72 side emblem removal
Old Aug 27, 2016 | 07:25 AM
Mac72LT1's Avatar
Mac72LT1
Default 72 side emblem removal
What is the best way to remove the side emblem. Looks like someone tried pry off one of mine and bent the front of the emblem. I see the pins in the fender but they don't have speed nuts on them or does it look like double sided tape was used. Hopefully I can get off and gently straighten.
Old Aug 27, 2016 | 08:25 AM
bj1k's Avatar
bj1k
Take some tape and put it around the emblem to keep from marring the paint and use a thin putty knife to gently pry the emblem a little at a time and work your way along it until it comes loose. Then gently straighten the emblem.
Old Aug 27, 2016 | 10:28 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Add a little heat (heat gun) to it to loosen up the double sided tape adhesive.
Terry
Old Aug 27, 2016 | 11:02 AM
Alan 71's Avatar
Alan 71
Hi mac,
I prefer to use a long piece of dental floss.
Start it at one end of the script and be sure it's between the tape and the body not between the script and tape.
Use a sawing motion to work it around the script. You have to change the angle as you move around the pins.
Typically no damage to the script or body.
Good Luck!
Regards,
Alan
Here.
Remember you have to reposition the floss as the script starts to release to get around the posts.
Old Aug 30, 2016 | 07:00 PM
Richard Daugird's Avatar
Richard Daugird
I got too close backing into the garage, mine came right off!
Old Aug 30, 2016 | 09:47 PM
redrdstr72's Avatar
redrdstr72
Originally Posted by Alan 71
Hi mac,
Good Luck!
Regards,
Alan
Here.
Alan has good advice as always. I'll add that if you don't have enough dental floss handy, and if you're a fisherman, monofilament fishing line works well too
Hope this helps!
Old Aug 31, 2016 | 08:24 AM
sgt kohler's Avatar
sgt kohler
I used fishing line and some Goof Off. did the ones on my 08 and 72 just take your time.
Old Sep 5, 2016 | 06:10 PM
Mac72LT1's Avatar
Mac72LT1
Thanks for all the advice. Got it off without scratching anything. It didn't have any double sided tape on it.
I would like to put some on when put back. Any recommendations on brand and type of double sided I should use?
Old Sep 5, 2016 | 06:19 PM
DUB's Avatar
DUB
3M...and GOOD LUCK with that!!!!. I have tied with my scalpel (many times). Trying to cut that double sided tape and have it look good was not worth my time. I buy new emblems. I am super picky because I am doing this for my customers....and I DO NOT glue them back on....that is also a waste of time. For me...gluing them on is a sub standard repair IF they have NO tape on them. An YES..I have seen it like that.
I have YET to find a double sided tape that is wide enough to cover the entire backside of the emblem.
DUB
To 72 side emblem removal
