i have been reading many posts about what people used and havent really made a decision on what i would like to install.
Does it sound better to get 6.5 components for the lower, put the tweeter up on the a pillar, and install a new upper with a 3.5" speaker? Or just put the tweeter in the 3.5" spot using some sort of adapter and the 6.5 in the door sub spot? I am looking to spend somewhere between $200 to $300.
It will be personal preference on whether you prefer the high door or dash tweeter location. The dash location will be "brighter" and have more reflections (diffraction, really) coloring the image. I run a set of large format tweeters in my upper door positions and get fantastic imaging as a result.
Either way, I'd skip the 3.5" altogether and run a good quality 6.5" midrange on a solid adapter in the door. Powering them from something other than the factory Bose crap is key too. Even head unit power from an aftermarket radio is better than the over EQ'd and under powered Bose amp. Better yet, put them on a clean external amplifier fed by pre-outs from a decent head unit.
Make sure your mounting adapter is RIGID and sealed to the door as much as possible to get best results. I actually have the back sides of mine sealed around the midrange too, but many people just seal the whole door cavity (there's a giant hole further back on the door panel). My setup puts the mid in a smaller enclosure volume vs using the whole door cavity, but both can work fine.
Thanks for the info I will look into getting a good seal around the adapter for the 6.5s. What adapter is used for the tweeter in the 3.5" spot?
I prefer lots of midbass and clear vocals. I achieved this by going with a 3way setup and dynamat on the doors. 10" woofer/midbass/ 3" midrange, and 3/4" tweeters.
I think im leaning more towards the tweeters in the upper door and 6.5 in my lowers. Got the dynmat ready though! I guess my next question would be what metra adapter works in the door panel for c6? Will it be specific to car ?
Metra 82-3014 speaker plate adapters for the lower door to hold the 6.5" speaker. And Metra 82-3015 speaker plate for the upper 3.5" speaker location. You will need to cut a hole to hold the tweeter.
Edit: You can get both from Amazon. Also ignore the description where it says C7 2013 for the tweeter adapter.
lol thats a big reason why i posted on here to check what adapter should be used because i came across that but it said c7 and i couldnt find a c6 one. Thanks for the help!
All have great reviews but its been a LONG time since i have purchased speakers and best buy by my house does not carry any of these so that i could listen to them.
You cannot do this on a C6 from what I understand. Otherwise, which 10" woofer do you have that fits in the door?
I have mb quart discus 10" shallow mount. For the price, it was worth a shot, and they sound damn good. Since it is dedicated for midbass, i'm not worried about vocals, the 3.5" mid takes care of that. I don't think it would sound this good without the dynamat, though.
here is my install, not very detailed, but you'll see.. C6 Build
Link to speakers on sonicelectronics: MBQuart
You can also use PIONEER TS-SW2502S4 without having to make a trim ring. This was done on a C7, but it's the same size as the C6: C7 Build
Apologies. The sheet metal is too thin to support a sub, it'll vibrate and rattle all to hell. I know for a fact because I could make my 6.5" vibrate the sheet metal at the right frequency and power level. Also, the largest I'd run is an 8" driver (but NOT a sub) in a reinforced adapter if it was mid-bass I was chasing.
