah, my bad. You're talking about LS WON. You're Fast Dawg. OK, LS WON, why are you here???
.so darn fast and has a great reputation...overall.
