Bee Jay's weight loss mods.
When does the car get so light that it won't stick in the curves? Just wondering if getting light does not have a down side. I am a pilot, so I am quite familiar with power to weight, but in the flying world you don't care about traction in curves. I am not suggesting weight loss won't improve things, but just raising the question. Is not the front to back weight balance important, the center of gravity of the car, etc. Duntov talks about the steel rear spring actually provided a low CG weight where the card needs it. All the weight reduction on the front end could possibly lose steering traction???? All questions to ponder.
less mass to accelerate and stop -
to get a car to stick its corners better - use air (wings, splitters, etc) to make the turn happen faster
As for the 78/79 C3, the stock weight distribution according to GM was 52% R: 48% front-I have also seen 51%R : 49% F-which is pretty darn good, especially in the 70's and better than most of the other C3's, especially the big blocks. All C3's including the 78/79's were setup from the factory to understeer or push at the limit-remember Ralph Nader from the 60's and the corvair. I too have owned my 78 L-82 4 speed forever and have had it on a weight diet of sorts for a long time but no where near Beejay's. First big one was in 1986 with a 360 composite rear spring (still on the car and perfect) and shortly after that the AC removal to balance off the 42 lbs reduction in the rear. I have done the big things like McJacks shorty header versus cast iron manifolds, lighter battery, removal of all smog equipment including monster CAT and AIR pump and hardware, lighter aftermarket 17 inch rims instead of OEM Aluminum RIMS, aluminum radiator/water pump (has L-82 aluminum intake). I wonder what it weighs with no spare and no T-Tops on it?
Beejays 3040 lbs is very impressive. Weight it without the tops on!! As I recall, the Tops weight about 17 lbs each. Those 34 lbs would get you really close to that magical 3,000 lbs number.
What about the 79 seats? I can tell you that those suckers are really heavy-took them out a few years ago to do the carpet and remember they were really heavy. As I recall, the C5/C6 seats and some aftermarket ones are much lighter! Are you going to switch seats any time soon?
Last I checked, my 80' weighed in at 3,180. Glass T-Tops on, 1/2 tank of gas, no spare tire/carrier, and no one it. One of these days I want to swap the heads and brake calipers for aluminum. Also, a set of brake rotors with aluminum hats.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
My opinion is that the '79 seats are pretty light, as they're just foam in a fiberglass bucket. I got a pair of '79 seats in a parts swap a few years ago. They're about 10-12 pounds lighter (each) than my stock '69 seats. I then welded up some custom brackets to adapt them to the '69 floor panel, and took another six pounds out of the system, for about a 30 pound reduction in vehicle weight.
BJ Inspired ........ Thanks
1980, Who has a correct oem curb weight for this year ?
Followed a lot of what BJ has done here is my list
hood and nose from oem to after market 35 pounds
head lights 24 pounds
full aero space component breaks 88 lbs
control arms TRZ 12 lbs
lighter rims 12 lbs
spare tire and carrier 49 lbs
cross member 5 lbs
AC delete 50 lbs
Rear spring 50lbs
starter 8 lbs
aluminum heads 35 lbs .
Aluminum intake 12lbs
377lbs total
Lets be fair and add 50 for 3" dual exhaust and stainless headers over the factory pipes and manifolds / also add 38lbs for the 4L80e
377 minus 88 leaves 289 pound loss over all.
new sbc 427
584hp / 567tq
3.92 rear gears
lighter rims 12 lbs
cross member 5 lbs
AC delete 50 lbs
Rear spring 50lbs
starter 8 lbs
377lbs total
new sbc 427
584hp / 567tq
3.92 rear gears
Did some playing around with my corner balance weights. Moving my 36# DieHard from LR to RF would take me from a 47.5/52.5 F/R to 48.5/51.5. It doesn't get any lighter but moves a little more to neutral. Appears to be plenty of room to put the battery up there. Anybody?
Thing is, playing with sway bars and shock tuning probably achieves the handling benefits without the aggravation.
(FWIW, I moved my battery to the RR compartment, and reduced the front brake bias slightly, to get the rear brakes to "earn their keep" a bit more.)
Since then I have removed lots of things, put on the Weld Draglites,L88 hood, converted to manual brakes and steering, aluminum heads, yada yada ...the list goes on.
Problem is I remarried and gained a ton.............so it's pretty much a wash.
Wow! This thread is still going? Thank goodness for email notification.
I spun a bearing in the old L-82 350. I spent over six months trying to obtain an aluminum block and gave up. I had the stock block machined and bored .030 over and clearanced for a 383 crank. Putting the engine together now. While the engine is out, I'm going to a Borgeson power steering setup. I've been driving an LT1 C4 in the mean time, great car, and cheap! Stay tuned.
BTW I was down to 3000lbs when the engine died. Once the car is up and running, I'll start trimming the pounds again.
Hey, How is everybody? Gkull? Paul Dana? 69427? 427-sbc? Justin? You all good?
Bee Jay
Bee Jay
Bee Jay
Bee Jay
happy to see your still at it...
Bee Jay
Bee Jay
Things are going reasonably well here. Just trying to improve my aluminum TIG skills. My car was 2815# two years ago (at Heartland Park Topeka's scales). They were shutdown last year (bankruptcy), but are reported to be planning operations this year. Can't wait. Did a few more mods to the car last year and over the winter so far, and I'm hoping for 2790#.
