Sponsored by: Innova
Old Mar 25, 2015, 01:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Android Head Unit & Backup Camera Installation
Old Mar 9, 2018 | 11:47 AM
  #481
LuckyC's Avatar
LuckyC
Default Thanks
[QUOTE=doomi;1596749542]Not sure where his came from but check out the below. It's a corvette wallpaper creator with quite a few options.
http://solidlystated.com/design/corvette-logo-mobile-wallpaper-generator/[/QUOTE
That'll work..I want a nice one in installing the new head unit thus weekend and would love a nice logo to make it look like a factory head unit..
Old Mar 9, 2018 | 04:41 PM
  #482
bjmsam's Avatar
bjmsam
Originally Posted by LuckyC
That's a nice logo where did you get it ..
See this post.
Old Mar 9, 2018 | 04:57 PM
  #483
LuckyC's Avatar
LuckyC
Default Thanks
Originally Posted by bjmsam
This site generates customized backgrounds:
That's a nice one..almost looks like it's stock.
Old Mar 9, 2018 | 11:22 PM
  #484
Dave70's Avatar
Dave70
How does the the backup camera that comes with the pumpkin work? would i be better off buying a better one or is this one fine? also the external mic. I know they are not all created equal.How does the one that comes with the unit preform?
Old Mar 10, 2018 | 01:51 AM
  #485
pierrel's Avatar
pierrel
There is no dedicated amplifier trigger wire, so connect the HU red ACC wire to the PAC red ACC wire and the PAC blue/white AMP wire.
On the GA2170 unit there is a blue/white wire coming from the HU saying "AMP CON". I soldered that to the blue/white from the PAC unit "Connect to remote wire from aftermarket radio for audio output".
Maybe I'm wrong here, and should do like bjmsam told us?
Old Mar 10, 2018 | 09:27 PM
  #486
downhil's Avatar
downhil
That is is how I wired mine up and all is working appropriately.
Old Mar 14, 2018 | 10:38 PM
  #487
downhil's Avatar
downhil
Finished up. I had, then lost the chimes; and now hear a very very faint electronic buzzing sound with the volume almost off, so I think I need to pop the console back off and regroups. Had a faulty PAC RP5GM11 that caused some heartburn, but the second one seems to be working.
Old Mar 15, 2018 | 05:11 AM
  #488
bjmsam's Avatar
bjmsam
Originally Posted by downhil
[left]Finished up.
Looks great! Enjoy.
Old Apr 5, 2018 | 11:25 AM
  #489
downhil's Avatar
downhil
CarPlay works.
Old Apr 5, 2018 | 06:55 PM
  #490
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
On the GA2170. How did you hookup the steering wheel controls?
Mine is currently at:
GA2170 SW+ to pin 6 on the PAC (Yellow)
GA2170 SW- to pin 7 on the PAC (Green/White)
And not working yet...
Old Apr 5, 2018 | 10:57 PM
  #491
pierrel's Avatar
pierrel
See below. I did this and then mapped the buttons within the head unit itself. Its somewhere in the settings menu i believe, cannot remember right now as its 04.50 AM where I'm at
Congrats! I hope you like it.
1. Correct. The HU does not have a dedicated amp trigger. The HU antenna trigger can be used as such, but there is a chance that it is not energized in some non-radio HU modes. GA2170 does have a blue trigger wire - just connect it with the PAC wire
2. Correct. The PAC harness brings its power in on the yellow wire and loops it back out on pin 6 to power the car SWC (purple wire on the car side of the connector). I believe yellow is constant power rather than switched, so I didn't care for that approach anyway (why energize the car SWC resistor tree when the ignition is off?). Cut that loop and connect the outbound yellow wire on pin 6 to the KEY1 wire. The SWC circuit becomes:
HU KEY1 <--> connector side PAC yellow pin 6 <--> car SWC purple pin 6 (+)
HU GND <--> connector side PAC green/white pin 7 <--> car SWC dark blue pin 7 (-)
1. No, the PAC SWC setting becomes irrelevant. I left mine set to 0 which PAC should have implemented as an unmolested pass-through to eliminate the need for this step.
Old Apr 8, 2018 | 04:41 PM
  #492
Coupe89's Avatar
Coupe89
Got it to work:
GA2170 SW1 to pin 6 on the PAC (Yellow)
..................... pin 7 on the PAC (Green/White) to ground
Old Apr 9, 2018 | 01:53 PM
  #493
billmoore48's Avatar
billmoore48
Default Chimes???
Got everything working but chimes... The connector is in the right spot on the PAC RP5 GM11 device, plugged into the "chimer", rotated volume to all levels, no ding-ding! Any ideas?
Thanks in advance...Bill
Old Apr 19, 2018 | 01:48 PM
  #494
downhil's Avatar
downhil
Old Jun 9, 2018 | 09:36 AM
  #495
partisan's Avatar
partisan
Looks great! And you did a nice job documenting it all in your thread.
Old Aug 1, 2018 | 11:05 AM
  #496
Mammoth's Avatar
Mammoth
4th Gear
Default Thanks OP
PUMPKIN Android 8.0
Thanks OP, this thread helped me install a new head unit in my C6. If anyone is looking to do it know it’s a big task but very much worth it!
PUMPKIN Android 8.0 Car Stereo Double Din 4GB with GPS and WiFi, Android Auto, Support Fastboot, Backup Camera, 128GB USB SD, 7 inch Touch Screen
PAC RP5-GM11 Radio Replacement Interface
NOAUKA Waterproof IP68 Night Vision 170 Degree Car Rear view/Reversing/Reverse Camera
Metra 95-3304 Double DIN Installation Kit for Select 2005-2006 GM/Chevrolet Vehicles (Black)
Old Aug 7, 2018 | 06:19 PM
  #497
keithd's Avatar
keithd
Does Android Auto or that screen mirroring feature work?
Old Aug 7, 2018 | 06:52 PM
  #498
Mammoth's Avatar
Mammoth
4th Gear
So I don't have an Android phone so I can't speak to Android play. But I can speak to the screen mirror and that works but I don't use it as all the feature with Android app it is more than sufficient for what I need I'm actually replying to this message in my car using Voice to text.
Old Aug 7, 2018 | 07:05 PM
  #499
doomi's Avatar
doomi
It has both.
But with full Android OS I've never found a reason to use them. I'd rather use the OS on the head unit than mirror my phone.
