Borgeson Steering Install
Old Jul 19, 2009 | 05:24 PM
  #41
Bee Jay's Avatar
Bee Jay
Originally Posted by Solid LT1
My wife wanted PS for the 70 LT-1 I installed a Corvette Steering Service kit over 3 years ago (Tom "invented" the Jeep box conversion.) I have been VERY HAPPY with the performance of this conversion and it allowed me to retain my 6quart "trapdoor" LT-1 oil pan (I have a NOS GM power steering system sitting in my garage right now and didn't use it because it would require me to change my LT-1 oil pan.) I know this conversion has plenty of clearance with Stailessworks small block 1.75" diameter chassis exit headers but, with a big block you may have some re-working to do on the driver's side tubes of any header system. The old power steering control valve is eliminated on this conversion and our C3 Corvette's technology level is moved from the 1950s invented Bendix power steering to the 1960s invented Saginaw intregal boost PS box. I have known people who have installed the rack and pinion kits, you loose ground clearance, the brackets are SCARY flimsy looking and the numer of universal joints and brackets makes me think the long term reliability will leave something to be desired. The "Jeep box" conversion is relativley straight forward, looks factory stock after completion and fits in with my idea of a proper modification for a reliable Corvette. Do a search on the amount of cracked mounting brackets the rack and pinion systems have had then make your decision, I know what I want in my Vette.
I thought the weak and cracking bracket problem had been resolved. I hadn't heard about losing clearance. Right now my low point is my headers since I went with a circle track oil pan. I have two other sports cars with rack and pinion (both non-power assisted) and boy do I love the steering response and feel. I wonder which one is lighter? I know you remove a lot of hardware with the rack and pinion. Several hundred dollars cheaper is a definite plus.
Bee Jay
Old Jul 19, 2009 | 05:55 PM
  #42
riggs 74's Avatar
riggs 74
How does your steering feel compared to a newer car with a rack and pinion
set up? My wifes daily driver is a 2008 grand prix and the steering in it is very
responsive, more how I would like the vette to be. Whats your thought on this
after adding this new box?
Thanks,
Riggs.
Old Jul 20, 2009 | 06:05 PM
  #43
iokepakai's Avatar
iokepakai
This is a great upgrade for your vette! Bolts right up in the stock location ,lines up with the steering column with no problems.I also did the conversion with out pulling the column .Been driving with it now for two months and love how tight and quick the steering feels.Check out my pics.http://www.flickr.com/photos/3910403...n/photostream/ .I went with a u joint from Borgeson and all seems to be fine so far.I really like how I can "feel the road" with this set up.....Best money I spent on my car so far. Thanks to all for your posts keep the info flowing...Alohas
Old Jul 21, 2009 | 06:44 PM
  #44
iokepakai's Avatar
iokepakai
My first successful pic posts!!
Old Jul 21, 2009 | 09:18 PM
  #45
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I too did the Borgeson box and rag joint. All from this end! I concur with the positive opinions. Most excellent upgrade!
Old Jul 21, 2009 | 11:18 PM
  #46
682XLR8's Avatar
682XLR8
Congratulations!
I remember these pics when searching for threads on the Borgeson box
Old Jul 22, 2009 | 07:16 PM
  #47
iokepakai's Avatar
iokepakai
I was going to replace my column lower bearing but didn't know how to get it out! I got the spring clip out but the bearing didn't budge.It didn't have any play so I just let it be.Did you guys change yours? If so how did you do it any tricks to it?
Old Jul 22, 2009 | 07:42 PM
  #48
riggs 74's Avatar
riggs 74
Thanks,
Riggs.
Does any body have enough seat time to answer this question?
I want the car to be as responsive as a new car, not just better
than it was, will this steering box do it for me or will I have to do
a rack and pinion set up? Does any body have experience with both
systems?
Thanks,
Riggs.
Old Jul 22, 2009 | 10:49 PM
  #49
BB72's Avatar
BB72
systems?
Thanks,
Riggs.
Lets hear
Old Jul 23, 2009 | 12:04 AM
  #50
682XLR8's Avatar
682XLR8
Best answer I can give would be:
My 2001 Toyota Solara- Real close
Wife's 2005 Mercedes- Not close, rack system wins
If you want the car to steer like it has rack-and-pinion you should probably install the rack system
It would be interesting to see a head-to-head comparison of the two systems in a C3
Old Jul 23, 2009 | 05:45 AM
  #51
riggs 74's Avatar
riggs 74
682xlr8,
Thanks for the reply, I am still real interested in this set up, thanks
for bringing this system to my attention with a great thread.
Thanks,
Riggs.
Old Jul 30, 2009 | 09:20 AM
  #52
1982CorvetteDude's Avatar
1982CorvetteDude
Great information, I like the fact that it bolts directly on....I've been looking at doing some sort of jeep box conversion and this looks way better than the hacked brackets in the corvette steering kit....at almost the same price.
Old Jul 30, 2009 | 10:54 AM
  #53
682XLR8's Avatar
682XLR8
Just out of curiosity, I did a search on Corvette Fever's website for the Borgeson kit. Saw an ad for it, but no articles of any kind(maybe I wasn't digging deep enough). So I sent an email to the editor asking if any kind of write-up has been done on the Borgeson system comparing it with the Steeroids. I'll post if and when I get a reply
Old Jul 30, 2009 | 11:26 PM
  #54
nmbr6's Avatar
nmbr6
has anyone put this in with a sb hooker side mount? I have absolutely no clearance with the stock box.
Old Aug 3, 2009 | 01:57 PM
  #55
1982CorvetteDude
Originally Posted by 682XLR8
Hoses installed on the pump end. It's harder than it looks, those hoses are thicker than OEM, a little tough to manuever in the cramped quarters of the C3 engine bay
[IMG][/IMG]
Do you know if you have to use the custom hoses that borgeson sells or will a standard stock Corvette steering pumps hoses work?
Old Aug 3, 2009 | 02:31 PM
  #56
682XLR8's Avatar
682XLR8
The original style hoses are too short
Old Aug 3, 2009 | 03:19 PM
  #57
1982CorvetteDude
ok..Thanks!
To Borgeson Steering Install
Old Aug 4, 2009 | 10:16 AM
  #58
1982CorvetteDude
Well I went ahead and ordered one of these, I got mine from Jegs it was a little cheaper than CC and ecklers. I still need to get the hoses and rag joint.
Good thing was I just snagged a manual drag link off fleabay this weekend for $30 shipped.
Thanks for taking the time to do a write up
Old Aug 4, 2009 | 10:22 AM
  #59
682XLR8's Avatar
682XLR8
You can get whatever else you need directly from Borgeson, probably cheaper
Old Aug 19, 2009 | 05:34 PM
  #60
1982CorvetteDude
Got the rag joint today, one thing I found odd was that you don't get a warranty or maybe I am misreading this. This was folded up inside the rag joint.
But it seems like if you use one of thier jeep boxes and rag joint you would get something especially at $104 for the rag joint
