My first rebuild
Old Mar 8, 2013 | 12:08 AM
  #1141
FatCat's Avatar
FatCat
Ok! Time for you guys to weigh in and post some pix!
I am working on cleaning up my door jambs. To me this whole project is slop unless this part is perfect. I need pix of your front and rear jambs, the process you used and materials. I need to understand what every nook and cranny should look like so really close ups will be nice.
I also need pix of how much gap should be at the front and back of the door when closes. Mine seem really wide also what seams and seam sealer works best
And is paintable.
This is the boat critical part to me for some reason. When I open the door to get in, I want it to be just as beautiful as the rest of the car.. Lots of post here guys, please!!!!
Old Mar 8, 2013 | 12:23 AM
  #1142
SuperBuickGuy's Avatar
SuperBuickGuy
And is paintable.
not a chance, my jambs are private!!!!
Old Mar 8, 2013 | 12:26 AM
  #1143
FatCat's Avatar
FatCat
Don't be scared SBG! Post'm up brother!
Old Mar 8, 2013 | 01:29 PM
  #1144
FatCat's Avatar
FatCat
And is paintable.
Anyone? Bueller, Bueller? Haha
Old Mar 8, 2013 | 01:58 PM
  #1145
birdsmith's Avatar
birdsmith
Fatcat,
I think if you dig around about halfway through my thread you'll get a picture of what it akes to get those jambs cleaned up. I used stripper on the big surfaces but mostly it was a lot of 60 grit sanding then working down to finer grits ountil I had all of the paint removed. The door jambs, hood sill, and rear deck opening sills were easily the most tedious, time-consuming parts of the whole sanding job because of all the tight corners, and they were also the hardest parts to get good paint coverage in. When you're shooting paint in those areas you've got to double- and triple-check to make absolutely sure you've got good coverage from every angle. Not THAT important in the grand scheme but important if you want the result to be non-cheesy...
Old Mar 9, 2013 | 11:44 AM
  #1146
hugie82's Avatar
hugie82
I cheated and buffed my door jambs and the looked like new when I matched the OEM color on my vette.
Other car and trucks I've done I usually took the door off especially if going to a different color. Align your doors perfectly and Drill a guide hole in the hinge to use when re installing the doors so alignment will be easy.
With the doors off you gain access to the hinge, spring, inside the front fender and of coarse the bottom of the door. Shoot it let it dry then re install to shoot the rest of the car.
Old Mar 9, 2013 | 12:45 PM
  #1147
FatCat's Avatar
FatCat
Anyone know how to figure how much "sprayable" paint and clear I need to figure for my car? I am still thinking HOK Kandy. Thanks!
Old Mar 9, 2013 | 01:14 PM
  #1148
FatCat's Avatar
FatCat
And I just bet this was the cause of a lot of my rattling in the rearend when driving! It wasn't bolted down just holding on because the wiring harness was connected to it.
Old Mar 9, 2013 | 05:07 PM
  #1149
SuperBuickGuy
1/2 gallon of each plus its attendant fluids - you'll have plenty left over for touchups
Old Mar 9, 2013 | 08:54 PM
  #1150
FatCat's Avatar
FatCat
The guy at the paint store is saying 2 sprayable gallons each of candy and clear and 1 gallon of base? That sounds like a ton and it is really expensive.
Old Mar 9, 2013 | 10:10 PM
  #1151
SuperBuickGuy
candy? ugh! why candy?
it is just about right - candy doesn't cover in 10 passes - so you need lots of paint to keep darkening it to get to the shade you want.
Of course, if you ever really light the tires up, you'll damage the paint and it'll be unrepairable without getting your razor blades back out and stripping the car.
Old Mar 9, 2013 | 10:18 PM
  #1152
FatCat's Avatar
FatCat
Ugh! Why is that? I just saw a dark blue candy on a Vette I liked. What I am after is this, a dark blue that when the light hits it just right, it has a purple hue. If that makes sense. Not a purple car but kind of a second take to say. Was that car blue or purple.
Like this. http://m.flickr.com/#/photos/countycorvette/8139230724/
Old Mar 9, 2013 | 10:27 PM
  #1153
Priya's Avatar
Priya
Mmmmmm, candy...
Old Mar 9, 2013 | 10:28 PM
  #1154
SuperBuickGuy
candy is for show cars, and cars that one race to the best spot for their owners to park their lawn chairs.
candy is fragile
candy is expensive
candy is impossible to match if it ever needs repair
candy doesn't last as long as any of the 2 stage paints
if you want purple in your blue, do a two stage with blue base and a purple tint in your clear coat - throw some pearl in the paint and watch it explode with color.
Old Mar 9, 2013 | 10:31 PM
  #1155
FatCat's Avatar
FatCat
candy is fragile
candy is expensive
Is the purple tint part of the pearl or something else?
Old Mar 9, 2013 | 10:46 PM
  #1156
FatCat's Avatar
FatCat
Originally Posted by Priya
Mmmmmm, candy...
Hahaha!
Old Mar 9, 2013 | 11:24 PM
  #1157
Priya's Avatar
Priya
Fatcat, I didn't see any pictures on the link you posted.
To My first rebuild
Old Mar 9, 2013 | 11:27 PM
  #1158
FatCat's Avatar
FatCat
Hmmm? Google "County Corvette Ghost Flames" that will pull them up on Flicker.
Old Mar 9, 2013 | 11:41 PM
  #1159
SuperBuickGuy
no... pearl is pearl - it's a fine metal flake (sometimes even ground up pearls) that makes the car sparkle. Tinting is using candy mixed with clear to slightly change the color of the paint on top of the basecoat. When done right, it's described as having depth (people will say the paint looks wet, or the paint looks like you can reach into it).
Old Mar 9, 2013 | 11:53 PM
  #1160
FatCat's Avatar
FatCat
So how do you know how to
Mix the candy in the clear and what do you mix the pearl with? Base or clear?
