Originally Posted by Norcoastal
Why no professionally rebuilt carb?
Where would be the best place to get one?
I didn't say "professionally" rebuilt. I said "commercially" rebuilt. The commercially rebuilt carbs, which some people think are "professionally" rebuilt, are pure junk and will run worse than what you have. Read the papers I've written about the subject. Email me if you need copies. I'm aware of 3 people who can do a professional rebuild job in addition to several here on the Forum who can do a very good rebuild and setup on their own cars.
I see from another thread you have going that you will be selling the car. Rebuild what you have and make it run right. Every dollar you sink into the car will be a loss, so just make it run well.
Lars
I appreciate the comments and advice. Not sure about selling it just yet. I got all caught up in chrome bumper cars and wanted one. Now that I'm back to my senses, the reality is that a chrome bumper car isn't in my future anytime soon. I have what I have and I'll have it at least 2-3 years if not more.
I enjoy just owning my Vette and I want it to run well and I want to have fun.
I think having the correct carb rebuilt professionally is the way to go.
I'll keep my eyes open on this forum for someone selling one.
I have a carb off a 79 with L48 auto, if it will work for you. I'd sell it for $40 plus shipping. I could ship it to Lars if you work a deal with him, let me know.
That's awful nice of you. Does it matter if it's an automatic or manual?
I'm sure the difference is something that Lars can adjust for. The linkage will be correct. I know it needs a choke pull-off which is usually replaced during rebuild anyway.
You might have missed it...but I wrote this in post #27. The photo I am referencing is in post #22.
With you having no heat riser..I am curious on how fast the tubes I showed in your one photo get hot when you have the engine running???
Like I wrote...I am curious on how long it takes for the tubes to get hot and your choke to pull off.
DUB
Dub,
Im running headers and no heat riser, the tubes warm quick and will usually kick choke off within a minute or two... HOWEVER it didnt work right when i bought the car....and fast idle cam is way off now since i set timing back, previous owners messed with it.
Pettyty hard to tell someone how to tune a carb over the internet, from the pics of carb that he posted it looks like many adjustments have been made, even kick off arms look rip and torn like someone bending on them. I would suspect idle mix is way off as well as fast idle cam...all these little settings can make or break a good working motor....running rich at startup, reving the **** trying to warm it up takes it toll...hense a blown rad hose....i would say that carb and setup would work great, just have to familiarise yourself with a few adjustments. Truth be told you going to need to learn it on a different carb if you do swap it out. So why not try onthe old carb first. You may be surprised how good it works after all!!!
Thank you VERY much, I just sent Lars a PM. Stand by.
Dub,
Thank you and I think I said, it's a frankencarb. The PO made one out of parts. I still think my best bet is the correct carb for the car sorted out professionally.
Yes i know norcoastal, no fault of yours....im pretty sure the guy you got it from just did a quick swap and sent it on its way...the tell tale for me was seeing the choke set up way to rich, which would keep the fast idle cam on almost indefinately...meaning your car when warmed up should be around 2000-3000 rpm idle. Not good.
Now that choke is set properly...let engine get use to ideling normal a few days/drives....then look up fast idle cam adjustment for quadrajets on youtube. What a few videos and verify your choke is closing when cold, you should be able to get it working pretty good with a phillips screwdriver and a little patience, even if carb is worn out, you at the very least could make it driveable amd have a little fun in the process!!!
Thank you so much. Ever since your help, it runs 1000% better.
I do want to get the correct carb, but it's so nice to have a normal running car without the fuel rich smell.
The only reason I am asking how fast those tubes get hot...is that I have had many Corvettes that have had altered exhaust systems and those tubes would take along time to get hot and pull off the choke. Literally 3-5 minutes of run time...you could touch them and they would not burn you. And it would be worse in the dead of winter also.
DUB
Hi DUB,
I have to check when I get back to New York. I'm in Austin now.
I will let you know and thank you so much for your help.
Steve
Steve,
No worries. Hopefully it heats up quickly like a previous Corvette Forum member posted in a response to you about this.
Also...the small black hose (1/4" I.D. I believe) that you see that is going from the choke housing to the one tube on the side of the carb. I can tell you that in time.... that hose will dry up and crumble away due to it is not like the silicone hose that GM used. It will possibly last for a few years...depending on how much you drive it and how hot it can get...but I have replaced this type of hose on several Corvettes where someone took off the orange-ish colored silicone hose and put a regular back hose on it. It is not hat big of a deal...until it fails.
