Second rebuild 1973
It's called Evapo Rust and I got it at harbor freight.
I did a small portion on the frame and a bag of rear end bolts.
The instructions are to soak the parts or use soakd paper towels and wrap with plastic.
I soaked it over night.
Cleaned with water and removed most of the rust and only left a all light punt and the old paint.
Lightly wire wheeled less than 2 min
The frame part I was happy but not overly pleased. Now the bag of bolts.. Whole other story!!!!
I was shocked at how well it worked on them, maybe I won't have to replace as many as I thought.
If I rated this stuff based on how pleased I was with the results, I would give it an 8 on a scale of 1-10 with 10 the highest satisfaction.
I just wanted to share this with you all and hope I didn't break any forum rules in doing so.
Scott
I have a 5 gallon bucket fill with rust remover I bought at home depot. When I need to clean rust off something I just stick it in there over night and it comes out like new the next day.
It's REALLY difficult to replace the long brake, fuel, and vapor lines with the body mounted on the chassis.
For me the 'dark pockets' in the frame in your picture still need to be addressed. Also, you chose a nice flat area for your test... it's the corners and welded brackets on the frame that are, and will be difficult to clean completely, with the liquid.
I don't think these's any short cut in preparing a frame to paint.
Regards,
Alan
I still believe there's no substitute for cleaning fasteners using a wire wheel mounted on a bench grinder if you're going to replete them.
Sorry!
Regards,
Alan
Sorry!
Hey speaking if plating, is it expensive to set up and learn to do the plating myself? I know you mentioned that was what you did. Do you have a good resource for learning the process?
Thanks!
Also started cleaning up the fuel lines.
I picked up some John Deere Vlitz Black today here's a picture of my rear end cross member.
The drips I have are around the bottom edges on the original parts. No drips on the bigger parts that I have seen. Imagine GM using a wire to hold the part and dipping it in black paint. The bottom most area on the part dipped has the runs.
I will have to see if I have some pictures. I prefer to post on NCRS because I really dislike the method of here on the forum of using Photo bucket.
Bill
Bill
No need for pix, I get what you are saying brother!
Scott
I also went ahead and started taping off everything so I don't get overspray on places it's not suppose to be.
I also got this in the mail today!!
