Second rebuild 1973
Old Nov 6, 2013 | 11:15 PM
  #301
FatCat's Avatar
FatCat
Hahaha! True story! I looked at AC Delco NOS shocks on eBay for kicks! All shocks $35-$75, Corvette rear ACDelco rear shocks. $600-$1200. Hahaha you can't make this stuff up.
Alan I looked at Paragon and didn't see any but maybe there is more than one Paragon site.
Scott
Old Nov 6, 2013 | 11:30 PM
  #302
1974ta's Avatar
1974ta
Default Shocks
Scott
Unfortunately GM long ago discontinued the Delco shocks that most closely resemble the originals. The new ones are made in Mexico. I have been looking for the older correct GM shocks for 6 years! They are called AC Delco "Reactec." Love to find a set or two.
I ended up getting Monroe shocks which again are not correct, but painted gray the resemble the originals and cost less than the Delco shocks. They will be for judging only. Although the ride was acceptable.
I also bought a set of Bilstein HD shocks used for one of the deals of the century, which I will use for driving. Cannot wait to try the Bilsteins.
BTW: Use Ford Dove Gray Engine paint to match the gray the shocks were originally painted. Had one long time NCRS guy look at the Monroe shocks I painted and he was duly impressed with the color.
Bill
Old Nov 7, 2013 | 12:46 AM
  #303
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Machinist are able to "part off" (precision remove) one end of the original worn-out shock in the correct area so that it can be rebuilt/welded together/remachined so the shock is usable and that the weld is not visible once the shock is painted.
We used that procedure all the time to rebuild 3,000 PSI hydraulic cylinders on industrial equipment.
Approximately 2 hours or less in labor charges plus cost of parts for EACH shock.
Old Nov 7, 2013 | 01:17 AM
  #304
FatCat's Avatar
FatCat
That would be awesome by the shocks on my car aren't original. I will probably put them back on until I can afford to buy some originals for judging.
Scott
Old Nov 7, 2013 | 09:26 AM
  #305
71scgc's Avatar
71scgc
Scott,
I'll try to call you later today.
Carter
Old Nov 7, 2013 | 03:07 PM
  #306
hugie82's Avatar
hugie82
Scott
Koni adjustable shocks for @$100 each. Best bang for the buck!
Old Nov 7, 2013 | 04:25 PM
  #307
Tim 1973's Avatar
Tim 1973
Scott
I guess I should not have scrapped the org's. They were still good and likely were the original shocks. I would not have thought they were worth anything except the metal weight.
Old Nov 7, 2013 | 04:28 PM
  #308
Alan 71's Avatar
Alan 71
Hi Scott,
I was looking at Paragon's #3803. $38 each.
With some gray paint on them I think they'd look pretty good.
Regards,
Alan
Old Nov 7, 2013 | 04:50 PM
  #309
FatCat's Avatar
FatCat
Thank Alan! I will look them up!
Scott
Old Nov 7, 2013 | 04:54 PM
  #310
FatCat's Avatar
FatCat
Here are what is currently on the car.
Any idea what they are?
Old Nov 7, 2013 | 05:34 PM
  #311
FatCat's Avatar
FatCat
Oh no!!!!! 😔 never toss anything original...
Old Nov 7, 2013 | 06:31 PM
  #312
Tim 1973's Avatar
Tim 1973
I have a bunch of stuff that I still have, from seats to ac unit with all the duct workings. Once done I will clean everything up and put it all in the for sale area.
Old Nov 7, 2013 | 08:12 PM
  #313
FatCat's Avatar
FatCat
Or maybe I will hit you up for some stuff along the way!! 👍
Old Nov 7, 2013 | 08:23 PM
  #314
Tim 1973's Avatar
Tim 1973
Let me know what you need and Ill let you know.
Old Nov 7, 2013 | 11:19 PM
  #315
FatCat's Avatar
FatCat
Any chance you have the original radio *****?
Old Nov 8, 2013 | 09:28 AM
  #316
doorgunner's Avatar
doorgunner
That idea was for OEM shocks to save the shocks and save some $$$$$$ also! Being a machinist was a lot of fun----"after normal working hours
Old Nov 8, 2013 | 02:07 PM
  #317
FatCat's Avatar
FatCat
Good idea and I am looking for some used originals! Right now with my job situation, I am more than ever trying to save every penny I can to keep moving forward. I wii keep the shocks I have and clean them up for now since those are an easy replacement part at a later date.
To Second rebuild 1973
Old Nov 8, 2013 | 04:03 PM
  #318
Tim 1973's Avatar
Tim 1973
The raido was missing when I got the 73 sorry
Old Nov 8, 2013 | 05:30 PM
  #319
FatCat's Avatar
FatCat
No problem! I will let you know of there is anything else!
Scott
Old Nov 9, 2013 | 12:17 AM
  #320
FatCat's Avatar
FatCat
After checking out Juliet's Corvette I decided to paint some parts that I know I will get points knocked off for but it's ok, I won't have parts needing rust prevention all the time.
Tonight events!
I may dull this down with some flat clear but not sure yet.
Enjoy! I sure am...
