Second rebuild 1973
Old Oct 14, 2013 | 11:44 PM
  #201
FatCat's Avatar
FatCat
Originally Posted by 1974ta
I am hoping they go back in a bit easier too.
Bill
Hey Bill, what tools did you use to get the rust between the frame and body?
Scott
Old Oct 14, 2013 | 11:55 PM
  #202
Tim 1973's Avatar
Tim 1973
Bill
My lift table helped but trying to get all the shims in sucked... I got it close but ended up with a few extra shims that I will take with me when I get the 4 wheel alignment. I got a set of SS shims as part of the rebuild.
Old Oct 14, 2013 | 11:59 PM
  #203
1974ta's Avatar
1974ta
Default rust
Scott
I did the best i could with the red pads, wire wheels, and mostly my fingers and 80 then 150 grit emory cloth/paper.
Time consuming and tedious and even then there are areas you cannot get to with the body on.
Bill
Old Oct 15, 2013 | 12:26 AM
  #204
FatCat's Avatar
FatCat
Bill
I have never used emery cloth is it the same as sand paper basically?
Scott
Old Oct 15, 2013 | 10:01 AM
  #205
1974ta's Avatar
1974ta
Scott
Not sure why but the emory cloth seems to work better to sand surface rust off.
It is like sandpaper but seems to hold up better when sanding rust.
B
Old Oct 15, 2013 | 10:17 AM
  #206
hugie82's Avatar
hugie82
Emory has a heavy material that keeps it from shredding. I use a sanding sponge to knock the scales off and then POR15. You need rust to cure the POR15. I put on my truck frame and it was disaster because I cleaned the frame down to bare metal. With in a year, it bubbled up and heavy rust formed underneath.
Sometimes it pays to read directions
Old Oct 16, 2013 | 12:46 AM
  #207
FatCat's Avatar
FatCat
Man bro that must have been really painful....it's really good to hear from u!
Old Oct 16, 2013 | 12:51 AM
  #208
FatCat's Avatar
FatCat
Bill
Time consuming and tedious has become a part of life for me and this car so I think I will try it out!!!
Old Oct 16, 2013 | 10:37 PM
  #209
FatCat's Avatar
FatCat
Any we are still alive and progressing!!! Hahaha
BTW Emory cloth taped to a paint stick is becoming a favorite in the plethora of tools!
Thanks for that advise everyone...
Scott
Old Oct 16, 2013 | 10:48 PM
  #210
1974ta's Avatar
1974ta
Default frame
Lookin good!
Gonna be purdy when done.
Bill
Old Oct 16, 2013 | 10:57 PM
  #211
FatCat's Avatar
FatCat
Lookin good!
Bill
If I can figure out how to paint in the really tight spots I will be really happy..... My dad sakes me tonight, " why are you doing all of that? No one will ever see it." most just don't get it!!
Old Oct 16, 2013 | 11:00 PM
  #212
FatCat's Avatar
FatCat
Any input on how to approach the stuff flaking off of the storage bins would be greatly appreciated and the best approach to cleaning the wells too.
Scott
Old Oct 17, 2013 | 12:54 AM
  #213
FatCat's Avatar
FatCat
Well I got too close and couldn't sleep so back to the garage.
Man those factory welders got wild!!
Old Oct 17, 2013 | 01:16 AM
  #214
Tim 1973's Avatar
Tim 1973
yep the org welders seem like they were always grabbing for a beer... LOL
Old Oct 17, 2013 | 01:23 AM
  #215
FatCat's Avatar
FatCat
Hahaha!!! Maybe if and when I have it judged, the NCRS will give me extra credit for leaving that stuff. Hahahaha. Just kidding.
Old Oct 17, 2013 | 01:46 AM
  #216
FatCat's Avatar
FatCat
Paging Alan71!!!
I hope you see this and don't mind I posted the picture but I have a question about it.
Can you tell me what the process for getting the underneath fiberglass that clean is? It appears to not be painted but is that just from a good cleaning?
Thanks!
Old Oct 17, 2013 | 09:16 AM
  #217
71scgc's Avatar
71scgc
Scott,
Use a putty knife to get the heavy stuff off the fiberglass, then some Simple Green or Purple Power and lots of paper towels.
I left mine raw.
Carter
To Second rebuild 1973
Old Oct 17, 2013 | 09:40 AM
  #218
FatCat's Avatar
FatCat
Originally Posted by 71scgc
Scott,
I left mine raw.
Carter
Thanks Carter!
Old Oct 17, 2013 | 05:10 PM
  #219
Alan 71's Avatar
Alan 71
Hi FC,
I don't recommend using anything stiffer than a PLASTIC paint scraper on any of the fiberglass under body, wheel wells, or spare tire tub.
You REALLY don't want to gouge or scratch the surface.
I used lacquer thinner in copious amounts on lots rags to soak through the crud everywhere on the underbody. I didn't find anything that enough lacquer thinner would work it's way through.
After the underbody and tub was clean I sprayed it very lightly with semi-flat clear. This restores a bit of sheen and makes it easy to maintain the fiberglass.
To answer your PM... not a problem.
It looks like you're making nice progress. I'm not sure though if I'd have done any painting until you've cleaned the underbody.
Good Luck!
Regards,
Alan
Here's another picture showing the under body.
And another at the transmission tunnel. You can see a little sheen.
Old Oct 17, 2013 | 06:05 PM
  #220
FatCat's Avatar
FatCat
Thanks for posting Alan that helps me a lot! I really debated with myself on whether to paint or not. My end thought process was any overspray that does get through would be on the old dirt and grime instead of the glass. After last night though I started thinking maybe it was a mistake. We live and we learn right!?!?
Scott
