Priya's 79 chrome bumper conversion project
Old Jul 1, 2017 | 06:05 PM
  #921
BLUE1972's Avatar
BLUE1972
In the past when working on large sections I would:
- wet sand, even with course paper it cuts faster
- a little ivory snow helps lube the paper, in the shop we would use a tarp and small pump to recycle the water. (fountain pump)
- I would take a 2 or 3' long 1x4 and glue another 1x4 to the center of the first one perpendicular -with holes cut as a handle. If you can true the wood ( before assembling & bonding with a table saw) the sanding is easier and flatter. It makes a flat board sander. I would use 3M contact spray #77 to put sand paper on to the wood.
- I also made full sandpaper sheet versions of the above
- taper the last 1/4 inch of the sanders to make it have less tendency to grab.
It looks really good and the end result will be fantastic...
Old Jul 1, 2017 | 07:27 PM
  #922
Priya's Avatar
Priya
Originally Posted by DUB
I read that you were having problems with your layers staying bonded and I guess you had air pockets that you had to grind out???
Just curious...did you ever get any of the laminating rollers???
I also read that you stated you were having problems with the West Systems resin. What problems???
What you laminated seems to look good in the photos....and I see what does look small B-B size air pockets that got exposed...but...knowing you are going to cover over the exterior laminated areas with VPA...that should not be an issue if they are prepped correctly.
In the photo below...and I KNOW you are not done ...BUT...I can not remember if I mentioned it or I did not go back and search this thread to see if I had...BUT...in the photo below...I can see what looks like resin that is applied on the brown paint below where you laminated up the seam. For what it is worth and I am sure you know...so this is for others who may not know who are following this process......make sure that the resin is ground OFF the paint before you do any filling with VPA.
DUB
Yes, I've had some problems with air pockets/layers not being bonded and I ground them out. That is the problem I was referring to with the Wests Systems epoxy resin. I have not had these air pockets/ unbonded layers with other kinds of resin. I did not buy a resin roller, I figured it would be too much of a hassle cleaning it and use a lot of pricey acetone.
I do know not to have resin over the paint. After I have all the laminating done I plan on going over all the painted surfaces with 120 grit and removing all the brown paint.
Old Jul 1, 2017 | 11:24 PM
  #923
DUB's Avatar
DUB
Depending on how warm you are allowing the West systems resin to get. because if it is cold it is much thicker...as I had previously mentioned to you in the past And if the ratios of resin to hardener are being strictly observed. I can not see how you are getting layers to not bond...unless the method you are using to apply the fiberglass mat is not correct...especially if these air pockets are at a 90 degree bend (such as at the top of your quarter.
I can not gasp your concern of the cost of acetone versus having tool that can easily aid in allowing you to laminate such large areas better if you are having a problem. Just boggles my mind.
TRUST ME...what you may feel it would be a 'hassle ' of cleaning the roller.... will greatly diminish when you use one and see what it can do for you.
But as always... so I do to get 'blasted' for commenting inappropriately..do as you want...and maybe when you get done you will prove to me that the loss of wasted materials and your time having to do it again and again will off set the cost of a roller and acetone needed to clean it. But I doubt it. That roller can actually aid you in saving your time an also materials....but don't listen to me. I am sure that will have to come from someone else who laminates more than I do.
DUB
Old Jul 2, 2017 | 01:24 AM
  #924
The13Bats's Avatar
The13Bats
Old Jul 2, 2017 | 02:49 PM
  #925
BLUE1972's Avatar
BLUE1972
Just a thought...
If you want to eliminate all air pockets you may want to think about vacuum bagging the work.
You can tape the release material over your work and bull a vacuum. This will eliminate all air voids.
If you don't have a vacuum pump, you can do what I did when mine died at home. I used a 350 cubic inch vacuum pump - the PCV line from my old Chevy. Just use a filter and shut off valve in the line.
I used 1/8 rubber hose and a 32 oz. jelly jar as the catch can for any debris. It worked perfectly....
I have used duct tape and lawn clear garbage bags - some stick to the glass some don't.
Old Jul 2, 2017 | 05:21 PM
  #926
DUB's Avatar
DUB
Boy I see you have a lot to add to this. No helpful advice for Priya...only some from of 'negative' comment...which I thought you were not on the forum due to ALL of the negativity...and here you are ..adding to what you dislike about the forum. Just par for the course with you...that is for sure.
Originally Posted by BLUE1972
Just a thought...
I vacuum bag some repairs....but not all the time. So much of it can be taken care of by using the roller tools that can make her job much easier.
DUB
Old Jul 2, 2017 | 05:43 PM
  #927
Priya's Avatar
Priya
Dub, I felt your post #923 was a little harsh. My husband didn't think so, so take it as you will.
Old Jul 2, 2017 | 07:04 PM
  #928
DUB's Avatar
DUB
If you were teaching me to cook 'once over' eggs in a frying pan and I was using a butter knife to flip them and get them out of the pan and kept having problems breaking the yokes...and you suggested buying a spatula so the yokes would be less likely to break....and I did not buy I one...but I tell you that I am still having problems from time to time and you ask me if I took your advice and I said 'no'......what would you think? I am sure you would think I am making it so much harder on myself... Especially when you know a spatula would greatly reduce the problems I have in breaking the yokes.
I HATE that you struggle and have problems..I HONESTLY DO!
I am SORRY you felt that what I wrote was harsh. As you are realizing and learning as you go...there are numerous dynamics at play when doing project like this. And the hopes of staying in budget oftentimes never occurs. I know from experience what the roller tool would do for you while you feel it would not. As for the comments on the resin and what have you. It is hard to try to help a person if we do not know exactly what is being done...so...I can only assume and try to comment on it and maybe what I write does make sense and it possibly helps you on a dynamic that could be causing you a problem.
NOT referring to you Priya here in what I am about to write....but it is funny how so many people often times think that laminating is easy and it takes not talent or attention and just 'slap' the stuff on. There are tricks/procedures and techniques...depending on what you are dong.
You will not have to worry about me any more.
Old Jul 2, 2017 | 08:27 PM
  #929
dtamustang's Avatar
dtamustang
one thing you may want to consider since you are having some difficulty getting all the air out of your lay up , as far as i know there is no styrene in epoxy resin , the long strands of fiberglass that make up mat is bonded together when its made so it doesn't fall apart and turn in to a pile of long strands , the stuff that bonds it together is neutralized with styrene that is in polyester resin and turns it back in to individual strands that are as limp as a cooked noodle. since there is nothing in the epoxy to let the strands relax they are probably going to be a lot more difficult to make them do what you want them to do , for example working air bubbles and getting it to lay around tight corners.
you may want to look in to finding a mat that does not need the styrene to relax and unbond to it self , i avoid using epoxy resin for this and several other reasons. i'm not even sure if mat is available like that , if not you may want to "limber it up " before wetting it out.
Old Jul 2, 2017 | 08:45 PM
  #930
Priya's Avatar
Priya
Thanks dtamustang.
Dub, I always want to hear advice from people like you even if I don't decide to follow it everytime. My husband said sometimes he gets mad at me too because I ask for his advice and don't always follow it. He mentioned the time I asked him for help mating my 79 Chev Monza car seats to my 81 AMC eagle seat tracks. He mocked up a stand to support the eagle seat tracks and made adapters to go to the Monza seats. He says I told him it was fine but later on I was cutting apart the adapters he made and further modifying them. I don't know what to tell people like him, he certainly is a far more talented fabricator than me. The seats felt fine from a quick sit down after he did them but after hours of driving in the car I realized they were crooked and not to my liking so I evolved what he had done with the adapters , cut, shaped, and re-welded until I got them fitting in a way that better suited me. I don't think I could have figured it out from scratch like he did but once he had the general shape done for me I could see how to modify it a bit to get what I wanted.
Old Jul 2, 2017 | 10:17 PM
  #931
Priya's Avatar
Priya
Originally Posted by Maymyvettelive4ever
When do you think this project will be done?
I'm going to say at the rate I'm going about three years from now (don't tell my husband, he thinks it'll be done in less than two years).
Old Jul 2, 2017 | 10:56 PM
  #932
doorgunner's Avatar
doorgunner
2026 Loser of the Year
LOL.......I think I have about 40 actual hands-on hours in my conversion.
It's the year of LIFE mixed in that is causing the slow-down!
I think a rookie like me could do the conversion (less painting) in about 60-70 total hours (provided there are no distractions).
Old Jul 2, 2017 | 11:19 PM
  #933
Priya's Avatar
Priya
We'll get there eventually Doorgunner
Old Jul 3, 2017 | 11:17 AM
  #934
BLUE1972's Avatar
BLUE1972
just a thought, something I learned a long time ago.
IT TAKES AN HOUR TO PUT THE ENGINE IN THE CAR AND 4 DAYS TO GET IT RUNNING. WHEN YOU PUT THE ENGINE IN IT LOOKS LIKE A LOT WAS DONE, THE REST LOOKS SO SIMPLE.
Enjoy the work, don't rush, step back often to enjoy and marvel over what you have accomplished.
The end result will be worth it...
GREAT JOB, looks great.
Old Jul 3, 2017 | 12:26 PM
  #935
Priya's Avatar
Priya
Thanks Blue1972
Old Jul 3, 2017 | 02:58 PM
  #936
71 Green 454's Avatar
71 Green 454
Your input is very valuable and I always enjoy reading your posts.
My dad made body work look easy and I was always impressed. I would stop by the shop and see cars cut in half...just amazing what he could do.
Old Jul 28, 2017 | 04:55 PM
  #937
VETFEVER's Avatar
VETFEVER
How is the conversion going??
vetfever
To Priya's 79 chrome bumper conversion project
Old Jul 28, 2017 | 05:14 PM
  #938
Priya's Avatar
Priya
Slowly. Its been hard to get motivated due to all the itchiness and fiberglass dust in my eyes from working under the car in the gas tank area.
I went to lay some more mat and resin today but discovered I have very little resin left so it'll take a week or two to get more.
Old Jul 28, 2017 | 07:56 PM
  #939
VETFEVER's Avatar
VETFEVER
Thanks for the update. Good luck
Old Jul 28, 2017 | 09:58 PM
  #940
doorgunner's Avatar
doorgunner
