Corvette V12?
Old Jun 30, 2012 | 02:47 PM
  #141
TheSaint's Avatar
TheSaint
When you did your electronic tach conversion is the Autometer dial showing in the ceter of the Corvette rachometer?
If so i would paint the autometer dial black like the color of the Corvette tachometer so the Autometer dial does not show at all
I like what you have done to the engine. Both the downdraft and crossram looks good
I would have a hard time decide which to choose if it was my car
Old Dec 7, 2012 | 11:29 AM
  #142
BB68Vett's Avatar
BB68Vett
Richard, any update. I've been following your build. Are you done yet?
Old Dec 7, 2012 | 12:18 PM
  #143
aaroncorvette's Avatar
aaroncorvette
Great hot rodding/EU debating thread
Loving the crossram intake
Yes and the EU is a corrupt mess, we get all the **** without any of the benefits.
Old Jan 25, 2013 | 08:59 AM
  #144
tyancey00's Avatar
tyancey00
any new updates?
Old Jan 25, 2013 | 10:58 AM
  #145
Richard454's Avatar
Richard454
Yes.. I think all the pieces are coming together w/ it...I am shooting for the Hot Rod Power Tour this June.
I just got an ECU that will be able to handle sequential fuel injection- twelve LS2 coils and the ITB's
It's the latest from Megasquirt -MS3-Pro
I pulled out the mock-up V12 and have the 'real' engine sitting in the engine bay- looks like everything is going to be close but fit...
I got the intakes back from my welder buddy- and the L88 hood will clear the fuel rails-
I decided I have to have air conditioning- but NO place was left for a compressor on the front of the motor...I found a 12VDC brushless motor and controller used for 18 wheeler cabs thanks to no idle laws. Putting in in the fender well and I have a Vintage Air system on order...
And thanks to "Tom B1"s idea with the Ford Probe Headlight Motors- I won't have vacuum lines running all over nor a vacuum tank...
http://forums.corvetteforum.com/c3-t...new-way-4.html
I'm working on putting together the engine wiring harness...a lot of wires...Here's one of the LS coils harnesses I made up-
Old Jan 25, 2013 | 11:21 AM
  #146
GmPartsDirect.com's Avatar
0GmPartsDirect.com
Former Vendor
Amazing work and craftsmanship! Cant wait to see the finished product!
-Mike W.
GmPartsDirect.com
Old Jan 25, 2013 | 05:30 PM
  #147
KTKelly's Avatar
KTKelly
Haven't read the entire thread, so someone (dountful) may have mentioned this...
I think this is a cool thing, but I'd like to do it in reverse.
Take a 7 series Beemer and fit it with a big block and 5 speed...
Wouldnt that get some attention?
A big luxo sedan pulls up next to you at a light and all you hear is the rumpety rump, and then it lights up the tires....
Old Feb 10, 2013 | 12:59 PM
  #148
Richard454's Avatar
Richard454
THANKS...
There's a couple of guys that have taken the 7 and dropped in a LS motor...
Harness is almost 'wrapped' up- awaiting some BMW cloth harness cover. I used the BMW connectors and 'tray' from a harness I had laying around-
The tough part was the throttle linkage...but I finally figured it out...Junkyard parts from a Mercedes and an Audi...
Richard
Old Feb 10, 2013 | 01:26 PM
  #149
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have been following this build since the beginning, I love it! Hotrodding at it's finest!!
The electric A/C compressor is a great idea, and your fabbed throttle linkage is awesome! I can't wait for the start up vid!
I am working on the same electric headlight motor mod, also thanks to the same thread by Tom B1. Do You happen to have a pattern for the brackets you made? It would save me some time! Yours looks great, I see you didn't cut the bottom of the housing, but instead notched the top. I like.
Old Feb 10, 2013 | 02:09 PM
  #150
TheSaint's Avatar
TheSaint
Have you decided on what kind of exhaust you are going to use?
Using side exhaust or almost straight pipes under the car with this V12 might sound really good
Old Mar 7, 2013 | 11:59 PM
  #151
Richard454's Avatar
Richard454
Thanks guys...I am going w/ sweet thunder side exhaust under the factory covers. I'll put the template up tomorrow for the headlights....
I'm getting really close to firing this thing up....
I'm in the process of finally assembly -throttle bodies-finished making the mounts for the fuel rails however still waiting on some aluminum tube to finish the vacuum block for the map sensor.
MY BIG step- the harness is finished. I hooked up the coils -injectors- air and coolant temp sensors plus the throttle position sensor.
I have put together a baseline program set up or tune for my engine- wasn't really that hard to do w/ "TunerStudio."
NOW the big test - I hook up 12volts power it up and connect the USB to my Laptop...It works!!! And here's proof-
I first have the throttle body w/ TPS sensor and got it calibrated- you can see it on the gauge on the Laptop. Next I run the hairdryer on the coolant temp sensor and then the Air temp sensor- and you can see the temps rise...
Next I run a injector test- you have to listen closely-the injectors click in sequential firing order- I labeled them A-L to verify..then I do the same with the coils...almost there!!!
Richard
Old Mar 8, 2013 | 07:27 AM
  #152
diehrd's Avatar
diehrd
Are you going to pull it all out after you have it all set up and detail the engine compartment ?
Old Mar 8, 2013 | 11:35 AM
  #153
Richard454's Avatar
Richard454
Absolutely !!!! Just mocking up right now...plus it's been to cold to do the Lizardskin coating!!!
Old Mar 19, 2013 | 10:05 PM
  #154
sibre2001's Avatar
sibre2001
6th Gear
I am all kinds of jealous of that car. Awesome work man. Can't wait to see it all put together.
Old Mar 19, 2013 | 11:47 PM
  #155
dmaxx3500's Avatar
dmaxx3500
alum headed 600'' big block chevy would put those german/british engs to shame
Old Mar 20, 2013 | 12:26 AM
  #156
7t9l82's Avatar
7t9l82
a built 350 would too, but thats not the point. he wants something no one else has. now where did i put that 440 6 pack.........
Old Mar 20, 2013 | 04:42 AM
  #157
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I think you used it as a Boat Anchor lol.
To Corvette V12?
Old Mar 20, 2013 | 07:00 AM
  #158
L88Plus's Avatar
L88Plus
Wow, Richard, what a build! Anything other than a GM engine in a 'vette doesn't have a lot of appeal to me, but you're changing my mind!
It's this sort of out of the box thinking and innovation that this country was built on. Your patience and perseverance are amazing, most of us would have abandoned this project when we first pulled the BMW engine and had it swinging on an engine hoist..."Fxxx that, I'll find a big block". You seem to be the kind of guy that thrives on challenge. It's easy to see why...you really are a process oriented sort of fella. Too bad that when you reach your goal, it'll be time to start a new one.
Next time how about a turbocharged LS stroker in one of those donor beamers...
My hat is off to you. Please carry on, I'm anxious to see this beast on the road.
Old Mar 21, 2013 | 02:21 AM
  #159
bustinthings's Avatar
bustinthings
Navigator
This thread is awesome. I've always loved the idea of putting a completely different engine in a car. And what better than this, I'm a huge BMW fan and C3 corvettes were my first love...well except for maybe the Ferrari F40...first attainable love.
Old Mar 21, 2013 | 03:38 PM
  #160
TheSaint's Avatar
TheSaint
The Ferrari F40 is on top of my list
It is much better looking than the Ferrari F50 as well
