SERIOUSLY thinking about this engine....
Old Dec 5, 2006 | 11:38 AM
  #41
gyopp's Avatar
gyopp
there's 8 inches of vaccumm at idle so the brakes work just not very well at idle. next spring I will try to sneak over to the track. My wife is not really on board with this plan as I usually tend to get overly invoved in these hobbies.
Old Dec 5, 2006 | 12:16 PM
  #42
'Bochawa72's Avatar
'Bochawa72
I had seen these guys on eBay too. I'm looking to buy a crate too and had been leaning towards the HT383 or the ZZ383. Now these guys have a 383 with numbers in the ZZ383 range for about 1000 less. Very tempting for a enlisted guy! My question is though how much work was done on these blocks? It says they have been bored but how much? Does it vary with the block? I'm trying to decide if I'd rather have a new block or a used one. So what would the advantages of going with these guys be over going with a GMPP block other than cost?
-CR
Old Dec 5, 2006 | 01:38 PM
  #43
CraigT79's Avatar
CraigT79
Originally Posted by gyopp
I have one of T&L's 408 motors and I can tell you that my engine was dyno run. I went there to watch the run myself. All of there engines get "new" serial numbers so its very easy to track. I would recommend to anyone that they go witness this, kinda like watching your baby born. My engine dynoed in the 470's pulling all the belt driven accessories. This is not where AJ is looking to be but I had them be very conservative with the cam for street cruising with an auto tranny and air conditioning. My cam is 306 duration, .480 lift. I don't know much about cams but understand that lift # is pretty low? Anyway, I love this engine. I am running a T350 with 3.55 gears and 275/40 18" kumho tires and have plenty of power to roll into the trottle runing 40-45 in second and pull the tires loose. I don't know how this stacks up for a drag racer but its lots of fun on the street.
By the way Alan, if you buy from them and go watch the dyno run have them set you up with the inside tours of Hendrix Racing, DEI, and some of the other local race shops. Loyd knows all these guys.
I also bought the 408 from them. Got it in a week ago, but won't go in till Feb. Mine was dyno'd at 463hp with a performer intake and hyd upgrade. Pretty much same build as gyopp.
Old Dec 5, 2006 | 01:46 PM
  #44
ajrothm's Avatar
ajrothm
Craig is that just the base Performer intake? you say hyd upgrade....you mean hyd roller cam upgrade right? you have the specs on the cam?
If it is a regular Performer intake, that thing is choking you to death. I bet you would gain 15-20hp easy changing to an rpm air gap.
Old Dec 5, 2006 | 02:19 PM
  #45
VETDRMS's Avatar
VETDRMS
I have the 1-5/8 Dynomax headers on my 406. Although it is being chocked I have been impressed with how it has performed, they can't be that bad. That being said a set of super-comps is definitely on my wish list.
Old Dec 5, 2006 | 04:05 PM
  #46
LFZ's Avatar
LFZ
yea, i agree with the others...single plane intakes are the way to go if you want all the power you can get. I run a Victor Jr. on a hydraulic roller 383, redlines about 6000rpms, and it will smoke the tires through
1st and 2nd with the M20.
Old Dec 5, 2006 | 06:32 PM
  #47
ajrothm's Avatar
ajrothm
-CR
The only real benefits to using a new GM block is that they are 1 pc rear main seal and are setup for roller cam usage. Plus you can buy a ZZ383 block that is already clearanced for the rods.
As for using an old style block, as long as its machined correctly, it is just as strong if not stronger then a new block. It is has been heat/cold cycled so many times the distortion in the block is usually at its end. Nothing wrong at all using an old block. Good machining is the key.
Old Dec 5, 2006 | 06:35 PM
  #48
ajrothm's Avatar
ajrothm
I wonder how much taller a Victor jr is then a RPM air gap?
Old Dec 5, 2006 | 07:11 PM
  #49
Ironcross's Avatar
Ironcross
Originally Posted by ajrothm
http://cgi.ebay.com/ebaymotors/SB-Ch...1405QQtcZphoto
What do you engine guys think about a 4" stroke SB? Think it would be a lazy revver? I want as much torque as I can get out of a SB. That price can't be beat. He adds $500 for a custom built, pro-form 750 DP installed and dynoed on my engine. About $5500 dynoed and shipped. I think 510/510 should be good for mid-high 11s with a good stall converter.. What you guys think?
4X4 small block Chevys have been around for nearly 50 Years. They are nothing new.
Old Dec 5, 2006 | 08:01 PM
  #50
LFZ's Avatar
LFZ
i think the Victor Jr. might be alittle lower..if not, they are at least the same height.
Old Dec 5, 2006 | 09:27 PM
  #51
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Vic Jr and Air Gap are the same height
About a single plane being no good for the street BAWWAHHAAAHH
I have Vic Jr and have 3.08 rear gears and it is soooo much fun to drive on the street it should be illegal. My carb is properly tuned and throttle response is instant, you hit the gas it goes....fast.
The throttle response is so good the dyno operator started the dyno at 2000RPM, 460ft/lbs at 2000RPM's helps it get rolling
Old Dec 5, 2006 | 09:54 PM
  #52
b71vette's Avatar
b71vette
Originally Posted by jackson
I've been involved in regional circle track racing for a long time; as car owner, engine builder etc.
T&L has never done any work on any motor of mine ... BUT they've had a good reputation amongst regional CT racers for a long time. They've been building race motors a lot longer than ebay, this forum or even the internet's been around; they're long-time experts.
If you want a street motor they'll build it ... if you want a race motor they'll build it ... but don't try too hard to compare the two.
If a new stroker motor has all new rods, crank, pistons & heads ... assembled for around $5K ... be assured the rods & crank have aisian origin. That's why many hot street/strip motors have a $600 forged imported crank (scat, eagle etc) & why most true championship motors have a $3K forged crank (bryant, moldex etc) ... similar disparity for rods. Everything has its place ... but for most folks here, asian forged crank/rods are just fine so long as an expert checks them first.
BTW ... I've flown a 40+ year old red chinese fighter trainer with red chinese radial motor ... both Nanchang & myself are still operational ... been inside its motor too ... little difference between it & a P&W. We've all had experience with aisian junk ... but some aisian stuff is junk & some ain't.
Thanks Jackson for reinforcing my confidence in T&L/Lloyd McLeary-glad to see he is getting a few more engines into vettes.
Old Dec 5, 2006 | 10:10 PM
  #53
coinwasher's Avatar
coinwasher
I made a swing by this shop a few months ago as I was in Charlotte on bussiness. You can eat off the floors in this place and they let me stand in the dyno room while they were twisting one up. I did not buy only because I wanted a correct 427 for my 69 coupe. These guys are the best I have ever seen and I am going to pick up a small block from them for my truck this spring.
  #54
birdsmith's Avatar
birdsmith
Just to chime (no pun intended) in here- I didn't see in this thread whether Lloyd specifies a cast or forged crank for the 408 combo. A lot of these low-buck ebay engine vendors are marketing "cast steel" cranks in their stroker kits in order to persuade potential customers into thinking that they're getting something way stronger than stock by calling it "steel". Asian or not, (and rest assured for 5k you're getting Asian metal) the operative word here is "CAST". Castings tend toward brittleness and if you're gonna be pushing 510HP and big torque #'s around a four-inch arm in a 3300 lb. car you will break that crankshaft sooner rather than later, especially if you're gonna beat on it as you seem to be suggesting you will. The couple three hundred extra bucks that you'll spend to get an Asian FORGING bolted into that bad boy would be cheap insurance indeed. If your 'cast steel' crank lets go at 6000 RPM it'll make a fine mess out of your motor in very short order, leaving you with little to salvage save a (single- or dual-plane, depending on your cup of tea) intake manifold and carburetor. IMHO
Old Dec 5, 2006 | 10:47 PM
  #55
ajrothm's Avatar
ajrothm
AS I read on the advertisement, its a 4340 forged steel crank. Chinese or not, I am not sure...... Rods are H beam steel. Granted these are not top shelf race parts but I would think they would be fine for a low rpm(6200 or less) street motor thats running on muscle, no spray or boost. I mean ****, freakin old school pink rods will hold 500hp, how can the chinese H-beams with ARP bolts not? I have sprayed 175hp shots through basically stock 350 bottom ends and they ran 11s for dozens of bottles. That was cast stock stuff, even pistons. I find it hard to believe these engines T&L would not reliably hold the HP they are making.
As for the Victor intake, if its the same height as an air gap, it may be worth a try although I don't see how its gonna help on an engine that only revs to 6k, especially considering the intake doesn't even start until 3k.
Old Dec 5, 2006 | 10:52 PM
  #56
gyopp's Avatar
gyopp
Loyd told me the crank was forged and I will tell you that they have no questions about the integrity of thier build or they wouldn't let customers and other visitors watch them twist these motors up like they do.
Old Dec 5, 2006 | 10:55 PM
  #57
gyopp's Avatar
gyopp
If you were having that much fun it probably was illegal
To SERIOUSLY thinking about this engine....
Old Dec 5, 2006 | 11:14 PM
  #58
Little Mouse's Avatar
Little Mouse
You would not want to run a 165/180 runner head even on a lower rpm
408 but you would on a 350. a dual plane RPM is a fine manifold on
a 327/350, it becomes a restriction on a 408. a victor Jr is a 3500/8000
manifold on a 327/350 not on a 408." read motorheads 460 pounds
of torque at 2000 rpm with a victor jr ". A dual plane on
a 396/427/454 is a good manifold, on a 500 cube motor it becomes
a restriction even at lower revs
Old Dec 6, 2006 | 07:44 AM
  #59
ajrothm's Avatar
ajrothm
Originally Posted by Little Mouse
You would not want to run a 180 runner head even on a lower rpm
The why would you suppose that MOST street engine builders that are building hot, roller 383s with good heads are using the RPM air gap? It does have the half divided plenum but obviously the plenum volume is not near as great a single plane would be. Most of the local builders around here that are putting their custom 383s out are using air gaps. One local builder quoted me $7300 for a solid roller 383 with worked Dart heads and he was using a port matched air gap...why would he not use a Victor if he thought it would give me another 20hp? Just curious.
I did used to run a torker II(single plane) on a pontiac 406" and it was the preferred manifold in the pontiac community, even over the Performer RPM(already an air gap on a pontiac). Often running a 1", 4 hole spacer on the top of the torker II was THE combo, at least up until a couple of years ago. And pontiacs are only 6000 rpm motors but there is a big difference in a Torker II and a Victor rated RPM range.
Old Dec 6, 2006 | 08:22 AM
  #60
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Originally Posted by 1BAD80
Why not build your own motor ?
A G.M. rocket block 427 can be built for that price.
That's what makes it fun
