Transmission Fluid Check: How-To Spotlight
By -
Chevrolet Corvette Drivetrain
Do not take for granted the fluids that make your Corvette move and function properly.
Most people are fully aware of the engine oil and the requirements and routine maintenance required to keep your car moving. Engine oil is the lifeblood of any vehicle. But if engine oil is the lifeblood, where does transmission fluid stand? If your answer is not “a close second,” then this may be an important item for you to read. One could consider transmission fluid the synovial fluid of your Corvette.
Corvette Manual Shifter
For those of you who have not pulled up Google yet, synovial fluid is what reduces friction around the joints in your body during movement. Without it, your bones would grind together while you tried to move. Does not sound fun to us, either.
CHECK OUT: How to Inspect Your Transmission Fluid
So how do you know if you need to change your transmission fluid? That’s where today’s How-To Spotlight comes into play. We want to teach you the proper way to check your transmission fluid. It’s a process takes a bit of patience, and you cannot skip or swap any steps along the way. There are no shortcuts with these steps. Hopefully, all you need to do is change your fluid. Worse case would be your having to replace gears or the transmission itself.
You can read through the article right here. Unfortunately the process is not quite as easy as it is for checking other bits on your car. With enough checks, however, you will learn to be comfortable in your capabilities. Let us know how it goes.
