C6 Corvette Z06 Owner Seeks Header Insulation Input
By -
C6 Corvette Z06
Corvette Z06 engine bays can get very hot, but there are several options to reduce temperatures.
If you are looking to add power to your C6 Chevrolet Corvette Z06, replacing the stock exhaust manifolds with headers is a good place to start. The problem with headers is that they can cause increased engine bay heat that can cause problems with plug wires, air conditioning lines and more. Fortunately, there are multiple options for insulating the headers on your C6 Z06, but which one is right for you?
A similar question was posted in the C6 Corvette Z06 & ZR1 section by “Twill45”. He recently purchased headers for his Z06 and he is wondering whether ceramic coating is worth the cost. According to the input from the community, some form of heat insulation is all-but-essential to prevent other issues.
Corvette Z06 Header Question
When the OP first posted his question to the forum, he talked about his Corvette, the headers that he purchased and how he uses his vehicles before asking a series of questions about coatings.
Tried searching the forum first and didn’t find a concise answer.
Recently acquired a set of 2 inch ARH headers for my Z06 and am debating if ceramic coating is needed or not. Car will be used 70% street and 30% HPDE/AutoX etc.
To those of you who did not coat your headers, do you regret it? What issues did you encounter? What precautions did you take?
To those of you who did coat your headers, did you notice any improvements?
He didn’t share any pictures of his car or his new headers, so we have included some GM images of the C6 Z06. The pictures showing headers were shared in the original thread by members in the discussion.
C6 Corvette Z06
Thumbs Up from the Community
The first person to reply was “EViL427”, who has experienced heat issues with his Corvette Z06.
I had a lot of problems in the Houston, Texas summers in my Z06. The headers were running too close to the A/C lines, causing them to go overpressure, cutting off the A/C. When I popped the hood to vent heat, the problem stopped. So it was either get a vented hood or ceramic coat the headers. I chose the latter, and never had another problem with the A/C.
So if you’re in a really hot environment during the summer, I would personally recommend it to cut down underhood temperatures.
The first person to share a picture of his own headers was “NotreOkc”.
For the price it costs, it was a no brainer for me. I ceramic coated my 1 7/8 ARH. Not only for the heat as Evil427 mentioned (I live in North Dallas) but I did not want to deal with discoloration and corrosion down the road. Aesthetically it just looks good too!
Coated Corvette Z06 Headers
The next to share a set of coated headers was “Uncle Meat”.
My Kookscame Jet Hot coated from the vendor. Was a no-brainer for sure. They look great too!
Finally, “Over-Rev” shared a picture of his headers with titanium coating.
Definitely worth it. ARH 2” with Jet-Hot 2500 titanium coating. There are different colors available with this coating, you can also go over it with a high temp paint and get any color you want.
I like the titanium because it looks more natural. Haven’t installed it yet so I can’t compare coated vs non coated, but the look and durability of the coating is definitely top notch.
Titanium Coated Headers
Header Wrap is Another Option
There is definitely a strong case for ceramic or titanium coating headers in a C6 Corvette Z06, but there is another option. The lower-tech header wrap, which has been around forever, is less expensive and can be done by a patient owner at home. The downside is that it doesn’t look as fancy as the bright, polished coatings.
Header wrap was supported by “SpaceMe1117”, who has used multiple different types.
I have had bare metal, ceramic coated, and currently have wrapped (lava rock based) headers. For a tight engine bay, ceramic coated or wrapped headers is the way to go.
On my C5, the bare metal headers were cooking and drying out the wires on the passenger side.
This is not as much of a problem on the C6 as there is factory heat insulation on some of the wiring. But on my C6 GS, I decided to wrap my headers in lava rock based wrap instead of ceramic coating. I find the wrap does a much better job of reducing the heat. It is a bit time intensive and takes patience to wrap headers but it works great and is a few hundred dollars cheaper.
But ceramic coating can look great in an engine bay.
Corvette Engine
However, “Unreal” has a concern about wraps.
Big down sides to wraps is fire hazard and cars burning down. To me, not even close to worth the risk.
…as the wraps suck up any leaking oil, and become fire hazards. A leaking valve cover gasket turns from a minor annoyance to a burnt down car.
I’ve blew a valve cover gasket about 2 months ago, spewed oil all over the headers. If they were wrapped, my car probably would have burnt to the ground.
If you have input on coatings or wraps to help keep some heat out of the engine bay of a C6 Corvette Z06, click here to participate in the thread.
Join the Corvette Forums now!
"Before I was old enough to walk, my dad was taking me to various types of racing events, from local drag racing to the Daytona 500," says Patrick Rall, a lifetime automotive expert, diehard Dodge fan, and respected auto journalist for over 10 years. "He owned a repair shop and had a variety of performance cars when I was young, but by the time I was 16, he was ready to build me my first drag car – a 1983 Dodge Mirada that ran low 12s. I spent 10 years traveling around the country, racing with my dad by my side. While we live in different areas of the country, my dad still drag races at 80 years old in the car that he built when I was 16 while I race other vehicles, including my 2017 Dodge Challenger SRT Hellcat and my 1972 Dodge Demon 340.
"Although I went to college for accounting, my time in my dad’s shop growing up allowed me the knowledge to spend time working as a mechanic before getting my accounting degree, at which point I worked in the office of a dealership group. While I was working in the accounting world, I continued racing and taking pictures of cars at the track. Over time, I began showing off those pictures online and that led to my writing.
"Ten years ago, I left the accounting world to become a full-time automotive writer and I am living proof that if you love what you do, you will never “work” a day in your life," adds Rall, who has clocked in time as an auto mechanic, longtime drag racer and now automotive journalist who contributes to nearly a dozen popular auto websites dedicated to fellow enthusiasts.
"I love covering the automotive industry and everything involved with the job. I was fortunate to turn my love of the automotive world into a hobby that led to an exciting career, with my past of working as a mechanic and as an accountant in the automotive world provides me with a unique perspective of the industry.
"My experience drag racing for more than 20 years coupled with a newfound interest in road racing over the past decade allows me to push performance cars to their limit, while my role as a horse stable manager gives me vast experience towing and hauling with all of the newest trucks on the market today.
"Being based on Detroit," says Rall, "I never miss the North American International Auto Show, the Woodward Dream Cruise and Roadkill Nights, along with spending plenty of time raising hell on Detroit's Woodward Avenue with the best muscle car crowd in the world.
Rall can be contacted at QuickMirada@Yahoo.com
