Show Us Your Engines
Old Jan 20, 2025 | 01:06 PM
  #261
Stormin_Normin's Avatar
Stormin_Normin
Double tap
Old Jan 20, 2025 | 01:08 PM
  #262
Stormin_Normin
389 -3.75 stroke, 60 over, 11.3:1 compression, all forged lower parts, AFR 195 eliminator street heads, 230/236 .540/.550 lift roller with 1.6 Harlem Sharp rockers. Dual 500 Edelbrocks, chrome re-pop MT valve covers.
1-7/8 Doug’s headers and side pipes.
Old Jan 20, 2025 | 03:29 PM
  #263
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Wish I had that crossover with the thermostat in it
Old Jan 20, 2025 | 06:29 PM
  #264
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Rescue I know you are creative
Sounds like a perfect piece to have proto-typed in a 3-D printer, and then have an aluminum one made from the CAD file.
Done!
Or... saw the water section off of an existing manifold.
Old Jan 20, 2025 | 06:50 PM
  #265
Rescue Rogers
My manifold has 1/2 inch NPt fittings at the front and rear. I am looking into Blower remote thermostats as well as making my block into parallel cooling and using the rear 1/2 inch NPT fittings as well, then tying them all into the remote housing as well as incorporating the bypass as well
Old Jan 20, 2025 | 08:29 PM
  #266
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Looks like a thirsty engine.
Old Jan 21, 2025 | 09:39 PM
  #267
dgunnr's Avatar
dgunnr
Default 1971 lt-1
Stock 1971 LT-1 that i recently bought.
Old Jan 22, 2025 | 08:31 AM
  #268
Richard454's Avatar
Richard454
Ive got that intake....making it work with Weber DCo 50 carbs eventually
post 1540 I mention it and it makes sporadic appearances through out the rest of the thread
https://www.corvetteforum.com/forums...grades-53.html
Have you looked at something like this? Jenvey makes these-
Old Jan 22, 2025 | 10:40 AM
  #269
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I love your unique manifold Rescue.
But it is hard to beat the look of old-school downdrafts on a BBC!
Old Jan 23, 2025 | 05:34 AM
  #270
Rescue Rogers
For a while i liked the down drafts more, then for some reason i just fell in love with the crossram look. And since i cant find a crossram manifold that was reasonable, and then the gooseneck showed up, I jumped on it.
As for goiing back to EFI, electronics have soooo many ways to be an issue I am done with them for a while. Maybe someday I can go back but I love the mechanics of a carb
Old Jan 26, 2025 | 05:11 PM
  #271
wvleon's Avatar
wvleon
Default My 467
467 built by Mark Jones in my 1970 vert. Backed up by Tremec TKX 5 speed
Old Jan 26, 2025 | 06:19 PM
  #272
litevette's Avatar
litevette
@wvleon Very nice, clean and should be with plenty of power and gearing!
Question…that trans tunnel shielding. Aftermarket? How is it held in there? Adhesive?
Old Jan 26, 2025 | 08:14 PM
  #273
roscobbc's Avatar
roscobbc
Jenvy only advertise inlets for LS series Chevys - no big block manifolds
Old Jan 26, 2025 | 08:52 PM
  #274
wvleon's Avatar
wvleon
Default Trans tunnel insulation
The trans tunnel kit is held in place by some adhesive as well as tabs on tunnel itself that help clip it in place. Super simple to install prior to engine and trans install.
so far I feel no heat in cabin. Interior is fully insulated and headers are ceramic coated.
last thing I need in Phoenix is more heat in the cabin
I believe I bought the insulation from Summit
Old Sep 19, 2025 | 11:11 PM
  #275
OldCarBum's Avatar
OldCarBum
It’s been a little while since this thread has seen any updates, so I thought I would give it a push to see what else there is out there we haven’t seen.
Old Sep 20, 2025 | 12:27 AM
  #276
Piersonpie's Avatar
Piersonpie
This is my current setup, although I expect it to change frequently.
SBE 1976 L48 with 1979 L82 valve covers, Lunati 601012 cam, Flotek aluminum heads, Edelbrock 2601 intake, and an aftermarket open element air filter. Doug’s stainless steel side pipes/headers with custom braided spark plug wires.
Other than the engine I have a spreader bar, deleted the evaporator box, and coated the firewall with bedliner.
Old Sep 20, 2025 | 07:11 AM
  #277
ML67's Avatar
ML67
All aluminum 535" (4.615x4.00). 850 HP on pump gas
To Show Us Your Engines
Old Sep 20, 2025 | 07:26 AM
  #278
Rescue Rogers
This is a I-wish-it-really-happened picture!
Prototype SOHC 427 BBC ~600 HP
Rescue should like the injectors!
I cant believe i never updated this page
Finally figured out the magic for the tune, 44mm chokes, .070F8 jet with the idle air bleed enlarged. Figure with the individual runners it 580hp and 541 ftlbs at the flywheel.
As for wishing it happened, heres a pic of Zora with his hemi BBC prototypes.
Old Sep 20, 2025 | 11:15 AM
  #279
Maximillion's Avatar
Maximillion
Four deuces and a 4 spd and an L46…
Old Sep 20, 2025 | 12:10 PM
  #280
OldCarBum's Avatar
OldCarBum
Now that’s impressive!!!
