Second rebuild 1973
Sep 22, 2013 | 06:10 PM
Quote:
Originally Posted by
PeteZO6
There should be a flat surface on the bottom of the diff case, below the right side output shaft. There will be numbers and letters stamped on that surface, date and ratio. Post them here and somebody will chime in and decode it for you. Can't tell if original or not; if date is close to car built, you can assume its original. Ratio should match what was offered that year.
Pete
This?
In case you can't read it: AWW149 E1
Sep 22, 2013 | 06:27 PM
FatCat
This?
That looks like it. Somebody should chime in. If not, there should be a list that decodes it on the Internet.
Like this.
http://http://home.comcast.net/~jmasperi/vetrears.htm
The date coding will take more research.
Pete
Sep 22, 2013 | 06:34 PM
PeteZO6
I believe that is the casting number. You want to find a stamp - think of the numbers stamped on the right front deck surface of the block. The "matching numbers" thing.
Pete
I think I was editing as you were typing!!! Hahaha sorry
Sep 22, 2013 | 06:46 PM
FatCat
LOL. No wonder! I thought I was going nuts.
thanks for clarifying.
Pete
Sep 22, 2013 | 07:02 PM
PeteZO6
Pete
Hahahaha! We are all crazy....
Sep 22, 2013 | 07:17 PM
AW= 3.08:1
W is for Warren MI plant
149= day of the year
Donnie
Sep 22, 2013 | 07:25 PM
DonnieP73
AW= 3.08:1
Donnie
Thanks Donnie so it doesn't even have the year on it....
Sep 23, 2013 | 12:19 AM
Is it possible to restore front grills with chrome on the edge or do people just paint them?
Scott
Sep 23, 2013 | 12:28 AM
The year is on the left side below and a little forward of the stub axle.
Mike
Sep 23, 2013 | 12:40 AM
tracdogg2
Mike
Mike is it stamped or raised?
Sep 23, 2013 | 11:35 AM
It's raised.
It will b a letter, then 1 or 2 numbers, then one number.
B 24 3 for example or B 5 3
Mike
Sep 23, 2013 | 01:22 PM
tracdogg2
It's raised.
Mike
That it?
Sep 23, 2013 | 04:26 PM
Sep 23, 2013 | 05:08 PM
tracdogg2
Yep
Do you know the year based on that?
Scott
Sep 23, 2013 | 11:17 PM
Sep 24, 2013 | 09:57 AM
If I can make out the code, it seems
D = April
18 = date
3 = 1973
Someone can correct if I am wrong.
Donnie
Sep 24, 2013 | 01:52 PM
DonnieP73
D = April
18 = date
3 = 1973
Donnie
So the casting date would be April and the date it was ready for the car would be May? That would make sense and would seem to be original since the trim tag shows May as the build month and the TTop bags are stamped May 22 1973.
Sep 26, 2013 | 09:29 PM
Pulled the tank tonight and this is all that is left of the tank sticker. Is there any way possible to salvage what's left?
Sep 26, 2013 | 11:07 PM
Looks very similar to mine... a good photo is probably the best thing you have.
Sep 27, 2013 | 01:23 AM
carjack007
Man I hope there is some way to salvage what's left but maybe not. 😒
