EFI conversion question
Old Dec 11, 2017 | 11:40 AM
  #41
zwede's Avatar
zwede
Originally Posted by chstitans42
Sure, but mu question still remains the same. Can the factory steel lines be used so the PTFE hose is at a minimum?
Yes, the factory 3/8" steel line can be used as either supply or return. You still need to add a second line. Some use the 1/4" vapor line as return which may or may not work. I used 3/8" steel brake lines for my return. I also prefer to keep the rubber hose sections as short as possible. The rubber hoses I have are:
Tank to supply line, ~1 foot.
Supply line from frame to engine ~6"
FP regulator (on engine) to return line (on firewall), ~6"
Return line to tank, ~1 foot.
Old Dec 11, 2017 | 03:41 PM
  #42
NewbVetteGuy's Avatar
NewbVetteGuy
Wait... are you sure?!?
Up to how many HP can you still use the 3/8" factory steel line?
My fuel system is the last part of my EFI conversion I still need to deal with; I've been avoiding it because it was just mind-meltingly complex for me and I wanted to try to understand it in chunks.
My factory steel line stops up basically just in front of the starter on the passenger side and then transitions to a section of rubber hose, then goes back to steel for a little bit, and then rubber to steel at the carb (the line to the carb got cut decades ago and replaced with rubber and hose clamps....). -If I kept the steel line up to that same spot near the starter how would I transition to a high pressure EFI hose the rest of the way to the regulator?
Adam
Old Dec 11, 2017 | 05:13 PM
  #43
zwede's Avatar
zwede
Haha, been running it this way for 15 years.
At least 600 hp. My 454 was blowing black smoke when I had the EFI set too fat so the 3/8" line was enough to overfuel it no problem.
A simple barb fitting on the regulator side and the factory line already has a barb on it that is sufficient. Use EFI-style clamps. You can get 1 ft EFI hose at auto parts stores. Additional plus is it's ethanol compatible.
EFI hose clamp (notice it doesn't have the worm clamp slots which would cut into the hose):
Old Mar 23, 2018 | 10:31 AM
  #44
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Originally Posted by clwi
Well, my Holley rep here in Sweden told me that i should keep me MSD dist as it is with vac advance, i wont gain anything by letting the Sniper control timing....lots of issus with MSD and controlled timing...and only way to get it fixed is to buy the Holley sync dist and thats expensive!
May I ask where in Sweden did you get your EFI?
I'm from Europe also and am looking at the possibility of going EFI.
Old Mar 23, 2018 | 01:57 PM
  #45
1moore522's Avatar
1moore522
Default Gooseneck?
Where did you get the gooseneck in the picture with the Sniper temp sensor installed? does it work OK installed there? In the instructions it told to install in the manifold or the block. Thank you.
Old Mar 24, 2018 | 12:15 AM
  #46
lionelhutz's Avatar
lionelhutz
CTS should go in the coolant before the thermostat, not after. It would work, but the cold start to hot running fuel transition will not be correct. If you need a spot then get a spacer block that goes under the thermostat with a hole in the side for the sensor.
Old Mar 24, 2018 | 05:17 AM
  #47
terrys6t8roadster's Avatar
terrys6t8roadster
While doing the Sniper conversion on the 69 which has a BTO 200r4 tranny the TV calbe hook-up to the throttle linkage is an in house modification at BTO. $165 for modification and $49 for insured shipping. T
Old Mar 25, 2018 | 12:43 PM
  #48
clwi's Avatar
clwi
At the time i could not get it in Sweden, ordered it from Summit.
Old Mar 25, 2018 | 12:48 PM
  #49
clwi's Avatar
clwi
That sensor is for OEM temp gauge, Sniper sensor is in one of the heads.
Old Mar 28, 2018 | 08:51 PM
  #50
1moore522's Avatar
1moore522
Default What about Plugs??
Did anyone have to change the plugs to a different heat range? What plugs are you running?
Old Mar 28, 2018 | 09:25 PM
  #51
derekderek's Avatar
derekderek
Get a small cap HEI. They are everywhere, cheap and durable. GM distributor designed for efi.
Old Dec 12, 2019 | 10:15 PM
  #52
stevelang's Avatar
stevelang
it looks like you used the old supply line on the bottom of the tank to connect to the inline pump. where and how did you connect the return line (the old steel supply line) to the tank? i ask because my 66 convertible only has that one supply pipe at the bottom of the tank.
