Sponsored by: Innova
Suggestion for a Headunit from DD Mods
Old Sep 10, 2017 | 10:27 PM
  #161
-=Jeff=-'s Avatar
-=Jeff=-
No I don't have a PS5.. I did at one point years ago.. sold it.
I can fix caps (easy enough) but it would just be for a bench
Also I think I am going to buy the add on tuner for SXM.. Since i will have the car apart for install, now is the time, then I have the capability if i choose it, I have SXM free until Dec on my Daily car, at that time maybe I can get a deal on another year...
for $45 I think it is worth it as I have GM LAN Adapter I can sell for for that much
Old Sep 11, 2017 | 02:39 AM
  #162
racebum's Avatar
racebum
so
the 960 hdmi comes with the xm kit
i have a 960hdmi and no interest in xm
how's 35 shipped? it's the sxv300 with the antenna and cable to attach to the deck, round din cable, all new in the bags
Old Sep 12, 2017 | 10:34 AM
  #163
-=Jeff=-'s Avatar
-=Jeff=-
Antenna placement?
My current radio has the GPS antenna under the dash pad and seems to work well, So do you think i can do the same with the XM antenna? I would prefer not to have to run it to the outside of the car. I also thought right on the edge of the dash closest to the windshield.
Old Sep 12, 2017 | 12:32 PM
  #164
carls2004's Avatar
carls2004
Antenna placement?
I have mine under the center grill, next to where center speaker use to be and it is working fine..
And i also put my sirius antenna under there to, but i dont have that activated as im not paying for something i'll hardly use..
Old Sep 12, 2017 | 12:39 PM
  #165
-=Jeff=-'s Avatar
-=Jeff=-
Yeah I know the GPS will work without issue, I was wondering about SXM.. like you I will install it, not sure I will activate it yet..
Old Sep 12, 2017 | 03:19 PM
  #166
racebum's Avatar
racebum
Antenna placement?
sadly no. XM always has to unobstructed. you can experiment with placement but it's no where near as forgiving as gps. i sent you their most current antenna with the receiver kit. carl's grill idea may be worth a shot...oh wait. c4 dash is solid on top....
Old Sep 12, 2017 | 04:22 PM
  #167
-=Jeff=-'s Avatar
-=Jeff=-
Not completely. I will put it on the Defroster vent then.. it can sit in place of the sensor for C68 AC, I have C60
Old Sep 12, 2017 | 06:16 PM
  #168
-=Jeff=-'s Avatar
-=Jeff=-
What about USB for music. I have a USB 3.0 64gb. Does it take a while to scan? Is there a suggested directory structure?
Old Sep 13, 2017 | 06:31 PM
  #169
racebum's Avatar
racebum
just put the music in a folder with a name you will remember, by artist, album, show etc
scan is instant. i leave mine plugged in all the time stached in the glovebox.
Old Sep 13, 2017 | 06:41 PM
  #170
dmaxx3500's Avatar
dmaxx3500
the roof is the best place for the antenna,,it needs a full look 360 degs
Old Sep 13, 2017 | 07:15 PM
  #171
-=Jeff=-'s Avatar
-=Jeff=-
Yeah it rebooted a couple times while trying to scan. I am under the limit which is 10k folders and files.. I might be at 4K. I am trying a USB 2.0 device
I get it and realize that. There is no real good spot on a C4.
Old Sep 13, 2017 | 08:51 PM
  #172
-=Jeff=-'s Avatar
-=Jeff=-
Swapped to a USB 2.0 and worked without issue..
here are a couple pictures, this will not get installed now until December, unfortunately
Old Sep 14, 2017 | 03:21 PM
  #173
racebum's Avatar
racebum
i've had no issue with usb 2.0 or 3.0 drives. could just be one drive you have it doesn't like if there was an issue
Old Sep 18, 2017 | 12:36 PM
  #174
02BlownZ06's Avatar
02BlownZ06
I put about 8000 songs in AAC format on a 256 gb usb drive and upon plugging it in, the 960 showed all the songs but they weren't available organized by album or artist. In the meantime it continued to say "Loading...." at the bottom of the screen. It took about a half hour of driving around before it quit loading and the songs were available by artist, so it wan't instant for me at all. Since then, no issues, though.
I don't know if it makes a difference or not, but I go into the folder properties on the usb drive and format it for music, also.
Old Sep 18, 2017 | 04:29 PM
  #175
racebum's Avatar
racebum
you have to make folders on your pc, put what you want in each. the folders will all show up. i have never had to use a music format as the deck works great with just files
so basically name your folders what you will. put what you want in each then you should see all those folders
Old Sep 18, 2017 | 10:54 PM
  #176
Ward Cleaver's Avatar
Ward Cleaver
Southern Piedmont Area
I had a high end Pioneer (AVIC-7200) and swapped it out for an Alpine INE-W960...
...the difference in sound quality is incredible.
I'll withhold any comment concerning your amusing subjective anecdote about sound quality, but I'm just curious...
Why would you remove a high end Pioneer AVIC-7200NEX head unit with HD radio and replace it with a cheaper non-HD unit with a smaller screen?
Regards,
-Ward
Old Sep 18, 2017 | 11:05 PM
  #177
TorchRedFred's Avatar
TorchRedFred
Regards,
-Ward
There was a whole thread on this. If you are judging based on sound quality, many will argue that the Alpines out perform most other brands.
https://www.corvetteforum.com/forums...-ine-w960.html
Myself, I have a Pioneer 8200.
To Suggestion for a Headunit from DD Mods
Old Sep 19, 2017 | 03:34 AM
  #178
racebum's Avatar
racebum
Regards,
-Ward
you basically ran your mouth before doing even one iota of research
if you're a "feature buyer" you're never going to get it
i'm somewhat convinced different people have different abilities in regards to hearing. some people really can't tell a difference and this is more common with receivers. people buy features for HT. if you go to a hi-fi shop it's completely different. you find people who can hear. who do notice the difference. if you can't and you see sound as "subjective" it's going to be an apples and oranges discussion. subjective is B&W vs martin logan. different sounds but both good. threshold vs mcintosh. different sounds, both good. that's subjective. some people lack the ability to differentiate tone to the same degree as others. if you can't hear these fine details on the one hand i see it as sad you're missing out but on the other you have no idea what you're missing.
pioneer has no focus on SQ and is all about the features. alpine is one of the lone standouts making a deck with a fairly balanced pre out that does not require a dsp to try and correct. a dsp can improve it but it's not that bad without. mated with a quality amplifier and decent speakers there is a very pronounced SQ difference between alpine and pioneer.
Old Sep 20, 2017 | 02:46 PM
  #179
02BlownZ06's Avatar
02BlownZ06
I couldn't have said it better myself. Yes, I went down in features but the improvement in sound quality is literally night and day. I mean it's not even close. It's like comparing a Yugo to a Porsche. I know I am not the only one that has heard the difference. Note, I do not have DSP, just the head unit going directly to two amplifiers with mids and tweets front and rear and 2 10 inch subs in the back.
Old Sep 22, 2017 | 08:00 AM
  #180
-=Jeff=-'s Avatar
-=Jeff=-
So I have a DSP, it ia temporarily wired. When I get to install my Alpine i will not wire the DSP and see how it sounds. I will then mount the DSP where I want it and wire it in
Unfortunately I need to get my foot fixed and I will not be able to move around easily for the 6 weeks (Approx) then I might be able to work on the car. I might find time to remove the Dash pad this evening
