C3's with 18" wheels only thread
Old Nov 30, 2013 | 11:16 PM
  #321
vette427-sbc's Avatar
vette427-sbc
Originally Posted by 509 rat
just my two cents, for all you guys running the taller wheels, get some bigger roters to match, does not look good.its like going to a restaurant and getting a large plate delivered to you with just a kernel of corn in the middle, I hope you all get this, cus if you don't, well I will stop here ..
Kinda like if you were to build a big block, and stop at 509ci instead of say a 598 or even bigger
Not sure if you have priced a proper 13"+ brake kit but they arent cheap! (just like bigger cube BBCs!)
Old Dec 1, 2013 | 01:44 AM
  #322
mac79vette's Avatar
mac79vette
Originally Posted by Sidepiper
18" rallies
The car has been on my lift for 6 months so it needs to settle.
Can we get more information on your wheels please?
Old Dec 1, 2013 | 03:59 PM
  #323
Vette5X's Avatar
Vette5X
Originally Posted by dmeesq
I'm not typically into mods but IMO this car looks great. Nice job!
Old Dec 2, 2013 | 03:55 AM
  #324
Swimtexan's Avatar
Swimtexan
Ditto
Old Dec 2, 2013 | 08:07 AM
  #325
gdh's Avatar
gdh
Originally Posted by Swimtexan
Ditto
X2. Are they the new AR aluminum 18"? What size tires are you running? I had talked with a rep a few months ago and he had said the AR ralleys are 2 pc.
http://www.customwheelsexpress.com/c...els-p-849.html
Old Dec 2, 2013 | 09:51 PM
  #326
509 rat's Avatar
509 rat
Default I agree
not cheap at all, im gathering all my parts right now.im going to run 335 18s with 315s up front, vansteel coil over suspension,with a big break kit.
Old Dec 2, 2013 | 11:49 PM
  #327
Bangkok Dean's Avatar
Bangkok Dean
I finally took some pictures this weekend with the new 18 inch wheels and tires.
Old Dec 10, 2013 | 11:31 AM
  #328
TedH's Avatar
TedH
Is there a complete list of all of the wheel specs, back-spacing, tire sizes and suspension modifications (or no mod) required to fit all of the wheels in this list?
So many choices, it is overwhelming.
I really LIKE the gray spoke torque thrust with (brushed aluminum?) perimeters... in 17" or 18". Sure would like to know the ID # and specs to fit them under my '80 L48 with no changes to my suspension.
Old Dec 10, 2013 | 09:35 PM
  #329
Beyond Budget's Avatar
Beyond Budget
Default Measure a thousand times, buy once.
A compilation of what our members have as far as wheel/ tire fitment wouldn't be a bad idea. If you look at your current configuration and measure your clearances underneath and at your fender. Taking into account your suspension travel. You should come up with a size that will work. Just remember that the tires that you go with my stick out past your wheel. Tire rack has the specs of tires that will tell you the over all width and the tread width.
Old Dec 10, 2013 | 10:04 PM
  #330
68/70Vette's Avatar
68/70Vette
Originally my plan was to use 18x9 1/2 on the rear with a 285 40 18. I have been looking at about 5 different wheels and the only one that both my wife and I like are the American Racing Rally wheel. They do not offer it in 9.5 in but in 9 or 10. Will a 10 in wheel with a 5.5 in back spacing work? I do have Van Steel off set T arms. Her is a photo of the rim.
These wheels look like the wheels I bought from..Wheel Vintique or Billet Vintique...Can't remember since they changed their name. The wheels look pretty much like stock wheels with the beauty rings..when you look at them from about 6 feet away. They don't have beauty rings, just polished aluminum. I bought a set of four for the 68 and paid about $2500. I easily would have considered buying another set for the 70 but for one thing. The little hat cap disks are made of flash chrome plated steel.......stock was stainless steel. The hat caps will rust very easily. The hat caps cost about $70 each, I've bought two extra just to try to keep the 68 looking nice. If it wasn't for these really cheap flash chromed plated hub caps I would have bought another set.
I suspect it was perhaps patents or something.. The stock stainless hub caps from C3's will not fit on these Rallye Wheels. You have to buy their cheap made in China hub caps that will rust in the bink of an eye.
Old Dec 13, 2013 | 10:08 PM
  #331
VCuomo's Avatar
VCuomo
Another rim/tire dummy here who owns a '72 and a '73...
So for those of us who don't want to have to make any mods, after reading through the posts in this thread it looks like this will work for the rims:
Front: 18x8 with 4 inch backspace
Rear: 18x9.5 with 5 inch backspace
Am I correct that no mods would be necessary, including no e-brake bracket mods?
If so, what size tires will work with those rims and not cause any fender or frame rubbing? Would these work:
Front: 245/45/18
Rear: 285/40/18
Basically, can anyone suggest the complete set of specs for a rim/tire "dummy" like me to purchase that won't require any mods but will allow me to purchase readily-available rims and tires for "spirited" () street use?
TIA!
Old Dec 13, 2013 | 11:02 PM
  #332
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Would these work:
Yes.
Having read this thread, you are no longer categorized a 18" diameter wheel dummy. Now you are "informed".
That size package works for many of us who moved to the 18" diameter wheel. Most with no further mods but bear in mind: your mileage may vary.
You have 90% of the info needed to run what you want. This thread offers the answers to your questions so pick a style and a brand then enjoy.
Keep us posted on your choice and good luck.
Old Dec 14, 2013 | 10:06 PM
  #333
VCuomo's Avatar
VCuomo
Originally Posted by Dustup7T2
... Having read this thread, you are no longer categorized a 18" diameter wheel dummy. Now you are "informed".
Is that the same as saying I now know enough to be dangerous?
You have 90% of the info needed to run what you want. ...
Any insight as to what other things I need to research for that last 10% of info, or is that 10% based on what happens when I try to mount the new wheels?
Old Dec 16, 2013 | 06:26 PM
  #334
mac79vette's Avatar
mac79vette
I spoke to American Racing about the center caps and they claim that on their wheel the factory 68-82 Corvette center caps will work. Most of the Corvette venders do sell the SS center caps.
Old Dec 16, 2013 | 07:59 PM
  #335
Dustup7T2's Avatar
Dustup7T2
It was only intended to say that nothing is perfect and that there are no absolutes in life, except death and taxes, of course.
The final fitment is up to you and the car. No guarantees stated or inferred. If that is what you are asking, then I can only wish you continued success in your future endeavors. Please let us know what choices you've made and show us some digital results, when convenient. You must know that CF members love pictures of your project(s).
As always, the best of luck to you.
Old Dec 23, 2013 | 11:44 AM
  #336
VETFEVER's Avatar
VETFEVER
Bumping
vetfever
Old Dec 23, 2013 | 12:16 PM
  #337
kcarlasc's Avatar
kcarlasc
Coys C5.. 17s on the front and 18s on the back...
To C3's with 18" wheels only thread
Old Dec 23, 2013 | 01:20 PM
  #338
VETFEVER's Avatar
VETFEVER
bumping
vetfever
Old Dec 23, 2013 | 01:24 PM
  #339
kentuckyfan's Avatar
kentuckyfan
7th Gear
Default 18s on my 77 Vette
Old Dec 23, 2013 | 07:40 PM
  #340
stopherjones's Avatar
stopherjones
Default 18" Boss 332's all the way around
Went with 18x9 rear and 18x8 in front....I am happy with them...
