custom engine bay in progress (many pics)
Old Jan 28, 2009 | 12:54 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
Default custom engine bay in progress (many pics)
follow along as my engine bay is transformed into functional art. many of you may have seen my other thread on my interior. here is a link. http://forums.corvetteforum.com/c3-g...many-pics.html this just the beginning and i will be posting pics as it progresses. the suspension is going to be replaced with the vbp performance plus system so ignore the well used parts that are in the photos. the headlights are custom and are going to be mounted behind a custom grill. the weight savings so far has been amazing. even after the custom work is done the car will still be quite a bit lighter. i will have a final weight posted when the car is finished. there will also be two electric fans mounted behind the fender covers to help move air through the engine bay. there will be an opening cut on each side for the airflow also. the headlight mounts will also be constructed to help support the front end. here are a few photos of beginning stages. the goal is to keep the entire car flowing together.
Old Jan 28, 2009 | 01:02 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Can't wait to see.......
Old Jan 28, 2009 | 01:57 AM
68 NJConv 454's Avatar
68 NJConv 454
Humm thats new on a c3. not bad i kind of like it
Old Jan 28, 2009 | 02:55 AM
Frogday's Avatar
Frogday
It looks like there isn't much room for suspension travel. Is the upper control arm going to have enough clearance when the suspension compresses?
Old Jan 28, 2009 | 04:19 AM
thegavel's Avatar
thegavel
Jeez,and I had troubles installing the A-Arm dust covers !!!!!
Great job(So Far, So Good)
Keep us updated PLEASE.
CHEERS from Downunder
GAV
Old Jan 28, 2009 | 08:00 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
yes the aftermarket control arms sit much flatter and give me a lot more clearance than the stock ones that are on there now. once the new suspension is on we will test it and adjust the cut out if needed. i also have several rubber strips that will be going behind the opening to keep down the road grime and sand.
Old Jan 28, 2009 | 09:41 AM
7T1vette's Avatar
7T1vette
How do you relieve the trapped engine heat?
Old Jan 28, 2009 | 09:49 AM
pbcanney's Avatar
pbcanney
where the wishy washy bottle going?
Old Jan 28, 2009 | 10:21 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
there will be cuts in each side panel with a trans. cooler fan behind each directing airflow to the side vents.
Old Jan 28, 2009 | 10:29 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i have custom tanks that will be mounted either behind or possibly on the outside of the covers. depends on what looks the best during mock up.
Old Jan 28, 2009 | 10:33 AM
OURSHARK's Avatar
OURSHARK
This will be a very interesting build. Keep us posted, it will be fun to watch.
Old Jan 28, 2009 | 10:35 AM
kortensi's Avatar
kortensi
Old Jan 28, 2009 | 10:41 AM
SuprJames's Avatar
SuprJames
The big question.....what are you going to do with the ugly wiper motor?
Old Jan 28, 2009 | 11:09 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
so i am going to hide it! there will be an aluminum section covering it. the templet is already made. it will be the last piece made. we will be starting on it tonight if everything else goes as planned for the other pieces. last night the metal sheer broke so i had to go get a new one.
Old Jan 28, 2009 | 06:47 PM
7T1vette's Avatar
7T1vette
Old Jan 28, 2009 | 08:34 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Diggin it bro, I think it will look killer when complete!
Old Jan 28, 2009 | 09:13 PM
danboback's Avatar
danboback
This could be really cool, if the craftsmanship is on par with the other thread it will be awesome!
To custom engine bay in progress (many pics)
Old Jan 28, 2009 | 09:16 PM
tak82's Avatar
tak82
I just come back from looking at the custom int. of the car, I'll have to say it all looks great. I really like the way the engine compartment is looking. Very unique.
Old Jan 28, 2009 | 09:33 PM
InternalBleeding's Avatar
InternalBleeding
Should be interesting.
Old Jan 28, 2009 | 10:20 PM
aussiejohn's Avatar
aussiejohn
GREAT work!!! I see you're in Florida, so you probably don't need a heater, but what about AC? I noticed your pass side shield and heater block off plate would make it impossible to fit an AC unit without some severe cutting. Also, as you are running electric fans, what about a spreader bar in there?
Keep up the good work, and show more photos when ready.
Regards from Down Under
aussiejohn
7 months to go
