Anyone have any idea of a tutorial or pix of the process you went through on fitting up the Fiberglass bumpers? Even though it seems fairly straight forward, I am really nervous about sanding and grinding on the thing.
I would make a cardboard template that would fit the nose of the car. Then transfer that shape to the bumper. If done accurately, the bumper should fit perfectly.
Pete
PS. I have never done that, but it's what I would do if faced with the problem.
Pete
I get how to do the cutout but are you saying I would actually cut a small potion of the entire bumper off to get it to fit?
I also watched this on YouTube can you all tell me if this is an acceptable tutorial on glass work and are there any brands of materials recomended?
That sounds like a good idea, prob what a 1/2"at the widest point and how far down you think?
Measure how far away it is at the ends, then pie cut the bumper that amount. That should get you in the ball park. Then trim as needed. I would go almost to the tip of the bumper.
This makes sense along with Pete's template idea. I will make a template of the bumper and pie cut it first and that should get me there.
Then I just have to learn how to work with the glass and should be good.
Thanks guys, I'll post pix when I get it done.
Scott
Scott
Template sounds good, just get it to where you want it and then cut. Fiberglass work is not hard, just messy. Use gloves when you do it. And a mask. Have fun. If you make a mistake, grind it off and start over. Even the experts started somewhere.
Scott
Scott,
What I meant was a template of the nose of the car. It should accurately depict the exact line on the front of the hood surround. Overlay that on the bumper and you have your cut line.
Pete
Thanks guys!!! Getting the diff ready to pull right now and will work on this bumper on the morning. Off tomorrow and going to try and get it done.
Anyone happen to look at that fiberglass video to see if it is the proper procedure?
Also is there any particular resin and body filler I need to use?
Thanks everyone, you make these things much easier for me and I appreciate the help!
While I am at it! Hahaha the tank has some surface rust, what do you do to get rid of it and keep the tank looking original?
Thanks!
Scott
You might want to consider a new tank... That metal is pretty thin and it's 40 years old. My decision would be new if the inside was rusty. If it is clean then use one of the rust removal products. Eastwood has a few of them. Others on this forum will surely have other solutions.
Bob
Bob
He gone!!!
Hey while I am here making decisions on the rearend, can anyone tell me where or how to verify this is original to the car?
Scott
There should be a flat surface on the bottom of the diff case, below the right side output shaft. There will be numbers and letters stamped on that surface, date and ratio. Post them here and somebody will chime in and decode it for you. Can't tell if original or not; if date is close to car built, you can assume its original. Ratio should match what was offered that year.
Pete
