Interior Heat
The headers I will be getting are headman, here's a link to Jegs;
http://www.jegs.com/i/Hedman/500/68308/10002/-1
I have the same heads (L98 882 castings, aluminum D-port, same as ZZ4). What stock manifolds, did you go with? Casting #? I'm curious, as I'm contemplating this as well and want that option as well.
When I had my other 76 back in the early 80's I don't remember the heat like it is now. I was a much younger man then so that may be part of it, and maybe my memory is flawed
But seriously, I'd like to see temps and results from the stock manifold crowd too.
I am, however, going for 1 7/8" Hooker headers now. I just can't live with the fact I'm probably losing 60hp or more through the stock manifold, LOL.
When I get my car back I am thinking about getting some corrugated aluminium heat shield to cover the headers...
http://www.thermalvelocity.co.uk/product.asp?P_ID=476
http://www.nimbusmotorsport.com/Prod...=753&CATID=252
I have seen people use it in direct contact with headers, not sure how well it works in that application. That's what we used to use to heat shield the seatback firewall on the rear engined car (which was an inch or less from the headers). With a bit of effort, should be able to form it around the headers. My problem with it, though, if there's so little airflow through the engine bay (and covering things up will only make it worse), it might just get heat saturated and not be overly effective. Or it might not work all that well if it's actually contacting the headers.
The results, would be another aspect, of how we can possibly fix this, vexing problem!
Maybe several rolls of Reynolds wrap aluminium foil loosely wrapped in 6 or 7 layers would do the same thing, no idea, lol.
EDIT: Actually, don't do that, regular aluminium foil will probably just melt or ignite at the heat your headers get up to, lol.
As you will recall, my car has stock manifolds and will cook you in 45 minutes or so. I just went out and looked, and even the stock manifold is just over an inch away from the steering box. All of you that are thinking of going back to stock manifolds shouldn't bother. It is not the headers that are causing the problem. It is that giant lump of heat generating metal in there with the headers.
If you look at the Chadwick link I posted earlier, he stated an enormous amount of heat was coming in through seams in the plenum on the passenger side. I am thinking that I am going to try that with the windshield sealer in the very near future. The discouraging thing about all of this is that Bob Chadwick spent a huge amount of time and energy trying to resolve this, and stated when I contacted him that he had sold his car because he could not stand the heat and was never able to fully resolve it.
What really has me confused now are that some C3 owners do not appear to have the problem. Maybe we should take a poll of the members to see if it is only certain years that have the issue. I would still like to know if the C2 community has any experience with this as well.
I don't know if there is a way to set up a poll on the forum, but my 74 coupe is basically unbearable after an hour. Is worse at speed with open windows...even worse with the t-tops off. Because of that fact alone, I am convinced that engine compartment heat is flowing in through leaks in the firewall/cowl/floorboards. I will start looking further tomorrow.
John
John
Even then I'll usually crack a window to stop the windscreen getting fogged up
Yeah, my stock exhaust manifold is really bloody close to the steering as well, though I thought that might just be a BB thing.
The stock exhaust manifolds are a lot thicker and have less surface area, so insulate better, that's part of the reason people like to stick with them.
I'm sure I can resolve the heat problem when I get down to it... I'm just not sure if I can do it without modifying my hood (which I don't want to do at the moment because it has a decent coat of paint on it I don't want to damage and I'm not the most artistic person in the world to go inventing new vents), without adding fans that would sound annoying and put a drain on the electrics, and without adding scoops that make front end lift worse.
I also can't do it while my car is not in my possession
I probably won't have time to play with it until Dec or Jan anyway.
Need a longer trip, but so far so good and it got driven hard. Ambient temp was 84 degrees
Big question, did the cabin feel any better? lol
Tudz, you were right on about the radiation stopping dead at the sheet metal. You can easily feel the difference between the one side of the barrier and the other, with your hand, tho' I can now feel the heat blasting upwards and I'm glad the hood vents are there!
The new shield got a lot of adjustments and repeated retrims! It is crude, but served the purpose. More on that tommorow.
John
