Elle88 Build thread
Old Nov 4, 2009 | 03:10 PM
  #81
Little Mouse's Avatar
Little Mouse
Originally Posted by 63mako
Cool video! Listen to that thing idle.
I went frame by frame at the end of the clip. It had a little blip at the end of the run. Power was pulling uniformly up to 6760 RPM. At that RPM Torque was 484, HP was 620. Then at 6860 RPM just before shutdown it showed 518 torque and 676.2 HP. This was just for a split second. Gained 34 ft lbs and 56 HP in 100 RPM. This very well could be a dyno error. This thing looked to still be pulling when it shut down ai 7000 RPM though.
Do you have a rev limiter? Did you have the carb spacers on the car before? If so how thick do you have room for? Would like to send it as you will have it setup in the car so you don't have to disassemble anything once you get it. Bolt it in and go.
Please tell me your not going to weenie out at 6900 rpm you never will know what the engine really makes. 262 .50 should pull well past 6900 in a 427.
Old Nov 4, 2009 | 06:51 PM
  #82
63mako's Avatar
63mako
St. Jude Donor '08-'09
Don't know what RPM we will pull on the dyno. Probably pull till power drops off on the last pull once everything is dialed in. Comp says the cam operating range is 3800 to 6800.
Damper and spin on adapter is on. Pushrods are in, valves adjusted, valve covers on (they look pretty puny), engine is painted. carb and distributor need to be installed and it is dyno time. Got a motor on the dyno now but hope to do it this week still. Anybody got a guess on Tq and Hp.
Old Nov 4, 2009 | 09:44 PM
  #83
Little Mouse
245 .050, 520/520 lift 427/435 hp factory were pulling power to 6500 rpm if that cam won't pull past 6800 rpm Competition cams needs to go out of business It could be the dual plane may hold things back.
Old Nov 5, 2009 | 01:55 AM
  #84
elle88's Avatar
elle88
wow!
great to see the motor complete-almost
yes dual plane and 800cfm carb could be limiting factors to hi rpm, but needed the engine to be tuned in its final user set up. I went for dual plane and 800cfm both for parts availability and to avoid excessive troubles at low speed-rpm operation.
btw, searching the web, I found a couple of Zl1-L88 builds with my same dual plane and divider not removed.pulling 650hp on the dyno if I remember right
found the link
http://www.superchevy.com/technical/...tor/index.html
650hp @6500rpm
very similar to my L88 build except the higher CR and slightly different cam. same cid, intake, heads , same rocker arms too
Old Nov 9, 2009 | 02:47 AM
  #85
elle88's Avatar
elle88
while waiting for the engine to be dynoed, here is the car in which it will be dropped
Old Nov 9, 2009 | 02:55 AM
  #86
WESCH's Avatar
WESCH
Hi
Will you be using the L88 cold air induction system ?
If not, why not ?
Rgds. Günther
Old Nov 9, 2009 | 06:25 AM
  #87
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Looks great!
my guessometer points are 612 HP and 642 TQ.
Old Nov 9, 2009 | 09:18 AM
  #88
elle88's Avatar
elle88
Originally Posted by WESCH
Hi
If not, why not ?
Rgds. Günther
yes, of course
this a pic of my former engine before the problem to a cylinder forced me to new build.as you know already is a 321 block like your
i hope 600hp on the new build
Old Nov 9, 2009 | 08:20 PM
  #89
63mako's Avatar
63mako
5 empty quarts of Brad Penn Break In oil in the trash can today. Other motor (540) was getting final tuned on the dyno this aft. Elle88 is next in line for the dyno. My guess on the 440 CI engine is 590 HP and 579 Tq. 600 HP and torque are hard to come by. Hope you guys are right though, I would love to see over 600 on both.
Old Nov 9, 2009 | 09:56 PM
  #90
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It is has a stroker crank in it ? What do the heads flow ? Should be a nice motor, and have enough torque to be able to tool around town too.
Old Nov 9, 2009 | 10:44 PM
  #91
63mako's Avatar
63mako
No. Stock 3.76 stroke. .070 overbore gives you 440 CI.
Here is some head info.
This head is identical to P/N 12363410, except it has 2.25" stainless steel intake valves, and 1.88" stainless steel exhaust valves with 11/32 stems.
Intake Runner Volume is 315cc. Rectangular Port,Semi Open 118cc Combustion Chamber.
It also includes high performance valve springs, valve spring caps, keys and valve stem seals.Valve springs are good for up to .680" lift. Springs have 140 lbs closed pressure and 360 lbs open pressure.
These heads are designed for high horsepower 396, 427, 454, and 502 engines.
Technical Note: For 502ci engines, use no sealant on the head bolts. For all big-block engines, use intake manifold gasket kit P/N 12366985, with intake bolt kit P/N 12367959, and cylinder head bolt kit P/N 12367779.Cylinder head casting number is 12363401.
FLOW NUMBERS
LIFT INTAKE EXHAUST
.050" 35 22
.100" 70 53
.200" 143 112
.300" 200 137
.400" 236 170
.500" 275 194
.600" 310 213
.700" 330 226
.800" 340 234
Old Nov 9, 2009 | 11:34 PM
  #92
MotorHead's Avatar
MotorHead
Properly tuned it should hit 600 HP
Old Nov 9, 2009 | 11:42 PM
  #93
eagle275's Avatar
eagle275
Default Man, what a build! Wow!
Do you have a P/N for that GM intake? Thanks!
The duration @ .050 are similar. Lift is higher. The biggest difference is the advertised duration. The oem was over 350 on both sides. This one is not listed but is under 325. Way faster ramp. This will give you better vacuum, more power, better manners and low speed driveability. As we have discussed the down side is longevity and everything relating to the valvetrain needs to be perfectly matched, properly broken in and correct. If your original cam was a true OEM L88 this should be better than that as far as streetability. If you are used to it and that is what you want it is all good!. Here are a few pictures. Motor is assembled. except carb, dist, pushrods and balancer. The damper just came off the balancing machine. Aldo, make sure your flywheel is neutral balanced. The OEM balancer needed a little material removed to be right. Factory is not always real good. Might be a good time for a clutch upgrade and flywheel resurface as well. The pushrod length checker came up with both intake and exhaust pushrods needing to be + .200. You can see the nice centered pattern on the two valves to the left in the photo. The pushrods will be in this afternoon. Paint today. Hoping to be done very soon.
Old Nov 10, 2009 | 04:08 AM
  #94
Vesa's Avatar
Vesa
Old Nov 10, 2009 | 09:58 AM
  #95
63mako's Avatar
63mako
Can do better than that. This guy still has one available.
http://cgi.ebay.com/ebaymotors/New-G...A1%7C72%3A1171
Old Nov 10, 2009 | 10:19 AM
  #96
gkull's Avatar
gkull
Mako - use a 1/2 inch 4 hole wood or thermal spacer.
Old Nov 10, 2009 | 10:31 AM
  #97
63mako's Avatar
63mako
Aldo provided a factory heat shield and a short thermal spacer. Don't know if he has roon for the 1/2" spacer though. Why the 4 hole?
To Elle88 Build thread
Old Nov 10, 2009 | 10:49 AM
  #98
67tripwr's Avatar
67tripwr
Great thread!! Itching to see the dyno results, should be interesting.
Old Nov 10, 2009 | 08:08 PM
  #99
63mako's Avatar
63mako
540 is off the dyno. The Elle88 is getting hooked up. Break in will be done with a known good carb, outer springs and 1.4 rockers. Then the carb will be changed out for Aldo's rebuilt 800, inner springs installed and the comp rockers installed and dyno tuning. Hope to get it all done tomorrow.
Old Nov 10, 2009 | 10:13 PM
  #100
MotorHead's Avatar
MotorHead
What grade are you going to use in it when it's broken in. I use 20W50 ( Brad Penn) in my 427ci. I keep asking my buddy ( machine shop owner ) about the 10W40 and he always tells me to forget about it and use the 20W50
