Sponsored by: Wheel Design
Soler Performance
Old Mar 3, 2024 | 10:46 AM
  #141
dman918's Avatar
dman918
Are most people mounting the controller or just tucking it away and using the app?
Old Mar 3, 2024 | 10:49 AM
  #142
Kracka's Avatar
Kracka
Tucking it under the carpet behind the pedal and using the app.
  #143
tadda's Avatar
tadda
Veteran: Marine Corps
I disconnected the controller interface display after install and just use the app...That said, once I settled on a setting (sport 4) I haven't even needed to use the app for quite a while now...
I also tucked the main module and cable under the carpet near the accelerator pedal for a stealth install...
Old Mar 3, 2024 | 11:16 AM
  #144
LongboardDelight's Avatar
LongboardDelight
For you guys that installed it. Did you wait until 500 mile break in period? I bought the controller before the car was delivered. I have 370 miles on it now and the controller is here staring at me. I said I’d wait until 500 mile mark. But curious what others did
Old Mar 3, 2024 | 11:32 AM
  #145
trumanjd1's Avatar
trumanjd1
I am going to treat the next 1500 miles just like the 1st 500 miles. There seems to be An unusual amount of DSC issues and fo t want to give GM any reason to not cover any warranty issues I haven't purchased the optional ins yet as I just brought my new 2024 Z51 out of storage weather still not very good or consistent here in WESTERN N.Y.
Old Mar 3, 2024 | 11:38 AM
  #146
Kracka's Avatar
Kracka
No reason to wait until after break-in as the controller doesn't actually impact the engine at all.
Old Mar 3, 2024 | 12:10 PM
  #147
Vega$Vette's Avatar
Vega$Vette
correct.
Old Mar 3, 2024 | 02:26 PM
  #148
GRSAMS's Avatar
GRSAMS
Shows they are out of stock at the moment.
Old Mar 3, 2024 | 04:08 PM
  #149
SMOKN C8's Avatar
SMOKN C8
They will get more. You can also check paragon performance
Old Mar 3, 2024 | 06:10 PM
  #150
Red Mist Rulz's Avatar
Red Mist Rulz
I don't even have the display connected. Just use the cell phone on the rare times I want to change something.
Make sure you install the new one where you can't accidentally bump it!
Old Mar 3, 2024 | 10:47 PM
  #151
SMOKN C8's Avatar
SMOKN C8
^^ Same. Zero reason to use the display (unless you do not have a modern phone)
Old Mar 4, 2024 | 10:38 AM
  #152
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
We've got them back in stock now! Had a huge shipment come in late last week.
Old Mar 4, 2024 | 08:33 PM
  #153
SMOKN C8's Avatar
SMOKN C8
this is the way
Old Mar 4, 2024 | 08:40 PM
  #154
RMS73's Avatar
RMS73
I put the controller on top of the steering column in the flexible boot.
Old Mar 6, 2024 | 01:26 PM
  #155
DRC39's Avatar
DRC39
I emailed mike@solerengineering.com and he suggested to check for vacuum leak. Sure enough, I found a disconnected hose under the duct in front of the throttle body. I’ll take it out this weekend and see it that was the problem.
thanks Mike
Mike@solerengineering.com suggested I look for a vacuum leak around the throttle body and duct. Sure enough, found a detached hose under the duct. Reattached and took it out today. Performed beautifully! Thanks Mike!
Old Mar 7, 2024 | 05:36 PM
  #156
tome's Avatar
tome
Default Excellent service!!!!!
I recently purchased a unit from them and had a couple of questions and so fired off an email......... within an hour I had a response!!!!!!!! Wish all companies responded as promptly....
Then I get the unit installed............................and discovered a whole new driving experience, what a great addition to the C8. If you are on the fence..... JUST DO IT!
Old Mar 16, 2024 | 08:46 AM
  #157
dman918's Avatar
dman918
Default Sport setting
Installed the throttle controller. Super easy process. Started at sport 5. Really touchy. Sport 4 is pretty decent but I think I'm going to compare sport 3 as that may be the sweet spot for me.
To Soler Performance
Old Mar 16, 2024 | 09:06 AM
  #158
winders's Avatar
winders
I started at Sport 2 as I thought anything higher was too touchy. After I got used to Sport 2, Sport 4 seems to be the sweet spot for me....
Old Mar 16, 2024 | 11:41 AM
  #159
mmaynard1's Avatar
mmaynard1
Is there a current discount code?
Old Mar 16, 2024 | 06:07 PM
  #160
jwt1603's Avatar
jwt1603
That’s where I ended up too.
