The Force Awakens...
Old May 15, 2019 | 05:03 PM
  #261
DorianC3's Avatar
DorianC3
This looks in sorry state. Anything contemporary recommended to replace these heat shields?
Old May 15, 2019 | 06:18 PM
  #262
caskiguy's Avatar
caskiguy
http://www.dynamat.com/automotive-an...e-restoration/
https://www.heatshieldproducts.com/hp-sticky-shield
Old May 16, 2019 | 04:15 PM
  #263
DorianC3's Avatar
DorianC3
This evening’s festivities included yanking out the under-car heat shielding... and some expanding foam that was edging it.
I measured the remains out and will replace it with some modern heat shielding.
Yes, I’m wine over beer.
Fortunately all the sharp shielding retaining thingies are intact.
I think WHILE I’M AT IT I’ll replace the starter cable with a new and beefier one.
Old May 16, 2019 | 04:25 PM
  #264
DorianC3's Avatar
DorianC3
Something a little more dramatic was Bondo to happen at one point with this car: rust !
I am not a fan of under-car paint. It’s, of course, used on occasion to mask rust. In this case, a white chip in black paint caught my eye. As I suspected: Bondo !
Of course I went ape and started poking around the entire car with a pick-hammer and screwdriver. I found nothing more.
The area doesn’t seem in awful shape. Once I dug out the rust, I quickly fell on solid metal.
Ill weld this up in a couple of weeks or so, once I am finished with the interior.
Old May 16, 2019 | 04:28 PM
  #265
caskiguy's Avatar
caskiguy
Just so you know, it's not that hard to pull the body off if needed to do structural work on your frame. Sorry you have the frame issue but glad you found it. Good luck with the repair.
Old May 16, 2019 | 04:34 PM
  #266
caskiguy's Avatar
caskiguy
Looks like my reply failed to post. Here's the drain hole in the channel.
1970
Old May 16, 2019 | 04:47 PM
  #267
DorianC3's Avatar
DorianC3
1970
Thank you ! This helps bigly.
Old May 19, 2019 | 05:35 PM
  #268
DorianC3's Avatar
DorianC3
Made just a little more progress.
Dyed a few more panels but ram out of dye when I got to the seats. It looks great tho !!! And I learned the meaning of “light coats” with HVLP. Looks sharp
Push button start hole plugged.
And welded up radiator support.
Old May 22, 2019 | 02:53 PM
  #269
DorianC3's Avatar
DorianC3
Moving along...
Now that the insulation is out... let’s get a closer look at the starter cable
Transferring the clips in the right place and orientation definitely made the job easier.
“He has a huge Schläng” - Darryl Van Horn.
Old May 22, 2019 | 02:57 PM
  #270
DorianC3's Avatar
DorianC3
The insulation came in. A high tech upgrade.
Old May 26, 2019 | 03:40 PM
  #271
DorianC3's Avatar
DorianC3
Got the shifter console back in. What a PITA. Everything that was disconnected has been reconnected: missing bulb, disconnected vent switch ...and all the fiber optics work now. It took me most of the day.
I started the upper dash driver side (also a royal pain) but had to give up after I had to solder two of the grey wire sockets that popped off. I had run out is sunlight.
Old May 27, 2019 | 06:19 AM
  #272
DorianC3's Avatar
DorianC3
Getting the lower dash pad driver’s side in was not fun. In fact I do not look forward to doing that over anytime soon. Tho I did have to pull it out in order to fix small things such as a couple of bulb sockets that popped off. I have become quite good at soldering them back together.
Yes, I need to by the correct tip for this job. But at hand was only this one.
Then for a test.
Some unexpected feedback confirmed that the license plate fiber optics work well.
Mmmmm. One cannot under estimate the positive vibe of a fully installed steering wheel and dash. No more leveraging tires while pushing the car
Rats ! I knew I forgot something: the cables for the speedo and tach. They are the push on type. I should be able to reach up there and press them on, hopefully without disturbing anything.
Old May 27, 2019 | 11:23 AM
  #273
OldCarBum's Avatar
OldCarBum
If you need to leverage the tires again to move your car around, spray a little “tiremagic”, or similar type product people spray on their tires sidewalls, on your tires tread.
Makes the concrete surface slick as ice and simple to slide the tires.
I used to do this to get my boats on tandom trailers close to the wall in a narrow garage.
Old May 27, 2019 | 01:16 PM
  #274
DorianC3's Avatar
DorianC3
Kewl !!! Thank for the tip !
Old May 28, 2019 | 03:04 PM
  #275
DorianC3's Avatar
DorianC3
And a little more progress
The center gauge cluster goes back in. It was a PITA. And it may have to come out again. The fuel gauge is pegging. My guess is that the connector is in backwards. I’m a little worried about the ammeter. I hope I didn’t put it in backwards as well. Any tips there would be welcome.
The passenger side lower panel is in and it looks good. Somewhat looking like a car again.
Old May 30, 2019 | 05:40 PM
  #276
DorianC3's Avatar
DorianC3
Made more progress today...
X clean out interior
X improve subwoofer install
X charge battery
X clean out rear storage compartments
- pad rear window trim to prevent rattling
X install battery with fast disconnect ( ! Battery back in the car is a big step. It also makes testing easier)
X improve grounds to get rid of parasitical radio noise
X mock up rear speaker install + test
X mend central air vent (mild fabrication required)
X install wiper bezel and switch.
X test wipers
X test fiber optics
- test ammeter
X figure out why driver side courtesy light does not come on. Same with rear courtesy light.
X fix door ajar switches
X connect driver side lower vent
X test fit speedo and tach cables. Do NOT install yet. They are a pita to remove. They will go on once I am sure I will not need to pull them again.
Having the battery finally back in with "unequivocal" cable is a huge step forward... both in terms of convenience for testing but also a psychological milestone. Yep, I need to patch up those holes.
I very pleased with the subwoofer... even with the compartment door shut it fill the car nicely. As others have said... nothing crazy; just the way I like it. Moving the speakers from the kicks to the dash was an excellent mod.
Merlot !
Hmmm... I really like that rear courtesy light. I am going to rethink the sound bar. I will probably try and mount these in the upper corners.
So far so good. All the interior lights work except for the shifter console climate control. The bulb is installed and works... but for some reason no light gets through. Not something I will bother with at this point.
Old May 30, 2019 | 05:46 PM
  #277
DorianC3's Avatar
DorianC3
The cigarette lighter works ... not just the power socket.
And the fiber optics already came in handy... thanks to them; I spotted a brake light that was not working properly. Without it I would not have known.
To The Force Awakens...
Old Jun 9, 2019 | 12:43 PM
  #278
DorianC3's Avatar
DorianC3
Today we repaired the sill plates. The screws weren’t really doing their jobs.
Easy enough. Rock solid.
Old Jun 9, 2019 | 12:46 PM
  #279
DorianC3's Avatar
DorianC3
Sealing the gap between the firewall and the cage.
Yes. That is an award winning Carolus beer. From the town over. Living in Europe has its perks.
Eatwoods version of dumdum works very well
Old Jun 9, 2019 | 12:53 PM
  #280
DorianC3's Avatar
DorianC3
Behold ! This is probably the first time this circuit has shone in the past 15 or 20 years. The connector looked like it was cut short. Again, no idea why anyone would do that
Neighbor youth working on his 80s VW Passat. Boldly taking on painting.
Speaking of painting, I sealed the T-top to windshield trim with dumdum and am testing 3D fabric paint to make it look presentable. Someone experienced on the board here did it this way. It looks promising.
Enough for today...
