Second rebuild 1973
Old Oct 13, 2013 | 12:44 AM
  #181
Tim 1973's Avatar
Tim 1973
Originally Posted by FatCat
Started soaking the TArms they aren't looking like much fun. Hahaha wish me luck!!!
Yea that's why mine went to Vansteal to have rebuilt. I also do not have a run out gage. They were recommended but others that had them done by them.
My back is killing me as I was on a ladder got to many hours today. I will try to get on the Vette tomorrow. Need to sand and get engine compartment painted. I ordered the new ac system from vintage air.. Need it so I can compleat the interior wiring
Old Oct 13, 2013 | 07:23 PM
  #182
FatCat's Avatar
FatCat
Get it on brother!!! Hahaha
Old Oct 13, 2013 | 07:26 PM
  #183
FatCat's Avatar
FatCat
TArms, I hate you!!!
Here is where I am at and I have ready many posts but before I stray hacking away, I would like to try and get the bolt out. Castle nut came right off today but what is the best way to tell if you have to cut the bolt out? I tried to get a wrench and a socket on the head of the bolt with no luck. Any suggestions would be much appreciated.
Scott
Old Oct 13, 2013 | 08:03 PM
  #184
1974ta's Avatar
1974ta
Default T Arms
Scott
Hi Scott,
The T Arm bolts fuse to the sleeve they pass through. Since yours is a 73 the T arm shims should be slotted. Pull the shims out and label them carefully. Take pictures too. Once you get the shims out you should be able to see the bolt.
The bolts are very hard. I believe at least grade 5. You will need the proper sawsall blade. Mine came right out so what I am saying has been perused from other threads.
Were you able to tap the end to the edge of the T arm bolt hole? If so it is not frozen. Use a thin stubby screw driver to push it through. You should then be able to grab the bolt on the outside of the T arm pocket. The bolt can be tough to see and get at but can be done. A triangular reinforcement and brake block/line obscures the bolt.
I used long nosed pliers to get the bolt out once I saw here it was located.
Hope this helps.
Bill
Old Oct 13, 2013 | 08:12 PM
  #185
FatCat's Avatar
FatCat
Hey Bill, I have not gotten the bolt too be in the hole. Is there anyway to try and break it loose before cutting the bolt or should I head to Lowes now? Hahaha
Scott
Old Oct 13, 2013 | 08:32 PM
  #186
Tim 1973's Avatar
Tim 1973
I soaked mine with wd40 for 2 days before I took mine off. I used a lift table under the arm to take tension off, I removed the shims by removing long carter key that holds them in then with a brass drift and sledge I gave it a good hit and it came out..
Old Oct 13, 2013 | 08:45 PM
  #187
1974ta's Avatar
1974ta
Default Bolt
Scott
Did you try both sides? There is barely enough room to tap on the bolt but it is tough to get a clear shot. You can not hit it very hard but maybe it just needs some light tapping to get started.
You may want to soak for a couple more days and see it that helps. before just cutting them out. Otherwise cutting them out is the only option.
There are some good threads about cutting them out. It happens more often than not.
Bill
Old Oct 13, 2013 | 09:07 PM
  #188
FatCat's Avatar
FatCat
Thanks guys!!! I will try telling the tension off and if that don't work let them soak a little more and as a last resort cut them out!! Stay tuned hahahaha
Scott
Old Oct 13, 2013 | 09:20 PM
  #189
Tim 1973's Avatar
Tim 1973
Scott
You should be able to get a good shot on it with a sledge with either brass drift or punch since the body if off.
Old Oct 13, 2013 | 09:33 PM
  #190
Tim 1973's Avatar
Tim 1973
For some reason I thought you had removed the body, my bad... Makes it much harder if it is frozen on the frame.
Not sure if you have a pneumatic punch or a chisel if you have a chisel bit then cut it off flat and used it to knock the bolt loose or cut the bolt off with a sawzaw
Old Oct 13, 2013 | 10:58 PM
  #191
FatCat's Avatar
FatCat
No problem brother! I started pulling the shims on the drivers side and only got one set out at thi point so I soaks again and will try tomorrow!! PITA! Hahaha
Old Oct 13, 2013 | 11:08 PM
  #192
jane1011's Avatar
jane1011
3rd Gear
Are there any special buffing tools to help with the rocker trim?
Old Oct 14, 2013 | 12:25 AM
  #193
FatCat's Avatar
FatCat
Hi Jane! I asked that question a while back and the commences is no because the trim is anodized and to keep it original you have to live with it the way it is or buy new. I you aren't worried about those points you could use 0000 steel wool to clean them up, paint the black parts and clear coat them!
Thanks for posting.
Scott
Old Oct 14, 2013 | 01:25 AM
  #194
FatCat's Avatar
FatCat
Oh! Got bored while waiting for the TArms to soak and did this! Any guidance from here is appreciated. I am not painting them but plan on using RPM Magic when done.
Process: First I cleaned the dirt off then hit them lightly with an already used 3M pad on the angle grinder to knock off the rust and patina. Then I cleaned it up a little more with 220 grit sand paper to get any light swirls out of it.
The process took about 15 min per axle to get them to this point, not too bad.
Scott
Old Oct 14, 2013 | 09:21 PM
  #195
FatCat's Avatar
FatCat
In the words of my daughter!!!!! OMG!
That just about broke me down....
Old Oct 14, 2013 | 09:35 PM
  #196
Tim 1973's Avatar
Tim 1973
I see one TA arm off, did you get them both off?
Old Oct 14, 2013 | 10:48 PM
  #197
FatCat's Avatar
FatCat
You are very observant! Hahahaha have not done the other side yet.....Think I will work the frame on this side for a couple of days before taking it on....Hahaha!
To Second rebuild 1973
Old Oct 14, 2013 | 10:57 PM
  #198
Tim 1973's Avatar
Tim 1973
Keep soaking it.. When I removed my body I used 3 of the large bottles of wd40 over a few days soaking every bolt. Figured that was easer then removing broke off bolts... Everything came out with out a issue, the TA like I said took a good swift hit with a sludge and a brass drift. But was able to get them out..
I think putting them back in after I got them back from the rebuild shop was harder then taking them out... Putting the shims in is a real pain...
Keep up the work....
Old Oct 14, 2013 | 11:28 PM
  #199
FatCat's Avatar
FatCat
Well crap! Hahahaha I was hoping they went in easier! 😃
Old Oct 14, 2013 | 11:31 PM
  #200
1974ta's Avatar
1974ta
Default Reinstall
I am hoping they go back in a bit easier too.
Bill
