Sponsored by: CARiD
DCT Fluid
Old Jun 10, 2024 | 12:51 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default DCT Fluid
After contacting the Valvoline Techline, found Valvoline 888705 is an alternative to GM DCT. Also found that 888705 has a 5-year shelf life. Tech line contact 800 832 6825.
Popular Reply
Jun 25, 2024, 06:28 PM
wbear's Avatar
wbear
ACDelco DTC Fluid is advertised as a synthetic blend, Valvoline DCT as a full synthetic. Delco hires someone to make it for them, Valvoline makes it themself. Delco is $21 to $32 per bottle, Valvoline $7.50 to $9.50. Both have FFL-4 on the bottle.
I maybe a fool taking a real chance but I have never been let down by a Valvoline product in 50 years of wrenching so unless there is proof it's damaging something for my $ I'm using it.
I can change it twice more for the same cost and I'm personally confident it will not grenade anything. If the shifting quality is that bad I'll drain it and put Delco in.
I'll be doing the first engine oil change and DCT canister filter soon at 1500 miles. I'll be sending the oil to Blackstone for a baseline and I'm tempted to send the fluid too.
Yeah, I like to live dangerously
Old Jun 10, 2024 | 01:33 PM
Dan Hintz's Avatar
Dan Hintz
Subscribing for the ensuing discussion
Old Jun 10, 2024 | 08:24 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Don't think I'd use anything but the recommended fluid while the dct is still under warranty....
And shelf life isn't going to alter GM's 3 year drain and fill requirement.
Old Jun 10, 2024 | 09:17 PM
Acpantera's Avatar
Acpantera
It will be fine I'm sure...who's trying it first?
Old Jun 10, 2024 | 09:31 PM
itsonlyairandfuel
Amazon.com: Valvoline Dual Clutch Transmission Fluid 1 QT : Automotive Amazon.com: Valvoline Dual Clutch Transmission Fluid 1 QT : Automotive
Old Jun 10, 2024 | 09:51 PM
Kracka's Avatar
Kracka
Some of the track rats already are, with positive feedback thus far.
Just passing the info along; don't shoot the messenger.
Old Jun 10, 2024 | 09:53 PM
Kracka's Avatar
Kracka
$7.18/qt
https://www.rockauto.com/en/moreinfo.php?pk=13651281
Old Jun 10, 2024 | 10:17 PM
itsonlyairandfuel
Already have supplies to do the 3 year change, next time I think I will change it yearly if I use Valvoline.
Old Jun 11, 2024 | 02:30 PM
sean.b's Avatar
sean.b
good post for posterity.. once there's c8's without warranties.
Old Jun 11, 2024 | 04:08 PM
Jacques Albrecht's Avatar
Jacques Albrecht
The British have a saying that would apply here: "Penny wise & pound foolish"
Old Jun 11, 2024 | 04:15 PM
RKCRLR's Avatar
RKCRLR
While I wouldn't use the Valvoline fluid while my DCT is within the GM Powertrain warranty or Platinum Protection Plan periods I'd consider using it if other people are using it without adverse effects. Sometimes the effects of using the wrong fluid can be subtle. Strange noises, weird shifting, clunky operation, etc. which can be rectified by switching back to the correct fluid. It will be interesting to see how this fluid works out in the long run.
Old Jun 11, 2024 | 06:57 PM
ArizonaZ06's Avatar
ArizonaZ06
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
I've run the Valvoline 888705 FFL-4 from RockAuto at 7.58qt. since my 3 year last July 2023 with 7100 miles since.
At $60qt at a dealer, come on. At that difference I'll probably just only do a full fluid change in a few months.
Old Jun 11, 2024 | 07:22 PM
Andybump's Avatar
Andybump
I had a new 1987 honda accord. Eventually, I replaced the automatic transmission with another well recognized and respected brand of the correctly rated transmission fluid. The shifting was funky. I then put the Honda brand fluid it, and it made a difference, the car shifted perfectly. Lesson: there can be important differences in lubricants that are not evident based on published "standards". But, in the case of the C8, is there any actual published standard for the transmission fluid? Some of the GM documentation still lists a Fuchs Titan product doesn't it? But no "standard" I'm not sure one would know how to pick a different fluid. By the way Amsoil also recommends a product for the C8. I did not check further, but I'll bet others do too.
Old Jun 11, 2024 | 09:16 PM
Kracka's Avatar
Kracka
Redline, Amsoil, Valvoline, Pentosin, etc.
FFL-4 is the specification I've seen referenced, as stated on the ACDelco bottle.
Old Jun 11, 2024 | 10:15 PM
RKCRLR's Avatar
RKCRLR
Does the Valvoline DCT fluid meet a FFL-4 specification? Does it specifically say it can be used in the C8 DCT? Or does it say something like "can be used in DCTs that require FFL-4 fluid"?
Old Jun 11, 2024 | 10:18 PM
Kracka's Avatar
Kracka
VALVOLINE DCT
"Recommend for use in: FFL-4"
REDLINE DCTF
​​​​​​"OEM Compatibility
Suitable for:
AC Delco 10-4130
FUCHS Titan EG FFL-4
GM 19418016"
Old Jun 11, 2024 | 10:21 PM
RKCRLR's Avatar
RKCRLR
It just worries me when a fluid states it can be used to replace a bunch of different specifications.
To DCT Fluid
Old Jun 11, 2024 | 10:24 PM
Kracka's Avatar
Kracka
Don't read the back of a motor oil jug
Old Jun 11, 2024 | 10:28 PM
Andybump's Avatar
Andybump
Who writes the specification? For a while I just thought it was part of a name like Pentosin FFL-4 or FFL-3, or Castrol GTX, Mobil 1 ESP x3 or Mobil 1 ESP x4.
Old Jun 11, 2024 | 10:30 PM
Kracka's Avatar
Kracka
I think the simple answer is, if it's a concern, the OEM ACDelco is the safe choice.
Is there better available? Probably... Which one is it? Who knows! I've personally had great experiences using Redline transmission fluids and gear oils in other applications (including my C7). I've also been impressed with Valvoline's in-house R&D lab facility in Kentucky. Will I try either of their DCT fluids in my C8? Who knows...my car is at the dealer now for the 3-year DCT service so I'll think about it come 2027.
