Doorgunner's '68 Convertible Project
Old Aug 13, 2015 | 07:18 PM
  #1621
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by Calo69
I expect no more than 3/1000th variance on spacing.........(edited for content).
Sorry, Dude......this is as close as I could get it (I was hot, tired, hungry, sleepy, and my diaper was wet).........
While I was making the short exhaust section, I turned the downpipe 45* away from the oil filter for some extra airflow (not easy to see because of the camera angle)...... and covered the entire section with exhaust wrap........[I]pay no attention to that greasy undercarriage/flaky engine paint---it's on the To-Do-List...LLOL.....[/I.......that's the old exhaust pipe hanging in the background.........]
There it is.........complete with grimy fingerprints and tools spilled neatly out of the "pick-up box"..........
85900
Old Aug 13, 2015 | 08:59 PM
  #1622
Brack c's Avatar
Brack c
Looking good Tony. ,
Steady as she goes . !!!!
I've actually spent the past 3 evenings working on my white ghost of a project . Seems I've gotten the itch again & that's a good thing!!
Old Aug 13, 2015 | 09:44 PM
  #1623
doorgunner's Avatar
doorgunner
That's good to hear Brack! The "hour-a-day" saying works!
Of course......it takes a month to re-install a steering column
Old Aug 13, 2015 | 09:54 PM
  #1624
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
4.5/1000th you sick s.o.b.
Good to see the progress, good luck
Old Aug 13, 2015 | 09:55 PM
  #1625
Richard454's Avatar
Richard454
Doorgunner-
I just wanted let you know the rocker panels on you car are NOT correct for a 68- will loose several points there!!!
I try to mess with my car every evening- just a little bit and at least feel I'm a little closer to getting back on the road!!!
LOOKING GOOD- Carry on!!!
Richard
Old Aug 13, 2015 | 11:21 PM
  #1626
doorgunner's Avatar
doorgunner
Big LOL.......I thought you'd get a kick "outta dat"!
Originally Posted by Richard454
Doorgunner-
I just wanted let you know the rocker panels on you car are NOT correct for a 68- will loose several points there!!! True.....but they ARE CORRECT.....for the '76 nose and '76 tail light panel that the 2nd owner grafted on!
I try to mess with my car every evening- just a little bit and at least feel I'm a little closer to getting back on the road!!! In that case I'm in good shape...my car was "messed with" from front to back/from radiator to transmission crossmember/now I trying to "unmess" with it LOL!
Richard
Old Aug 14, 2015 | 10:17 AM
  #1627
doorgunner's Avatar
doorgunner
Well........I think I have the "hang" of hanging a sidepipe now!
Time to run over to the auto parts store and buy the necessary exhaust adapters to connect the passenger sidepipe.
Let's see if I "can do this" in less than a week (the good news is......the PTSD is still slacked off and is allowing me to get SOMETHING DONE....even if it takes ten times longer than it should)
Old Aug 14, 2015 | 05:44 PM
  #1628
doorgunner's Avatar
doorgunner
Moving right along........I welded the front frame nut in place and attached the forward bracket (hard to see....it's left of the cordless drill).....I also welded the rear frame nut in place and attached the bracket.........
The pipe is roughed-in/hung on the brackets......the clamps need to be set the correct distance apart so that the pre-drilled holes in the heat shield line up with the pre-drilled holes in the clamps.......then I will cut the bottoms off the brackets so they won't be visible
It looks like the car will be getting new rocker panels once the new paint goes on!
That's it for today.
Old Aug 14, 2015 | 05:56 PM
  #1629
SB64's Avatar
SB64
That should make you feel good and it's another thing off the long list that if your like me seems to never end.
R
Old Aug 14, 2015 | 06:21 PM
  #1630
havesometo's Avatar
havesometo
The side pipes look real good.
Old Aug 14, 2015 | 11:57 PM
  #1631
Calo69's Avatar
Calo69
Looks good Gunner, you going metal to metal everywhere? I know some kits come with rubber cushion washers, guess it acts as a vibration eliminator. Knowing you though you'll probably be able to hang the car by the pipes,
Good luck
Old Aug 15, 2015 | 12:03 AM
  #1632
doorgunner's Avatar
doorgunner
R
It was a relief that I got that far in one day....it took four days to hang the other sidepipe (a 1-day mod is taking 10 days.....PTSD SUCKS!)
Calo69: Looks good Gunner, you going metal to metal everywhere? I know some kits come with rubber cushion washers, guess it acts as a vibration eliminator. Knowing you though you'll probably be able to hang the car by the pipes,
Good luck
The kit has the rubber grommets...but they are too flimsy.....I wouldn't be able to lift the car using the sidepipes....LOL!
Thanks....I thought for a year about buying them/finally decided on the "simple-style sidepipes/I'd rather put the funds into "the downpayment/LOL" on new paint rather than on great-looking $1200 stainless header-pipes.
86300
Old Aug 16, 2015 | 04:48 PM
  #1633
doorgunner's Avatar
doorgunner
.............. Knowing you though you'll probably be able to hang the car by the pipes,
Good luck
I'm NOT going to read any more of your replies!
While installing the 2nd sidepipe I didn't like the way the supplied brackets were so easy to bend/reposition....Calo's comment kept rattling around in my head.................
So......I bought 2 feet of 1" X 1/4" thick steel flatbar.....10 minutes later I had a heavy-duty bracket ready to replace the front bracket on the passenger sidepipe.....I'll fabricate 3 more since this one worked out well....
Old Aug 16, 2015 | 05:20 PM
  #1634
CVO2FIXUP's Avatar
CVO2FIXUP
Do you not think the pipes are hanging a bit to low? Those curbs are vicious you know.
Old Aug 16, 2015 | 05:38 PM
  #1635
doorgunner's Avatar
doorgunner
No problem......if they are too low I'll flip the brackets over and remove 3" from the exhaust downtubes
Old Aug 16, 2015 | 08:51 PM
  #1636
Calo69's Avatar
Calo69
Or maybe you can just go lower all the curbs in Louisiana.
Old Aug 16, 2015 | 08:57 PM
  #1637
doorgunner's Avatar
doorgunner
Nice try but............................I'm NOT reading it!
(I still have to fabricate 3 more H.D. brackets)
To Doorgunner's '68 Convertible Project
Old Aug 17, 2015 | 12:25 AM
  #1638
13611's Avatar
13611
DON"T READ THIS!!!
Old Aug 17, 2015 | 09:50 AM
  #1639
Calo69's Avatar
Calo69
O.K. Gunner you can forget about lowering all the curbs.
All you have to do instead iS raise up all the roads, much more practical.
Old Aug 17, 2015 | 01:24 PM
  #1640
doorgunner's Avatar
doorgunner
Yeah......well........I'm installing 4-corner air shocks with front and rear sensors to raise the car when going onto curbed parking lots/driveways!
