Z-Bar
Old Mar 8, 2009 | 10:23 PM
  #81
spedaleden's Avatar
spedaleden
[QUOTE=81cali;1569218191]would the back up light switch be the same as the one for auto? my connections are all on the auto shifter for both back-up lights and neutral safety. Does the auto tranny have this particular switch as well mounted to it?[/QUOTE
You will need the switch and bracket and rod for back up lights that mount to 4 speed trans. Your new back up switch will plug into the safety neutral switch (2 prong plug)
I think the auto shifter has a pin so when the shifter is in the reverse location it triggers the safety neutral switch to set the back up lights on. 4 speed cars have an extra switch mounted on trans. Others may know more.
Old Mar 14, 2009 | 04:55 PM
  #82
81cali's Avatar
81cali
thanks fo rthe input, i still have to tackle that when i get there. right now, i'm stuck with the pedals. does the dash really need to come down a bit? i've gotten as far as moving the booster out of the way and took the plate off that holds the steering column up.
Old Mar 15, 2009 | 02:13 PM
  #83
81cali's Avatar
81cali
Originally Posted by Go Vette Go
I believe 80 & 81 already have the holes drilled in the frame for the Z-Bar bracket. Here is the bracket you will need -> http://www.zip-products.com/Zip/prod...CD040A78D92C7C
I used this on my 78 when I converted from auto to manual.
John
Hi John,
Would you happen to have a pic of where this bracket bolts on to? If not, can you please be specific as to where it goes? Thank you!
Old Mar 15, 2009 | 05:39 PM
  #84
spedaleden's Avatar
spedaleden
Here is the pic you requested on the clutch rod. If you need anything else, just ask!
Old Mar 15, 2009 | 05:58 PM
  #85
81cali's Avatar
81cali
Thanks a lot!!!! So the boot attaches from the outside.
Old Mar 15, 2009 | 06:05 PM
  #86
spedaleden's Avatar
spedaleden
Yes,
You should order an Assembly Instruction Manual. It is great for reference. I refer to it all the time.
Old Mar 15, 2009 | 06:17 PM
  #87
81cali's Avatar
81cali
I believe you and if it wasn't for generous people like you, this would have been an eternal and tedious task. THANK YOU!!!
Old Mar 15, 2009 | 09:23 PM
  #88
spedaleden's Avatar
spedaleden
Ok, how far did you get and what's left to do until you can drive it.
Old Mar 16, 2009 | 01:08 PM
  #89
81cali's Avatar
81cali
lol.....next would be the Z bar mounting bracket and the actual installation of the Z bar itself. I did ask you about the linkages at one point but decided to put that off until pedals and z bar are installed. So, after Z bar would be the tranny linkages.
Old Mar 16, 2009 | 01:11 PM
  #90
81cali's Avatar
81cali
I just remembered, would you happen to know if the speedo cable for the auto is the same for the manual? I might as well get one if it's different while I still have the cluster out. It's a PITA to snake my hand under the dash once the steering and everything is back on.
Old Mar 16, 2009 | 04:47 PM
  #91
spedaleden's Avatar
spedaleden
4 speed cable is 72" long Auto cable is 62" long. You may want to try but it seems like you will need a new cable. This is based on not having cruise control. If you have cruise you will need to put a kill switch like the brake switch on the clutch pedal. The factory did not offer cruise on a 4 speed car.
4 speed cable number 213065 corvette central 23.95
36693 Wilcox 14.95
I believe forum members get a discount from Wilcox.
Old Mar 16, 2009 | 04:53 PM
  #92
dobroman2001's Avatar
dobroman2001
36693 Wilcox 14.95
I picked mine up at Advanced Auto for about 15.00 bucks. Probably any other parts store will have it as well...
Old Mar 17, 2009 | 03:59 PM
  #93
81cali's Avatar
81cali
should i disable the cruise control?
Old Mar 17, 2009 | 05:10 PM
  #94
spedaleden's Avatar
spedaleden
First see if your existing speedo cable works. For know just disconnect cruise harness at cruise control. You will need to add another brake switch onto the clutch pedal if you want to use the cruise control.
Old Mar 21, 2009 | 04:13 PM
  #95
81cali's Avatar
81cali
Originally Posted by dobroman2001
Here's some pics of my '76. The holes for the pedals (and clutch rod) were already there.... they have a firewall "plug" on them..
http://s189.photobucket.com/albums/z...20to%20Manual/
I guess I'll have to take the entire brake booster out. I don't see the three screws like what you have in your car.
Old Mar 21, 2009 | 05:20 PM
  #96
spedaleden's Avatar
spedaleden
Post a pic if you can of just below the brake booster
Old Mar 21, 2009 | 09:31 PM
  #97
81cali's Avatar
81cali
pictures taken from under the car as well. There are holes but we can't see any of the 3 screws mentioned.
To Z-Bar
Old Mar 22, 2009 | 10:56 AM
  #98
spedaleden's Avatar
spedaleden
It's hard to tell by the angles of your pictures, but the first pic has either a vacuum line or speedo cable going through a hole. That is the one I would think is used for the clutch rod. My speedo cable come out much higher up the firewall.
I will try to get you pics of my car later. I have it at another location. I am going to start it today?
Where those two rivets are is there one above? I can't see. That may be it. You will need to drill out the rivets. If you have the boots or grommet for the clutch shaft. Check to see if boot covers hole. There is a metal ring that goes over the boot or grommet to secure the boot. Make sure you have the ring.
Old Mar 22, 2009 | 01:39 PM
  #99
81cali's Avatar
81cali
The 2 rivets are too far apart and there's no third one above it. In the first pic, that's actually the clutch rod that i tried to see if it will align with the pedal. However, I don't think the hole is big enough for the boot.
Old Mar 22, 2009 | 02:43 PM
  #100
spedaleden's Avatar
spedaleden
I found what your looking for, look at C1, you need to drill a hole. Gm states 1.25 +or - 1/64 diameter at dimple in cover brake pedal housing
Mounting holes 3 7/32 +or- 1/64
Retainer for Clutch rod seal
http://www.ecklers.com/product.asp?p...8&dept_id=1462
