Sponsored by: CARiD
Diff Whine ... Common?
Old Nov 21, 2021 | 10:02 PM
Thera p's Avatar
Thera p
Default Diff Whine ... Common?
I’ve started to notice some diff gear whine in my ‘22 HTC. 700 miles. There’s a noticeable whine in the 65-70 mph range, regardless of gear. So I’m wondering if others have noticed it and if you’ve addressed it with GM? I’m probably more interested in hearing from those that don’t have an issue since I’m anticipating the “they all do that “ response. The local service Mgr has driven mine and stated ‘he wouldn’t be happy if it was his car’ ... so I hope he will go to bat for me. I made a similar post on the ‘general’ forum but didn’t get much useful info. I hope this group is more helpful.
Old Nov 23, 2021 | 09:30 AM
Thera p's Avatar
Thera p
Anyone?
Old Nov 29, 2021 | 08:13 AM
RandelB's Avatar
RandelB
Tremac DCT
Above is a link to a very good article regarding the development of the C8, as well as the transaxle. One very important detail is that they wanted a common fluid to lubricate the gears, clutches and everything else. To accomplish that they had to do away with a hypoid ring and pinion, since it in itself requires a very special fluid that is not compatible with the other things now in there. So, the ring and pinion gear set is an on-center alignment. Hypoid gearing was developed decades ago to reduce gear whine. So, it is inevitable that there is a very faint whine from the rear. It is normal, and almost expected, but I doubt Chevy would ever say that. Being the mechanical guy that I am, I like the sound of a flat tappet solid cam, supercharger whine and turbo spool-up, so a whine of a rear gear from a fantastic sports car is not objectionable to me.
The whine you are hearing is considered normal. Enjoy the ride.
Old Nov 29, 2021 | 09:23 PM
Thera p's Avatar
Thera p
Originally Posted by RandelB
Tremac DCT
I haven’t read the article yet, but using a common trans fluid does not preclude using a low-noise differential gear set. Many modern transmissions have a common lube and are quiet. I worked In tractor DT development for many years. Our trans used wet clutches and brakes ...not unlike the DCT. It used a common fluid and was the reservoir for the entire hydraulic system. We used on-centerline (spiral/bevel) ring & pinion and they were quiet. IMO, DCT whine probably has more to do with contact ratio, overall gear dimensional quality, and setup. TheC8 is not a big block C2 or C5 with an aftermarket blower. Gear whine is like finger nails on a chalkboard to me and it shouldn’t be a characteristic of a car of this caliber. I’ll be addressing it with GM so will try to update this post with developments.
Old Nov 30, 2021 | 07:29 PM
BJ67's Avatar
BJ67
Yes , I have rear gear whine between 50 and 60 mph on light throttle or maintaining speed on level ground, with just a little off throttle from 60 to 55 mph. I have a 2021 , 2600 miles, non Z51.
Old Nov 30, 2021 | 10:28 PM
Thera p's Avatar
Thera p
Originally Posted by BJ67
Yes , I have rear gear whine between 50 and 60 mph on light throttle or maintaining speed on level ground, with just a little a off throttle from 60 to 55 mph. I have a 2021 , 2600 miles, non Z51.
Are you OK with it or are you working with GM on resolving?
Old Dec 1, 2021 | 08:38 AM
c5racr1's Avatar
c5racr1
I have it too. Not a big deal to me
Old Dec 1, 2021 | 08:57 AM
BJ67's Avatar
BJ67
I had the dealer service dept. make note of it on the repair order on my 1st oil change/trans filter change at 1500 miles. If it gets worse I will push it, other wise probably live with it.
Old Dec 1, 2021 | 01:08 PM
Thera p's Avatar
Thera p
I’ve heard (on FB) of one instance of the owner adding an additional 2 qts of fluid to the transmission (as recommended for track use) and it reduced diff whine. Can anyone confirm whether an oil ‘add’ does reduce whine?
Old Dec 1, 2021 | 01:56 PM
c5racr1's Avatar
c5racr1
Default Wine
Been having 2 extra from day 1 still wines. Changed the fluid and filter at 4k, still wines.
Old Dec 1, 2021 | 03:18 PM
Thera p's Avatar
Thera p
Are you addressing with GM? ... or just live with it?
Old Dec 1, 2021 | 04:15 PM
c5racr1's Avatar
c5racr1
Default Wine
Live with it.
Old Dec 2, 2021 | 07:15 PM
ssv3's Avatar
ssv3
I have to pay attention but I don't hear a whine on mine. I usually pick up odd noises but don't hear a diff whine. Mine is a 2020 if it matters.
Old Dec 2, 2021 | 08:07 PM
Thera p's Avatar
Thera p
If top is on, windows up, radio low, and your hearing is good, you would hear it at 60-70 mph.
Old Dec 3, 2021 | 11:37 AM
RKCRLR's Avatar
RKCRLR
Mine slightly whines at higher speeds at part throttle when it has warmed up. It is most obvious when I hold the throttle in a neutral load situation. Like going down a very slight grade or letting the car slightly decelerate.
I noted it on my service order when I brought the car in for its first service. The response was "no abnormal noise heard at this time".
The DCT transfer spur gears have straight cut teeth vs helical teeth which are quieter. I suspect a slight whine is inherent in the design.
Old Dec 3, 2021 | 12:00 PM
Thera p's Avatar
Thera p
Thx for your info. Your experience is a little different than mine. I hear a noticeable whine under load at 60-75 mph.... regardless of temp. The dealer checked the trans oil and said it’s OK. They are adding two qts today to see if that helps. I doubt it.
For those that don’t think they have an issue, please listen closely at highway speeds. I’d love the hear from owners that have NO gear whine to support my discussions with GM.
Thx to all for your input!
Old Dec 3, 2021 | 12:06 PM
Thera p's Avatar
Thera p
Here’s a cutaway pic of the DCT. I don’t see any spur gears in there.... but they may be out of view.
To Diff Whine ... Common?
Old Dec 3, 2021 | 12:18 PM
RKCRLR's Avatar
RKCRLR
You're right. I had seen this photo and saw the spur gears. However, I didn't look close enough. They appear to be for the LSD and won't be rotating when going straight.
Old Dec 3, 2021 | 01:23 PM
Phil1098's Avatar
Phil1098
They all whine a little at steady state cruise in the 60-70 mph range. Mine has never changed in 4,400 miles and so it's just characteristic of the design. I live with it and it's fine.
Old Dec 3, 2021 | 05:22 PM
Thera p's Avatar
Thera p
I had the dealer add an additional 2 quarts to the tranny as recommended for track use. It seems to have reduced the whine a little bit. I might try add some insulation to get the noise down to a level is not objectionable to me. Not sure what to use or where to apply so need to do some research.
